cp3? hard start? white smoke? - TheDieselGarage.com
Home Forum Who's Online Today's Posts Vendors Advertise Insurance Auto Loans
Go Back   TheDieselGarage.com > GM Diesel & Truck Discussion > Duramax 2001-2004 (LB7)
Thread Details Posted by 01_24valve, this thread has received 1 replies and been viewed 814 times.
Old 11-16-2011, 01:39 AM   #1
01_24valve
01_24valve's Avatar
2002 gmc that wont start with out a little WD. idles rough with white smoke all the way through the rpms loaded and not. rebuilt the filter housing and now it flows a solid stream of fuel without any air bubbles. but no fuel in the oil.
Has anyone ever heard of a injection pump going out? if so what are some things to check to tell? would a pressured lift pump help? are the injectors bad?
could it be low compression?
01_24valve is offline   Reply With Quote
Old 11-16-2011, 04:35 AM   #2
BriteWhiteRam
CRAZY CANUCK
BriteWhiteRam's Avatar
white smoke and bad idle and rough running sounds like Injectors to me, Get the balance rates checked out
+-4mm3 in park idling and +-6mm3 in gear idling are within spec, anything higher or lower are bad injectors
Aaron the Crazy Canuck
2006 Chevrolet Silverado LT 2500: LBZ - Allison, Greystone Metallic, 4x4,PPE airbox mod, missing muffler/cat, EFILive tuned by Nick at duramaxtuner, MA tie-rod sleeves and Grade C headgaskets
Totalled!! May 2nd 2008-2005 Dodge Ram 3500 laramie: Cummins auto, plain white, rebuilt tranny
1986 Mercury Capri - 5.0L, AOD, shorty headers, acell ignition, Holly street dominator intake, Holly 625 vacuum secondaries carb, Dual glass packs "my little yellow terror"
DURAMAX INDEX; You want a Duramax? you want to click on this >>The Duramax Index
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
Check out the NEW and IMPROVED TDG Truck Poll!
TDG TOTQ
BriteWhiteRam is offline   Reply With Quote
hard starting and white smoke help!!!!!!! chevyboy3672 5.9L Cummins 12 Valve (1994-1998.5) 9 05-23-2010 08:37 AM
Hard start, white/grey smoke ewales 6.5L Diesel Engine 20 10-13-2009 01:17 AM
Rough start and white smoke at cold start? bassn_07 2003-2007 6.0L Power Stroke 11 03-02-2008 10:57 PM
Hard to start / white smoke at start, again. bsigg 6.5L Diesel Engine 2 11-27-2007 03:57 PM
Hard start w/ white smoke ovruigo 2003-2007 6.0L Power Stroke 21 10-18-2006 12:47 AM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
