Oil leak at injection pump 3406b - TheDieselGarage.com
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Heavy Duty
Thread Details Posted by 377pete, this thread has received 5 replies and been viewed 1636 times.
Old 12-13-2011, 12:07 AM   #1
377pete
My pump is leaking oil and an oval cover towards the front on the pump but it's located on the inside part of the pump between the block. It also has one on the opposite side of the pump. Can I just remove it and clean it and put silicone or go buy the gasket? Does this cover hold anything inside? Looks kinda tight but I think I can remove it. Thanks for the help
377pete is offline   Reply With Quote
Old 12-13-2011, 12:35 AM   #2
SledMan
SledMan's Avatar
They are orings, not gaskets. They've gotten hard, brittle and square. Get new ones from Cat. The back one can be changed.....but its tricky. Just covers....no flying parts.
2005 250 Super Duty Crew. White and Grey. ARP studs, EGR Delete, and SCT from Vivian. CCV re-route, and 4" Magnaflow turbo back.
Other trucks: 1979 Kenworth W900A reg hood, 1980 Ext hood, 1982 Kenworth Cabover Aerodyne (BJ and the Bear) 2000 and 2003 Kenworth W900's. All Caterpillar Power. My 2003 has an MBN I converted to 6NZ. Early 550 file, 211-3026 squirts. 800 cam. Acert twins via custom mount. ARP head bolts. 856 to the tires via Antrim Dyno.. with the tuned file.
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
SledMan is offline   Reply With Quote
Old 12-13-2011, 12:40 AM   #3
377pete
Thanks foe the reply. Any suggestions on how to go about it easy. I have a cat dealer close I can go buy the parts.
Old 12-13-2011, 12:46 AM   #4
fastshovelhead
fastshovelhead's Avatar
My pump is leaking oil and an oval cover towards the front on the pump but it's located on the inside part of the pump between the block. It also has one on the opposite side of the pump. Can I just remove it and clean it and put silicone or go buy the gasket? Does this cover hold anything inside?No, it is used to check rack travel. Looks kinda tight but I think I can remove it. Thanks for the help
I would recommend replacing the oring.
I see sled already took care of this wile I was replying
Going Nowhere Fast
fastshovelhead is offline   Reply With Quote
Old 12-13-2011, 12:46 AM   #5
SledMan
SledMan's Avatar
You'll have to pull the compressor.....then you can get right to it.
Old 12-13-2011, 02:49 AM   #6
SledMan
SledMan's Avatar
Are you sure its the inspection cover on the back? There is an Allen plug on the back, in the oil rail that is bad to loosen and seep oil. May be it, too......
3406b oil leak in front of water pump Hitmanhart54 Heavy Duty 5 09-10-2011 12:15 AM
DT466 fuel leak from injection pump zag Medium Duty 6 05-10-2011 01:59 PM
cat injection pump leak 377pete Heavy Duty 4 02-26-2011 02:29 AM
3406b pump jellyhole83 Heavy Duty 5 11-26-2010 02:25 AM
I need an injection pump and an aftermarket lift pump for my 98.5 24v CRAZY ROB Dodge parts wanted 2 02-10-2010 07:35 PM
