case 4490 - TheDieselGarage.com
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Utility & Farm Tractors
Thread Details Posted by 5.9silverado, this thread has received 3 replies and been viewed 1017 times.
Old 03-03-2006, 12:58 AM   #1
5.9silverado
case 4490
is it true that if that if you turn the pump up @ advance timing that the engine will run hotter(like alot hotter asif they cant handle it)? it gained 200rpm just by straight piping it does good just when you start gradual incline pulling 32' cultivator it starts to lose power.. would it be possible for 200hp out of the 4490?:shrug:
5.9silverado is offline   Reply With Quote
Old 03-03-2006, 04:14 AM   #2
nevrenufhp
Super Moderator
nevrenufhp's Avatar
Advancing the timing actually cools it back down. The turning up the pump is all the heat. Add a pyro and crank up the pump, then see how hot the EGT's get when it's really working hard.
Dale
my daily driver:67 F100, 300 4V, cammed, 4 spd.
or, 08 VW R32.
work rigs: 94 IH 4900, DT466(originally 230hp), #0 fuel plate, tighter gov springs, 22* timing
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline   Reply With Quote
Old 03-04-2006, 12:39 AM   #3
5.9silverado
10-4 ive talked to dad bout that ..it will probaly gain more rpms right? were already in the yellow range on the tack, i dont know how many rpms it will take.. case couldve put a smaller tack than the engine is rated for, i dont know for sure the dealers couldnt tell me
Old 03-04-2006, 02:21 AM   #4
bmoeller
bmoeller's Avatar
Not unless you jack with the governor. It wil still limlt the RPMs. As said before, adding fuel makes more heat, not advancing the timing.
"Obama = Hoax and Chains"
