Oil coming out of the dipstick! - TheDieselGarage.com
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 5.9L Cummins (1998.5-2002)
Thread Details Posted by mopar440cu, this thread has received 28 replies and been viewed 6879 times.
Old 12-22-2011, 02:58 PM   #1
mopar440cu
Question Oil coming out of the dipstick!
Hey Guys,
Maybe one of you can help me with a question. I have an 01 dodge 24 valve and yesterday it started spirting oil out of the dipstick bad and smoking white after I fueled it up. I know its not the puke box plugged up, because i checked that. Is there any other places I should check for maybe crankcase breathing? Or am I going down the wrong path? I took the oil cap off and its puffin out the valve cover? It never got hot or anything, what is going on?? It only has 310,000 on it.
mopar440cu is offline   Reply With Quote
Old 12-22-2011, 05:54 PM   #2
Johnp3
High crank case pressure is caused normally by to much oil in the base not allowing the vapors to vent back to the front cover. Other things are the turbo can vent air from the compressor side to the crank case. Valve guides can leak air into the crankcase or you could have a piston scuffed and putting air into the crank case.
Your oil pan level should be 15 quarts / 14.2 liters. That is the level to the full mark.
To check the turbo, you have to isolate it and pressurize it to about 10 lbs, and if it vents into the crankcase it needs repair.
Pressurise the turbo outlet and that will test the valve guides for internal leakage, and if you release the pressure and turn it you can also find the cylinder.
The cylinder you can remove the pan and look up or remove the injectors and do a cylinder leak down test.
Just a thought!
1988 ford van fresh overhaul, 1991 nissan pick-up 1993 Caprice 2000 GMC S10 Blaser 2007 nbs 3500 GMC 4x4 crew-cab long box 17 inch single wheels Duramax Alison. BW turnover Ball. Furakawa FL35 loader. Retired, HD mechanic, worked on engines all my life. Fabricator welder. electrician. in the process of finishing my new shop. Live in Rock Creek B.C. Wife has a fruit stand.
Johnp3 is offline   Reply With Quote
Old 12-22-2011, 06:25 PM   #3
mopar440cu
Would the ehote smoke coming from the exhaust due this also the puffing from the oil filler cap?
Old 12-22-2011, 06:33 PM   #4
Johnp3
If you have white smoke coming out the exhaust then you can remove the exhaust manifold, and see which cylinder it is, look into the turbo turbine to the ends looking for damage. Cut apart the oil filter and look for piston aluminum.
Then you have decisions to make.
The Following User Says Thank You to Johnp3 For this addition to TDG:
mopar440cu (12-23-2011)
Old 12-23-2011, 01:59 PM   #5
mopar440cu
Someone said it could ne fouled injectors. Will that push oil out the dipstick? I know it will cause the white smoke un sure about the other.
Old 12-23-2011, 05:45 PM   #6
Johnp3
I have done a lot of these engines and changed very few injectors, if one has blown or cracked a tip it will smoke a lot but if you are already getting the puffing from the breather, it already has damaged the piston. You need to test it and fix it.
Old 12-27-2011, 08:17 PM   #7
mopar440cu
Just a thought!
so you're saying that turbo could be the probs to? I have a friend coming over saturday to do a compression check. how would I check the turbo?
Old 12-28-2011, 04:58 PM   #8
mopar440cu
Hey John,
Thanks for the info number one. Number two since I am waiting for the compression check guage, now coming on Saturday, how would I check the vaccum pump and turbo?
Old 12-28-2011, 10:43 PM   #9
Johnp3
The turbo you have to block off the intake and use the plug for testing the CAC pressurise the compressor housing to about 10 lbs.
The vacuum pump I do not know I worked on trucks that did not have them.
If you are going to pull all the injectors and do a compression check, I would recommend a cylinder leak down test it will give you more information, and is a lot less mess.
Old 01-16-2012, 12:57 PM   #10
mopar440cu
Johnp3, I finally did a compression check and the 1 piston only had 100 on the reading. The others were over 300 varying a little. Could this be a valve seal, ring or head gasket?
im looking for a dipstick and the pipe.... biz 1994-2003 7.3L Power Stroke 0 12-02-2009 09:31 PM
7.3 idi dipstick length.... MrDanB 7.3L and 6.9 IDI (Pre 1994) 6 03-30-2009 09:43 PM
Oil leak at dipstick? 96stroker 1994-2003 7.3L Power Stroke 2 04-15-2008 01:09 AM
7.3 idi dipstick 91/2 7.3idi Whats Been Sold 0 11-13-2007 09:11 PM
Billet Dipstick??? ymmot General Ford Truck and Excursion 2 08-29-2007 01:47 PM
