Upper radiator hose collapsed? - TheDieselGarage.com
Thread Details Posted by bootcamp, this thread has received 2 replies and been viewed 2864 times.
Old 12-24-2011, 12:32 AM   #1
bootcamp
bootcamp's Avatar
I opened up the hood to my truck the other morning just to make sure everything was squared away before i cranked it up to head to town and noticed that the upper radiator hase was collapsed. After driving it and for a while and it reached operating temp, the hose looked just fine. Checked it again the following morning and same thing the hose was collapsed again. Its not unlikely that the hose is getting week and needs to be replace with 108k miles on it. Just curious if there is something else I should be looking for.
TIA
Paul
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline   Reply With Quote
Old 12-24-2011, 12:54 AM   #2
harry6.0
harry6.0's Avatar
Most of the time on vehicles when this happens its due to a bad radiator cap thats releasing pressure in the system and creates its own air siphon through the cap. But also can be caused by a loose hose clamp or cracked coolant reservoir or anywhere up high in the system where air pressure can bleed out.
Harry
Jan 03' built 6.0/F250cc4wd trqsft/SCT-tuned by KEM-Performance/Garrett Powermax vg-turbo/blue spring mod/gauges=egt+boost+fuel+SG2/exhaust/airaid intake/DR 4.5 lift/dual bilsteins/315's/greasable ball joints/powerstop/smittybuilt/kc lights/high idle mod/roll-n-lock/T5-Rotella 10w30 with (Archoil AR9100 in the oil) and (AR6200 in the fuel)http://www.archoilspokane.com/
harry6.0 is offline   Reply With Quote
The Following User Says Thank You to harry6.0 For this addition to TDG:
bootcamp (12-27-2011)
Old 12-27-2011, 03:41 PM   #3
cartmanea
Check the vent on your overflow container too. It should be able to suck air past the cap under vacuum, but that vent could be plugged up.
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline   Reply With Quote
The Following User Says Thank You to cartmanea For this addition to TDG:
upper radiator supports needed dzljon Ford Parts wanted 6 01-12-2011 01:14 AM
Upper Radiator Hose bigdieselpower 1994-2003 7.3L Power Stroke 6 10-29-2009 03:49 PM
Upper Tubo Hose VONDIESEL 2003-2007 6.0L Power Stroke 8 09-16-2007 05:40 AM
Upper Hose team_penin 1994-2003 7.3L Power Stroke 6 02-15-2006 09:40 PM
Upper radiator hose ? Unbroken 2003-2007 6.0L Power Stroke 6 12-02-2005 08:09 PM
