White smoke from exhaust? - TheDieselGarage.com
Home Forum Who's Online Today's Posts Vendors Advertise Insurance Auto Loans
Thread Details Posted by I_b_strokin, this thread has received 6 replies and been viewed 3716 times.
Old 12-27-2011, 09:11 AM   #1
I_b_strokin
Exclamation White smoke from exhaust?
Ok so I'm a new owner of a 2005 Ford Excursion Eddie Bauer edition, and Im not a diesel expert and don't know everything about diesels if they are different from gasoline engines! Ok well i have white smoke coming out of my exhaust when my truck idles and no other time? And it's pretty hefty of the amount of smoke that comes out.
When I bought the truck the previous owner said he replaced the injectors and injector cups 3 months previous to me buying it, and he never told me if he flush the coolant system and I found diesel fuel in my coolant which is from the cups leaking by I am told. I flushed it and ran simple green through it to clean the fuel out and it's been fine.
So if anyone could let me in on some stuff to check into about this and if it something I should really worrie about!
Thanks
John
I_b_strokin is offline   Reply With Quote
Old 12-28-2011, 01:41 AM   #2
harry6.0
harry6.0's Avatar
How does the truck run? Smooth idle...good power...starts easy? Does it smoke all the time, cold and warm engine temps? Your coolant condition should be monitored, make sure you are not losing coolant and having to add any coolant. Keep the coolant level at the minimum line or just below it. Your white smoke condition could be(EGR valve or EGR cooler related, or a constant leaking fuel injector issue).
You can pull the EGR valve out(2-bolts hold it in place on top front of intake manifold-see the 6.0 bible in the stickies section at the top of this forum for locations) and check down inside the intake manifold hole where the valve comes up out of, and if it's sooty and dry, then your ok, just clean the valve and vacuum out the hole. If it's wet down inside the hole, then your EGR cooler has failed.
Harry
Jan 03' built 6.0/F250cc4wd trqsft/SCT-tuned by KEM-Performance/Garrett Powermax vg-turbo/blue spring mod/gauges=egt+boost+fuel+SG2/exhaust/airaid intake/DR 4.5 lift/dual bilsteins/315's/greasable ball joints/powerstop/smittybuilt/kc lights/high idle mod/roll-n-lock/T5-Rotella 10w30 with (Archoil AR9100 in the oil) and (AR6200 in the fuel)http://www.archoilspokane.com/
harry6.0 is offline   Reply With Quote
Old 12-28-2011, 10:00 PM   #3
lenzhotrod
A small amount of white smoke can be considered normal when cold. Could be from the fuel you are using or moisture in the exhaust system. Keep an eye on that coolant. May take a couple of flushings to get all the fuel out! I find dishwasher soap works well.
lenzhotrod is offline   Reply With Quote
Old 12-28-2011, 10:56 PM   #4
bismic
Don't want to throw bad news at you, but Ford has found that most of the time you have fuel in the coolant it is due to cracked heads (not injector cups). Not saying that is your situation, but I would keep an eye on it.
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower250A;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
bismic is offline   Reply With Quote
Old 12-31-2011, 10:08 PM   #5
ralphinnj
Got Torque?
ralphinnj's Avatar
Images: 80
Could also be HG's.
Black 2003 F350 Dually, Nothing Stock
Other Rides:
Black 2006 300C SRT8
Black 2012 CTS-V (630HP)
Black 2008 Mercedes E550
ralphinnj is offline   Reply With Quote
Old 01-01-2012, 12:33 PM   #6
TooManyToys
Curmudgeon
TooManyToys's Avatar
AS you speculated, the fuel in coolant could be residue that was never cleaned out. For that situation, I would just keep an eye on the coolant and see if the fuel returns. If it does there is a possibility that one of the cups or injectors were put in improperly. But before I would get worried I would see if the fuel returns.
As far as the idle smoke, does it have a sweet smell and are you loosing coolant? If sweet, most likely coolant. If not, it can be an sticking injector that is pushing too much fuel. Or worst case poor compression on one or more cylinders. The best way to check that is have a dealer run a compression test with the software.
Jack -
Formerly FMTRVT, Manager of Vehicle Testing - Brakes
2003 F-350SC Lariat 4x4 6.0L Auto
Truck Modifications as below in Pictorials on Facebook. Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
TooManyToys is offline   Reply With Quote
Old 01-01-2012, 03:15 PM   #7
D.F.A.
D.F.A.'s Avatar
Mine poured white smoke at idle when the bearings in my turbo was going out . The oil from the turbo was burning off in the exhaust . Turbo wasnt making any strange noises at the time either. I could see the oil in my exhaust pipe.
D.F.A. is offline   Reply With Quote
White smoke blue smoke low on coolant whats wrong littlebigrig6.0 2003-2007 6.0L Power Stroke 24 12-05-2009 11:11 PM
white smoke vs. black smoke DUMPIN99 1994-2003 7.3L Power Stroke 20 03-07-2008 11:01 PM
07-5-4 Cold Start Driveability - White Smoke, Lacks Power, Exhaust Odor, Surges, Runs Squatch Ford Oasis requests 0 03-22-2007 02:41 AM
White Smoke, Lacks Power, Exhaust Odor, Surges, Runs Rough, Or No Start - 6.0l PSDPlayer 2003-2007 6.0L Power Stroke 4 01-24-2006 01:18 AM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
