400 CUMMINS BIG CAM 4 - TheDieselGarage.com
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Heavy Duty
Thread Details Posted by Overload, this thread has received 11 replies and been viewed 7375 times.
Old 12-27-2011, 11:31 PM   #1
Overload
I have a 88 peterbuilt with 400 cummins cpl 833 how do i know if it has stc and can you adjust stc ?
Overload is offline   Reply With Quote
Old 12-27-2011, 11:35 PM   #2
ynot
The other guy
Three connected oil lines going to the center of the rocker boxes. And the adjustment is only to make it function.
ynot is offline   Reply With Quote
Old 12-28-2011, 12:19 AM   #3
theakerstwo
A cpl 833 is stc engine
theakerstwo is offline   Reply With Quote
Old 12-28-2011, 01:59 AM   #4
Overload
my engine has about 5000 miles on a complete in frame overhaul with rebuilt injectors i had my pump rebuilt set at 10% over stock the engine still smokes gray and mises when cold and does not pull like i think it should i am the 2nd ower have all the repairs records that have been done on it. can the stc not work right and cause this?
Old 12-28-2011, 02:16 AM   #5
Overload
i do not understand how the stc works can someone explain this to me? what does the block with the lines running to it that is below the pump do? my pump man says i should have 66# of fuel presure idling i don't i have very little presure about 6# thats all i had before i took the pump off for rebuild.
Old 12-28-2011, 09:08 AM   #6
theakerstwo
I think he means it should have 66 psi of oil prssure to set the stc in advance mode.If not then the injectors may be in retard mode and this will cause a smoke problem. The oil line to the oil manifold that goes into the top of the rockers for the STC tappets needs a tee fitting put in line and the oil pressure checked their. f not enough takie it to some one that works cummins and ask for help. Another thing is does the idle oil prssure on the engine stay up good?If not remove the pressure releif valve on the bottom of the oil pump and pull the plunger and spring out and clean it and see if that helps. This is a coomon problem of something hanging the plunger and sticking the plunger causing low oil pressure.
Old 12-28-2011, 12:19 PM   #7
ynot
The other guy
I put a couple washers behind the spring also. Adds about 10psi at 1500, 4 at idle. Helps a bit sometimes.
Old 12-28-2011, 02:32 PM   #8
CR Toney
CR Toney's Avatar
The block below the pump is the STC Valve. At Higher fuel pressures it retards timing and advances timing at low fuel pressures. I could be wrong but at max power your fuel pressure should be over 200psi. A 400 should make ~ 21psi of boost. Add a dual line kit to make it a 425hp. Too high of fuel pressure can bend push rods. On initial start up the truck should smoke run rough until oil pressure makes it to the timing advance and then the injectors. It should then run clean.
'95 T800 N14 13sp DO 4.33 gears
'89 W900B 444 Cummins CPL 1280 18sp 3.55 w/2sp axles 19ft CIM grain/silage box
'03 Dodge 2500 4x4 6sp modded just right
'05 Dodge 3500 4x4 6sp w/ Triple C hydra bed
Smarty Jr Centramatics ATS ex manifolds
'06 IH 4300 DT466 Alison 245HP
CR Toney is offline   Reply With Quote
Old 12-29-2011, 03:46 AM   #9
Overload
thanks every one for the info its been very helpfull. How does the stc make the timing change?
Old 12-29-2011, 07:12 AM   #10
theakerstwo
Thru the tappets in the hi priced injectors.
2011.5 CUMMINS 6.7L HIGH OUTPUT - Cummins.com Jeremiah 6.7L HO Cummins (2011.5-2012) 10 08-01-2011 10:54 AM
N 14 Cummins barbershop Heavy Duty 11 02-26-2008 01:57 AM
04 cummins rpm INT_MAN 5.9L Cummins (2003-2007.5) 1 09-18-2007 12:20 AM
Cummins Conversion Adapter 460 to cummins Dieselwrencher Diesel Conversion 0 05-23-2007 06:29 AM
Cummins Conversion Adapter 460 to cummins Dieselwrencher Whats Been Sold 0 05-23-2007 06:29 AM
