3406E crankshaft breakage - TheDieselGarage.com
Thread Details Posted by 20RPM, this thread has received 12 replies and been viewed 4763 times.
Old 02-04-2012, 11:41 AM   #1
20RPM
Maybe someone could give me an idea understanding what causes a crank to break in a 3406e while cruising down the highway at 65mph. Thanks
20RPM is offline   Reply With Quote
Old 02-04-2012, 03:08 PM   #2
bmoeller
bmoeller's Avatar
Whatever it was that caused it to crack in the first place. Just finally gave out.
Out of balance, abusive driving (i.e. severe shock loads),..............
"Obama = Hoax and Chains"
Old 02-04-2012, 09:04 PM   #3
Johnp3
If it breaks at the #2 throw it is from the belts to tight, That is the area and cause of most breaks.
#5 throw is usually from the transmission being loose.
Tell us where it broke, and pictures, of the break area.
1988 ford van fresh overhaul, 1991 nissan pick-up 1993 Caprice 2000 GMC S10 Blaser 2007 nbs 3500 GMC 4x4 crew-cab long box 17 inch single wheels Duramax Alison. BW turnover Ball. Furakawa FL35 loader. Retired, HD mechanic, worked on engines all my life. Fabricator welder. electrician. in the process of finishing my new shop. Live in Rock Creek B.C. Wife has a fruit stand.
Johnp3 is offline   Reply With Quote
Old 02-04-2012, 09:10 PM   #4
SledMan
SledMan's Avatar
There are alot of reasons posted on here, but the real reason is because Cat admitted to having a supply of defective crankshafts. Ynot explained this sometime ago. Particularly the 5EK and 6TS series. I had one of each to break at the #1 journal. Both had less than 800K miles.
I had a Cat service bulletin at one point explaining this. I'll try to find it and post.
2005 250 Super Duty Crew. White and Grey. ARP studs, EGR Delete, and SCT from Vivian. CCV re-route, and 4" Magnaflow turbo back.
Other trucks:1980 KW Ext hood, 1982 Kenworth Cabover Aerodyne (BJ and the Bear) 2000 and 2003 Kenworth W900's. 2003 Pete EXHD. All Caterpillar Power. My 2003 has an MBN I converted to 6NZ. Early 550 file, 211-3025 squirts. 800 cam. Acert twins via custom mount. ARP head bolts.
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
SledMan is offline   Reply With Quote
Old 02-05-2012, 03:30 PM   #5
Red Diesel
O'Skool Member
Red Diesel's Avatar
Wasn't that the PO'ed union worker's sabotage with the casting mix?
My Ride Album
Red Diesel is offline   Reply With Quote
Old 02-05-2012, 05:08 PM   #6
Johnp3
Yea right and the metallurgical guys were involved the machinists and the guys that do the testing the engineers that designed it, the truck driver that took it to the assembly plant and the machine that put it together. Everyone was to blame and the Management got a performance bonus. Those dam workers are destroying the economy.
Did I hit all the Frank Luntz hot buttons.
Old 02-06-2012, 10:02 PM   #7
SmokinCAT
SmokinCAT's Avatar
I do think there was a point and time that they went through the metal not having the proper makeup, I believe it carried over to the cams as well causing them to wipe out lobes. Not sure if it was the workers or not though.
John, where do you come up with these ramblings, a fault with the metal makes sense as opposed to anything that you posted, there could have very easily been something left out of the metal production process.
Cody.
79 KW W900A 3406B, Holset HC5 turbo, RTO12513,
4.11 SQHP rockwells
79 KW K100C 400BC1, Holset HT4B hybrid, custom
injectors, RTO12513, 4.33 eaton DS380s
00 Freightliner Classic XL C15
83 KW K100C 400BC3
SmokinCAT is offline   Reply With Quote
Old 02-06-2012, 11:22 PM   #8
Johnp3
It just gets a little stale when it is always a union member, that cased the problem the Cam problem went on for years, I only saw one crank broken and that was from the belts. These defective cranks were was it they broke?
The cams were not a strong point for the B or C let alone the "E".
The rollers failed, the rocker arms bent, studs st reached, was that all someone else's fault?
Every batch coming out of the pot in a foundry, there is a sample taken for testing. someone with a lot higher pay grade than a union member has to OK every batch.
We all know it could not be CAT trying something different.
I was working at and engine dealership when Detroit had a huge batch of defective Cranks there was not talk about a conspiracy they recalled thousands of engines and replaced them with new one's. Thousands of engines because a key way was cut into the nose cone fillet.
What did Cat do? I never heard of a recall, what was the number?
I did a lot of Cat work and always went on line looking for any recalls according to serial number. If it was not done by the service writer.
Old 02-10-2012, 03:40 AM   #9
CumminsISXpower
CumminsISXpower's Avatar
Wasnt just 5EK and 6TS, we had a rash of 7CZ's that broke cranks,some at #1,most at #6,one at thrust. A couple were million mile crankshafts,most of the failures didnt make 750,000
C A T
U F H
M T I
M E S
I R
N
S
CumminsISXpower is offline   Reply With Quote
Old 02-10-2012, 05:43 AM   #10
Mike the Fox
we just did an mbn at work. broke at #6
Mike the Fox is offline   Reply With Quote
Trans update pics from breakage Blk350on20s 2008-2010 6.4L Engine Tuner Forum 10 01-30-2010 01:32 AM
LBZ Crankshaft LBZ GM Parts wanted 0 10-03-2009 11:18 AM
crankshaft 97CumminsTurboDiesel 12 Valve Performance 9 08-18-2009 01:33 AM
400 hp Reliability and Breakage genie144 General Ford Truck and Excursion 32 06-10-2007 12:41 AM
Crankshaft fuzzys69 2003-2007 6.0L Power Stroke 4 01-03-2006 02:08 AM
