3406e power loss - TheDieselGarage.com
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Heavy Duty
Thread Details Posted by zx12guy, this thread has received 5 replies and been viewed 1502 times.
Old 03-21-2012, 12:40 AM   #1
zx12guy
3406e power loss
I currently drive a 99 pete with a 2ws 3406e @ 475hp. The truck was recently converted from a 10spd to a 13spd. After the swap i noticed the truck only makes 21psi opposed to 27-28psi with the 10spd. Also the cruise control no longer works. Does the ecm need to be reflashed?
88 T600,BCIII,13spd,3.42s
totin a dump wagon
99 378, 2ws, 13spd,4.33s
Stick hauler
zx12guy is offline   Reply With Quote
Old 03-21-2012, 01:45 AM   #2
SledMan
SledMan's Avatar
No, the ECM does not need to be re-flashed. There are parameters in the ECM where you can change top gear ratio, -1 and -2 ratio....but I dont think that would cause the power loss. I assume the speedo still works fine? Will the cruise still raise the RPM while parked?
It may be in derate for some unknown reason. Need to check for any fault codes....have someone hook ET to it and make sure all the switches are working...
2005 250 Super Duty Crew. White and Grey. ARP studs, EGR Delete, and SCT from Vivian. CCV re-route, and 4" Magnaflow turbo back.
Other trucks: 1979 Kenworth W900A reg hood, 1980 Ext hood, 1982 Kenworth Cabover Aerodyne (BJ and the Bear) 2000 and 2003 Kenworth W900's. All Caterpillar Power. My 2003 has an MBN I converted to 6NZ. Early 550 file, 211-3026 squirts. 800 cam. Acert twins via custom mount. ARP head bolts. 856 to the tires via Antrim Dyno.. with the tuned file.
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
SledMan is offline   Reply With Quote
Old 03-21-2012, 02:54 AM   #3
zx12guy
Cruise lights up on the dash but doesnt function at all whether at raising rpms parked or running down the road. Speedo works fine.....
totin a dump wagon
Stick hauler
Old 03-21-2012, 03:30 AM   #4
AaronF
Was the speed sensor for the ECM hooked back up?
-Aaron-
2001 Volvo VNL 660
AaronF is offline   Reply With Quote
Old 03-21-2012, 02:36 PM   #5
379Longhood
379Longhood's Avatar
Make sure that the clutch switch is closing, that would effect the cruise , both parked and at speed. don't know if it would effect power, but it might cause a derate
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline   Reply With Quote
Old 03-22-2012, 12:06 AM   #6
SledMan
SledMan's Avatar
3406E More Power weese3 Heavy Duty 7 11-07-2010 05:03 PM
loss of power wskeith 1994-2003 7.3L Power Stroke 4 11-02-2007 03:41 AM
loss of power? AUSSIEDAVE 1994-2003 7.3L Power Stroke 23 10-20-2007 02:52 AM
7.3 loss of power Robts 1994-2003 7.3L Power Stroke 2 10-29-2006 06:18 AM
05 SCT loss of power? aald4x4 2003-2007 6.0L Power Stroke 15 10-21-2006 04:47 PM
