Kenworth T370 A/C Evaporator Freeze Switch - TheDieselGarage.com
Thread Details Posted by Birken Vogt, this thread has received 13 replies and been viewed 6169 times.
Old 04-23-2012, 01:17 PM   #1
Birken Vogt
Fire App. Mech.
I have a 2009 T370. It has had an intermittent A/C problem since new. Dealer has been no help other than changing some parts, including TXV, some at their expense, some at ours. After going round and round with this, I have come to the conclusion that there must be a freeze up switch in the evap that is intermittent or failed closed, causing the AC to run good for a while and then ice up.
Can anybody tell me the parts I need to get, and how to get in there to fix it? It doesn't look easy or fun but it has got to be done now that it is heating up.
For the last year or so I have kludged it by installing a 1996 Ford truck CCOT type low pressure switch in place of the factory one to keep evaporator pressure a bit higher so it doesn't ice, hopefully, but it is not a 100% solution. It still ices eventually and capacity is reduced.
Thanks
Birken
Birken Vogt is offline   Reply With Quote
Old 04-23-2012, 05:12 PM   #2
twister
twister's Avatar
I'm not an expert but this is what I would do. Check the amount of charge; is there a sight glass? There should be no bubbles after a few minutes of running. If no sight glass, check with guages.
Does the thermostat cycle the compressor on and off?
Is there a air filter that may be clogged?
If all this is correct, then changing or adjusting the thermosat expansion valve like you did should have solved the problem.
twister is offline   Reply With Quote
Old 04-23-2012, 11:42 PM   #3
RachelJeanWalker
RachelJeanWalker's Avatar
Birken normaly when the AC system is over charged it will freeze up. Like Twister said check with guages to see it your system is at the parameters needed. R-12 should have no bubbles but 134 is different and may have bubbles. If all else fails evacuate the system make sure it holds a vacuum and try recharging sometimes moisture will be in the line and this could also cause it to freeze up. Hope this helps.
RachelJeanWalker is offline   Reply With Quote
Old 04-24-2012, 12:22 AM   #4
bmoeller
bmoeller's Avatar
Any time the A/C system is opened up for repairs, the receiver/dryer MUST be replaced.
"Obama = Hoax and Chains"
Old 04-24-2012, 02:38 AM   #5
Birken Vogt
Fire App. Mech.
This truck has done this from day one. Everything has been changed, checked, and reverified, except this switch.
Here is what happens. You start running the system and all is well. Air is cold and everything. After an hour or two the air flow is getting restricted (icing up) and eventually the heat transfer to the evaporator is no longer enough to keep the pressure up and the low pressure cutoff switch cuts off the compressor. Large quantities of water drain out. It gets real warm because the low pressure switch has a wide operation band and the TXV is of the type that does not let any through when the compressor is not running.
Well after half an hour or more the low side will rise enough that the switch will allow it to cut back in and it starts to working for some time before it freezes again. Meanwhile it gets to be like a muggy swamp in the cab, or when it happens in winter, it fogs all the windows so bad it is a hazard to vision.
I have worked around it by replacing the factory low pressure switch with a Ford cycling clutch type from a mid 90s truck but it is not a very good solution because that is for a flooded type evaporator with a suction accumulator and it keeps this evaporator too warm for very good cooling on hotter days.
What I really need to know is how to get at the evaporator temperature switch on this unit. It is not apparent at all. Do I go from the cab or engine side? Does anybody have a part number or wire numbers for it?
And sometimes it does work on its own, but only when it feels like it. I recall seeing some sort of a recall on this issue for a T2000 but I don't know if it applies here.
Thanks
Birken
Old 04-24-2012, 03:59 AM   #6
twister
twister's Avatar
Thanks
Birken
I'm thinking that RachelJeanWalker had a good suggestion. It might be overcharged. When the pressure gets too high, a high pressure switch cuts off the compressor. Is the water drain open? The temperature switch should be on the evaporator, but I don't know how your truck is built. I'm guessing that it in the cab. The ones that I have seen have a bulb and a capillary tube to the switch. If you turn the temperature down low, does the compressor cycle on and off? Like I said I'm not an expert. My advice is worth what you paid for it. ha
Old 04-25-2012, 01:12 AM   #7
Johnp3
The low preasure switch is not you problem and never has been it only works on original start. If you have a charge in the system it alows the power to the clutch.
the high preasure switch turns on the engine fan to cool the condenser.
The thermatic switch is in the evaporator core, it shuts the power off to the low preasure switch/clutch.
Be sure the drain tube for the evaporator is clear.
Put the system back as it was and take it to a different dealer, if you do not get any satisfaction there call the Kenworth regional representative.
Do not yell, just explain the situation. It sounds like the thermatic switch is stuck on.
1988 ford van fresh overhaul, 1991 nissan pick-up 1993 Caprice 2000 GMC S10 Blaser 2007 nbs 3500 GMC 4x4 crew-cab long box 17 inch single wheels Duramax Alison. BW turnover Ball. Furakawa FL35 loader. Retired, HD mechanic, worked on engines all my life. Fabricator welder. electrician. in the process of finishing my new shop. Live in Rock Creek B.C. Wife has a fruit stand.
Johnp3 is offline   Reply With Quote
Old 04-25-2012, 05:03 AM   #8
Birken Vogt
Fire App. Mech.
Yes, the only reason I changed it to the Ford style is so that I could use it to keep a higher pressure inside the evaporator and thereby limit the condensing temperature above the freezing point, since it is easily adjustable. It does not cool nearly as good as it does when it is hooked up properly but at least it does not freeze up (as fast anyway).
Right, it is working fine and head pressures are right where they should be.
You should see the water it pours out when it is pretty well iced up, and you cut the AC power off and let warm air melt it all off.[/quote]
I'd love to but taking anything to the closest dealer is 3/4 of a day for two men. It would probably be a hotel stay for any other dealer. Besides at this point it is so far out of warranty I doubt it would ever be worth it. Nothing would be covered.
The other trouble with this place is, not only will they not fix anything right much of the time, they don't have the time to send over any info on how to fix it yourself either. That is why I am hoping somebody can help me with how to get at the evaporator switch.
Thanks
Birken
Old 04-25-2012, 05:09 PM   #9
Johnp3
I worked at Freightliner, but it seems to me if you call KW and ask they should be able to get you a thermatic switch. Freightliner produces a book that has the cross over numbers I have one but only covers up to 99 KW. Maybe you can google alliance and see if it comes up their.
You talk about adjusting the preasure switch to keep the preasure higher to keep the temperature in the evaporator from freezing, the condenser is the core in front of the rad, the hot one.
Many systems you can not run them on MAX, that is only to bring the temperature down, not to be used continually.
The system is engineered to run at certain parameters if you start boosting pressures, you will have failures and warranty will not cover it.
You may want to get KW to get a number for you from the manufacturer that builds their system and you talk to them.
If you are expecting to get the efficiency that the old R12 systems had being able to cool the cab to the 50F forget it, systems are made to cool the cab 10 to 20F, below outside temps a Maximum, that is so the driver does not get pneumonia, and for fuel economy.
Just a thought!
Old 04-26-2012, 03:24 AM   #10
Birken Vogt
Fire App. Mech.
I guess what I wrote was confusing.
What I did was to replace the low pressure cutoff switch temporarily with a Ford adjustable one. The evaporator pressure with this system runs about 12 pounds. This will cause it to freeze with the freeze switch not functioning. The original switch like you said is just to prevent the compressor from running when there is no charge in the system. The Ford switch cuts off the compressor at about 35-40 pounds instead. This keeps the surface temperatures above freezing at all times. However it also limits the total system capacity so that when it gets hot out, it does not cool well at all. So that is why I need to fix it right.
Birken
new T370 exaust mods?? Matt_cov40 Medium and Heavy Duty 0 01-15-2012 12:50 PM
Kenworth A/C High Pressure Switch rckhauler Medium and Heavy Duty 5 12-17-2011 09:29 PM
08 Kenworth T370 PX-8 Crankcase Pressure Codes AGAIN Birken Vogt Medium and Heavy Duty 3 10-14-2010 02:52 PM
KW T370/PX8 Getting Engine Codes (Crankcase Filter?) Birken Vogt Medium and Heavy Duty 11 02-09-2010 01:11 PM
Evaporator Coil Help AGGIE00 General Dodge Discussion 1 09-15-2009 03:41 AM
