headlights - TheDieselGarage.com
Home Forum Who's Online Today's Posts Vendors Advertise Insurance Auto Loans
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Heavy Duty
Thread Details Posted by carco21, this thread has received 14 replies and been viewed 1335 times.
Old 06-06-2012, 04:44 PM   #1
carco21
headlights
Peterbilt w/9004 bulbs, just not very much light even w/ clear/clean lens.
What would be a good legal replacement for brighter light/better night visibility?? HID system?? Is HID legal on commercial trucks? Will HID brightness irriatate oncoming drivers due to increased height of headlights on class 8 tractors.
Is there a brighter optional 9004 bulb not going HID.
thanks.
carco21 is offline   Reply With Quote
Old 06-12-2012, 05:05 PM   #2
CatHouseMouse
CatHouseMouse's Avatar
The one thing you can do that is perfectly legal is to make sure that the headlights are getting full voltage. Check the voltage reading at the alternator with engine running then check it at the headlights. ANY difference is lost lighting. Also check the grounds.
If you find a difference you can either build a relay system to feed them from the alternator or there are several for sale commercially.
Did this to my 379 and made a huge difference, even with single headlights. Mike
CatHouseMouse is offline   Reply With Quote
Old 06-14-2012, 12:56 AM   #3
carco21
Thanks Mike, I have not chked the B+ or B- and I know better, will chk tomorrow. Did buff/clean the headlight plastic lens, big improvement in appearance have yet to see improvement, need a night run.
thank you.
Old 06-24-2012, 10:42 PM   #4
nevrenufhp
Super Moderator
nevrenufhp's Avatar
You can get brighter(higher wattage) bulbs for a 9004. OEM is 45w on low. I've seen some run 100w on low and 130 on high. Legality? not very, but it's really not that bright & annoying like an HID. I've bought some from bulbs.com and jc whitney.
Dale
my daily driver:67 F100, 300 4V, 4 spd.
work rigs: 94 IH 4900, DT466(originally 230hp), #0 fuel plate, tighter gov springs, 22* timing
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline   Reply With Quote
Old 06-25-2012, 02:23 AM   #5
justdoug
justdoug's Avatar
HID is pretty high dollar and reliability of aftermarket systems in big rig apps is questionable. I would stick with halogen and the suggestions above. IMHO,annoyance to other drivers has more to do with proper adjustment than intensity.
-Doug
justdoug is offline   Reply With Quote
Old 06-25-2012, 10:11 AM   #6
chunkchange
chunkchange's Avatar
HID
800 bucks for LEGAL HID kit. Replaces all wireing, so no problem anymore with a overheated headlight switch.
Lights are very directional, its wild how they control the beam.
Pull up behind a pickup and you can see a dark line , keeping the light on the road, never blinding oncoming traffic.
chunkchange is offline   Reply With Quote
Old 06-25-2012, 12:45 PM   #7
justdoug
justdoug's Avatar
....till something knocks them out of adjustment-even just a tiny bit,then it's like a laser reflecting from my mirror into my retina
-Doug
The Following User Says Thank You to justdoug For this addition to TDG:
black_dog106 (06-25-2012)
Old 06-25-2012, 06:03 PM   #8
378Pete
378Pete's Avatar
Aaaaaaaaaaaaaaaand how....!!
378Pete is offline   Reply With Quote
Old 06-25-2012, 08:29 PM   #9
chunkchange
HID
Let me inform you it would take quite a bit to knock the kit I have out of adjustment.
As it is they have been in for 4 years , running 15,000 lbs on a 20,000 steer axle in a COE.
Old 06-25-2012, 11:49 PM   #10
SmokinCAT
SmokinCAT's Avatar
You could look into the hella sealed beam conversion kit.
Cody.
79 KW W900A 1693TA in progress
79 KW K100C 400BC1
00 Freightliner Classic XL C15
83 KW K100C 400BC3
SmokinCAT is online now   Reply With Quote
05 Headlights into an 04 Fire59Rescue General Ford Truck and Excursion 4 08-01-2009 10:50 PM
APC headlights plainredtruck Whats Been Sold 8 04-05-2008 06:17 PM
H13 HID headlights $DIESEL Whats Been Sold 25 05-07-2007 12:52 AM
How? headlights out! cdiesel General Ford Truck and Excursion 11 04-11-2007 06:25 AM
Headlights on '05 and up One Fast Harley 2003-2007 6.0L Power Stroke 2 01-27-2007 07:32 AM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
