Alternator Running Hot - TheDieselGarage.com
Home Forum Who's Online Today's Posts Vendors Advertise Insurance Auto Loans
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 5.9L Cummins (1998.5-2002)
Thread Details Posted by CanfieldOO7, this thread has received 2 replies and been viewed 875 times.
Old 06-09-2012, 04:09 AM   #1
CanfieldOO7
Dirtbag
Swapped an alternator for a 98.5-02 Dodge 2500 Cummins into a 95 Dodge 2500 Cummins. The only difference i can see on the backside of the alternator is that instead of the 2 wires that plug into the 98.5-02 the 94-98 has one that bolts on. Ive got it hooked up by splicing the wires from a Weatherpack and wrapping them around the terminals from the original harness on the truck. Its charging to ~14V just fine, however the alternator gets hot to the point that its safer to touch the exhaust manifold after a few minutes. Its a brand new 200A unit from Geno's Garage. My old unit had something rattling around inside it and it had ~200k miles on it so i wasnt thinking it was the PCM/ECM. What could be causing this excessive heat?
My Rig: Midnight Blue '95 Ram 2500 12v, Long Bed Ext Cab, 5 Speed Manual 4x4. BHAF Straight Piped. Pump Untouched
198k miles
The Wifes Rig: Montego Blue '97 Ram 2500 12v, Long Bed Ext Cab, 47RE Auto. 4" Downpipe, AFC Screw tweaked a bit, Plate Full Forward.
177k miles
CanfieldOO7 is offline   Reply With Quote
Old 06-15-2012, 06:52 PM   #2
neeltburn
ADMIN/MAFIA
neeltburn's Avatar
Over Charging. incorrect wire size. Faulty alternator from the beginning.
Why go with one from a 24v and get one for a 12v? The best advice I can give you is to get an alternator for a 12 valave from someone like NAPA and try that, I would guess your problem will go away.
When written in Chinese, the word "crisis" is composed of two characters. One represents danger and the other represents opportunity.- John F. Kennedy
2012 Ram 2500 Crew Cab Big Horn
6.7L 68RFE 4wd
Yeah its stock.
Edge Insight CTS / Line-X / Access Bed Cover
B&W Turnover Ball
9-11-2001 NEVER FORGET
neeltburn is offline   Reply With Quote
Old 09-02-2012, 12:30 AM   #3
oldbeek
THe 2 control wires on my Bosch alt 2001 are just in and out for the slip rings( rotor load) The max draw is 5 amp. This is typical of all alternators, no matter how they are controlled. You could use an old style Mopar external regulator with this alternator. Don't see where a 12 valve alt would be diffrent. Should charge between 13.6 and 14.4 volts. Amperage output that can cause mucho heat should cut back quickly after start unless you have a bad battery.
oldbeek is offline   Reply With Quote
Alternator Running Hot CanfieldOO7 5.9L Cummins 12 Valve (1994-1998.5) 0 06-09-2012 04:08 AM
alternator output / volts while running?????? Stompers 4x4 Inc 7.3L and 6.9 IDI (Pre 1994) 4 02-28-2010 11:24 PM
Need new alternator....help jennamax 2003-2007 6.0L Power Stroke 1 01-19-2010 02:50 PM
DT 466 E (Alternator) ROADWRENCH Heavy Duty 4 08-22-2007 10:14 PM
Alternator bad Diezel Dawg 1994-2003 7.3L Power Stroke 13 06-16-2007 04:05 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
