Non adjustable wheel bearing assembly - TheDieselGarage.com
Home Forum Who's Online Today's Posts Vendors Advertise Insurance Auto Loans
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Heavy Duty
Thread Details Posted by AaronF, this thread has received 3 replies and been viewed 457 times.
Old 06-19-2012, 01:46 AM   #1
AaronF
I beleive that the assembly is a Conmet (atleast the drums are), but it is the wheel bearing assembly that has the sleave between the inner and outer wheel bearing.
According to a Conmet page I found, the spindle nut needs to be torqued to 300 ftlbs and engage the locking tabs. If the tabs won't engage, tighted more until they will.
The locking nut that is on it has 2 locking tabs, oposing one another (6&12, 11&5,10&4, 9&3 etc...)
Is this the correct method and torque or has there been any updates with different torque ratings etc...
Aaron - 1986 Ford LTL9000 - 3406 B/C/E
AaronF is offline   Reply With Quote
Old 06-19-2012, 01:53 AM   #2
theakerstwo
Go to the meritor web and check for torques. I think it was around 5 or 600.Its ok if you have to back it off to lock it.
theakerstwo is offline   Reply With Quote
Old 06-20-2012, 01:54 AM   #3
tc2
also note that the specs are only valid using the EXACT correct bearings. if a different brand or whatever bearing is used, you must remove the spacer and treat it like a normal bearing assembly.
here is a link to the service manual :
http://www.conmet.com/pdfs/preset_serv_manual_revb.pdf
tc2 is offline   Reply With Quote
Old 06-20-2012, 08:06 PM   #4
Red Diesel
O'Skool Member
Red Diesel's Avatar
http://www.youtube.com/watch?feature...v=wsH0qz54vSk#!
Right about 2:58 they mention the OEM preset sleeve and leave it out and use dial indicator to set play like regular bearings.
My Ride Album
Red Diesel is offline   Reply With Quote
Wheel bearing? MART5.9 5.9L Cummins (2003-2007.5) 27 07-28-2010 09:14 PM
wheel bearing Buckshot341 1994-2003 7.3L Power Stroke 3 06-21-2009 10:39 PM
Wheel bearing? bigdiesel502 1994-2003 7.3L Power Stroke 25 07-03-2006 04:39 PM
my front bearing assembly is shot what did yall pay for one jponder 5.9L Cummins (1998.5-2002) 10 04-19-2006 02:30 AM
Wheel Bearing imported_CWAGO 5.9L Cummins (2003-2007.5) 11 03-08-2006 01:20 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
