Cummins ISM Low Power - TheDieselGarage.com
Home Forum Who's Online Today's Posts Vendors Advertise Insurance Auto Loans
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Heavy Duty
Thread Details Posted by mathura, this thread has received 6 replies and been viewed 1037 times.
Old 06-19-2012, 11:35 AM   #1
mathura
mathura's Avatar
Engine in Foden Truck and the driver is complaining of low power and slow pickup when accelerating. Engine smoking black when under load and fuel consumption has increased.
Insite scan has shown no active or inactive fault codes, checked the turbo and after cooler lines and found nothing unusual, new air and fuel filters but no improvement. Did a top set but same results.
What I noticed before changing air filter is that it was black as though exhaust soot is being sucked into filter but no leaks was found on the exhaust.The driver told me that he has to change his air filter reguarly because the filter is always clogged with exhaust soot.
What am I missing here
mathura is offline   Reply With Quote
Old 06-20-2012, 12:19 AM   #2
manasteel
what is the esn?
manasteel is offline   Reply With Quote
Old 06-20-2012, 01:48 AM   #3
bmoeller
bmoeller's Avatar
Is the air intake close to the exhaust stack? If it is, then one of them needs to be moved.
"Obama = Hoax and Chains"
Old 06-20-2012, 04:20 PM   #4
Johnp3
Pressure test the CAC and intake!
What I do is remove the pipe from the turbo and pressurize the system into the engine look for leaking at the intake area, see if there is a lot of preasure from the CC-vent. Then isolate and test the CAC to 35 lbs for 15 seconds it should not loose more than 4 lbs.
1988 ford van fresh overhaul, 1991 nissan pick-up 1993 Caprice 2000 GMC S10 Blaser 2007 nbs 3500 GMC 4x4 crew-cab long box 17 inch single wheels Duramax Alison. BW turnover Ball. Furakawa FL35 loader. Retired, HD mechanic, worked on engines all my life. Fabricator welder. electrician. in the process of finishing my new shop. Live in Rock Creek B.C. Wife has a fruit stand.
Johnp3 is offline   Reply With Quote
Old 06-22-2012, 11:33 PM   #5
mathura
mathura's Avatar
The Truck is not availabe at the moment, owner is still moving lumber, will let you know my findings as soon as I work on it. Howver the air filter is not close to exhaust stack
Thanks for your contribution gentlemen
Old 06-25-2012, 05:51 PM   #6
Johnp3
If you have an exhaust leak under the hood can the intake draw in that air.
Old 06-25-2012, 11:03 PM   #7
mathura
mathura's Avatar
Intake is mounted high at the R/S rear of cab so there is no possibility that a leak under the hood can cause the intake to suck the exhaust gas.
The exhaust stack is under the left side of the truck
cummins 8.3 more power brent8604 Utility & Farm Tractors 3 11-14-2009 02:25 AM
cummins=no power beerman0504 Heavy Duty 5 09-09-2009 01:06 AM
more power from 06 F650 w/cummins honda_guy4 Medium Duty 4 01-29-2009 08:53 AM
Cummins power baby! Rainman 5.9L Cummins (2003-2007.5) 12 12-11-2007 08:43 PM
Cummins Power hcr400ex The Parking Lot 0 04-28-2006 02:55 AM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
