Aftermarket ac help - TheDieselGarage.com
Home Forum Who's Online Today's Posts Vendors Advertise Insurance Auto Loans
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Heavy Duty
Thread Details Posted by cdwood388, this thread has received 3 replies and been viewed 470 times.
Old 06-20-2012, 03:41 AM   #1
cdwood388
Aftermarket ac help
I just purchased an aftermarket A/C kit and need a little help. I got the condensor mounted, the drier mounted along with the compressor and the floor mount unit in between the seat. Heres where I need a bit if help. I run the large line from the low side of the compressor to the large port on the unit in the cab. The smaller line from the condensor to the drier then into the small port on the unit in the cab. Then the smaller line on the compressor to the other side of the condensor, pretty sure thats right. Ok heres my dilemma, I have three wires out of the unit in the cab, black, red and white. Guessing black is ground, red is 12v hot and white is what activaties the compressor, correct me if I am wrong. Then the compressor has a red and black guessing red is for 12v from the unit and black is ground. I have a binary switch I need to mount in the high side of the system I think. What do I wire this Binary switch to? Inline with the power to the compressor or what? I also did not get a fitting in the kit that has a place for the binary switch. It is a female thread so I guess i will have to buy some sort of fitting to go in the hose somewhere. There are absolutely no instructions with the kit which I think is BS.
cdwood388 is offline   Reply With Quote
Old 06-20-2012, 12:46 PM   #2
bmoeller
bmoeller's Avatar
What brand is it? Do they have a website, to look at a schematic?
Black or white tends to be used for ground. Black or red can be for power supply. Not sure how they want it though.
Should be 2 switches. One for high and low pressure. You want those in line with the power supply wire to the compressor. That way when either switch opens, the compressor will shut off.
"Obama = Hoax and Chains"
Old 06-20-2012, 01:06 PM   #3
cdwood388
It is a red dot unit and there is no schematic I could find on their website. I just need to make sure te wiring is right.
Old 06-21-2012, 12:43 AM   #4
bmoeller
bmoeller's Avatar
Don't know what model you have, but check this out. Has schematics and plumbing diagrams for several of them. -
http://www.coldairfast.com/RedDot/Ecat/Backwalls.pdf
all I did was a web search. red dot a/c unit wiring diagram
aftermarket cam?? foxygoliath GM Performance Forum 5 02-16-2010 07:18 AM
MY NEW 6.4L with Aftermarket Exhaust BeauxPete 2008-2010 6.4L Power Stroke 59 10-16-2007 03:19 PM
Aftermarket tach estay 7.3L and 6.9 IDI (Pre 1994) 2 09-18-2007 02:25 AM
aftermarket cam??? Orangepstroke 1994-2003 7.3L Power Stroke 43 05-31-2007 10:16 PM
Aftermarket CumminsPower 5.9L Cummins (2003-2007.5) 2 06-12-2006 12:24 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
