Cutting out while towing - TheDieselGarage.com
Home Forum Who's Online Today's Posts Vendors Advertise Insurance Auto Loans
Thread Details Posted by flycut, this thread has received 5 replies and been viewed 1061 times.
Old 06-29-2012, 01:42 AM   #1
flycut
Hi Well I'm on vaca pulled 150 miles no trouble ran 70-75 mph then truck sputtered and cut in and out . My scan gage shows icp at 600 when idling and ipr shows 21 at idle temps on oil and water are good . My fuel filter has about 2000mi on it I have owned truck since new and always used 5w40 changed at 5000 mi . It has about 600 mi on this oil chg . The thing I find wierd is after I got off the hiway it seemed fine and I put about 300mi on it with out trailer and it runs great Also I get no cel or codes. My truck is 2005 stock except egr up pipe has been replaced with one from rcd and egr is unplugged also I replaced the turbo about 5000mi ago with a new not reman turbo . So what do u think injectors going or is there something else I should check. O I almost forgot I had my ficm repaired 2months ago and it's reads 48v Thanks for any help
flycut is offline   Reply With Quote
Old 06-29-2012, 11:51 AM   #2
harry6.0
harry6.0's Avatar
What were the oil/water temps while towing? Could be an injector starting to malfunction, not really sure of the cut in/out symptom your describing. Does it stall completely, or just bucking/jerking? Could also be a intake leak and under higher boost levels while towing it shows up. Check all your cold air tube intake boots for leaks.
Harry
Jan 03' built 6.0/F250cc4wd trqsft/SCT-tuned by KEM-Performance/Garrett Powermax vg-turbo/blue spring mod/gauges=egt+boost+fuel+SG2/exhaust/airaid intake/DR 4.5 lift/dual bilsteins/315's/greasable ball joints/powerstop/smittybuilt/kc lights/high idle mod/roll-n-lock/T5-Rotella 10w30 with (Archoil AR9100 in the oil) and (AR6200 in the fuel)http://www.archoilspokane.com/
harry6.0 is offline   Reply With Quote
Old 06-29-2012, 01:18 PM   #3
flycut
You could call it bucking it does not stall just sputters I'll look at the towing temps today when I pull home. On the intake thing Ck at the heads or the cac pipes. Also if I have a injector going would I get a code? Thanks Harry
Old 06-29-2012, 11:02 PM   #4
thartman
I just worked on a guys truck that had some of the same issues. When I would turn the key on not all the injectors were cycleing. (no codes present) I replaced the defected injectors and has been fine since. Are you haveing any starting issues hot or cold?
thartman is offline   Reply With Quote
Old 06-30-2012, 06:09 AM   #5
flycut
Well it sputtered home I tore into it and found the front plug on the ficm was falling out. The inside clip toward turbo broke I zip tied it in runs good now But that brings my next question where is the best place to get a new harness also it looked like the connector was arcing and burnt two pin holes and about a 1/8 inch off 1pin on ficm I'm worried about the ficm pin Also do u replace intire harness or just pigtail to ficm. Thanks for the replys So much preventive maintenance and something small like a plastic clip can cause so much trouble
The Following User Says Thank You to flycut For this addition to TDG:
harry6.0 (06-30-2012)
Old 06-30-2012, 01:48 PM   #6
harry6.0
harry6.0's Avatar
You can purchase a replacement/repair connector separately, like the ones here...
http://www.shopdieselspecialists.com/category-s/121.htm
or and entire engine harness from Ford for around 600.00 is what I've seen them going for. Or go to a salvage yard and cut off the connector you need, and purchase some good solder melt type electrical connectors like these...
http://www.calcentron.com/Pages/elek...onnectors.html
(these work great and you only need a hot air gun to melt the solder..we use these at my work all the time). As far as the Ficm pin damage, I would contact one of the places that rebuilds them like,
http://ficmrepair.com/
they may have a solution to save you money from spare parts that they have.
Harry
The Following User Says Thank You to harry6.0 For this addition to TDG:
MT Pockets (06-30-2012)
?Why is it cutting off? jonesy 1994-2003 7.3L Power Stroke 22 04-16-2012 05:19 AM
6.0 cutting out Levi'sford 2003-2007 6.0L Power Stroke 4 12-14-2010 02:53 AM
Cutting out at 2k rpm... fordzilla502 2003-2007 6.0L Power Stroke 19 07-02-2010 10:12 PM
Cutting tires 01duramax6spd The Parking Lot 18 02-17-2008 03:53 PM
Cutting out EverydayStroker 1994-2003 7.3L Power Stroke 6 12-20-2007 05:39 AM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
