Cat intercooler leak - TheDieselGarage.com
Go Back   TheDieselGarage.com > Heavy, Medium, Work Trucks and Trailers > Heavy Duty
Thread Details Posted by claymore1500, this thread has received 8 replies and been viewed 3559 times.
Old 08-29-2012, 02:01 AM   #1
claymore1500
claymore1500's Avatar
One of the Peterbilt trucks in the fleet that I am in charge of keeping on the road seems to be having a problem with inter coolers, the original one started leaking about three weeks ago, I replaced that one and the truck made ONE trip.
When it got back I checked the cooler and found it leaking again, We sent it to a local Kenworth dealer, to have some injector work done, and they replaced the cooler again, now, about one week later it has started leaking again.
What I am looking for is ANY ideas as to what may be causing this.
Thanks in advance. Tom.
claymore1500 is offline   Reply With Quote
Old 08-29-2012, 02:35 AM   #2
SledMan
SledMan's Avatar
Either it's overboosting (doubtful), or the radiator frame is twisted. I have seen KW's twisted and I had to shim the mounts so the bolts wouldnt draw it together and crack the solder joints.
2005 250 Super Duty Crew. White and Grey. ARP studs, EGR Delete, and SCT from Vivian. CCV re-route, and 4" Magnaflow turbo back.
Other trucks: 1979 Kenworth W900A reg hood, 1980 Ext hood, 1982 Kenworth Cabover Aerodyne (BJ and the Bear) 2000 and 2003 Kenworth W900's. All Caterpillar Power. My 2003 has an MBN I converted to 6NZ. Early 550 file, 211-3026 squirts. 800 cam. Acert twins via custom mount. ARP head bolts. 856 to the tires via Antrim Dyno.. with the tuned file.
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
SledMan is offline   Reply With Quote
Old 08-29-2012, 02:36 AM   #3
379Longhood
379Longhood's Avatar
Poor workmanship either on the part of the cooler mfg of the guys that installed it, if the cooler isn't mounted right or the mount points are damaged it could cause problems, but the shop that installed it should check that kind of thing to avoid warranty hasssles.
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline   Reply With Quote
Old 08-29-2012, 10:51 AM   #4
claymore1500
Maybe I should have specified, This is the "Cat" part, it mounts on the engine between the turbo and the water pump.
Also: Cat, put the first one on when the engine was built, I installed the second one, and the third one was put on by a Kenworth dealer, so it seems unlikely that the installer is at fault.
Old 08-29-2012, 11:58 AM   #5
SmokinCAT
SmokinCAT's Avatar
If you would have specified what engine that would have helped, and that is actually a pre cooler to drop IAT to a reasonable level before it enters the air to air. Must be an ACERT, which that being said you don't hear of those leaking too often, where is the leak?
Cody.
79 KW W900A 3406B
79 KW K100C 400BC1
00 Freightliner Classic XL C15
83 KW K100C 400BC3
SmokinCAT is offline   Reply With Quote
Old 08-29-2012, 11:10 PM   #6
claymore1500
Please, forgive my lack of useable info, I started the thread at 1 AM, and I was half asleep,
That being said, It is in fact a C-13 acert, The part in question is the pre cooler and the leak is internal, meaning the coolant is going thru the air intake right into the engine, there is coolant trails from all of the turbo hose connections on both sides of the air charge cooler.
And like I said in the OP, this will be the forth one on the engine in about a month.
Old 08-30-2012, 11:12 AM   #7
C15
C15's Avatar
precooler bypass valve is not letting coolant flow through,which causes the precooler to overheat ,creating the crack.the bypass valve is the thing that bolts to the side with the solenoid in it.replace that whole unit and it should solve the problem.good luck
C15 is offline   Reply With Quote
The Following User Says Thank You to C15 For this addition to TDG:
claymore1500 (09-07-2012)
Old 08-30-2012, 11:26 PM   #8
claymore1500
Thank you, I believe the boss took the truck back to the Kenworth dealer where the last cooler was put on, I will check it when it get's back.
Old 09-07-2012, 01:13 AM   #9
claymore1500
Good call, We had Kenworth check the valve, and they said that it was not working.
Thank you
OK fuel leak stopped now oil leak Stacked6600 1994-2003 7.3L Power Stroke 7 01-27-2011 04:37 AM
intercooler ?;s Sabbath5.9 5.9L Cummins 12 Valve (1994-1998.5) 15 03-03-2010 06:11 AM
bank intercooler piping(with a stock style intercooler) install question Jjona5 1994-2003 7.3L Chips & Tuners Forum 1 09-13-2009 01:46 PM
intercooler ?s zpd307 7.3L and 6.9 IDI (Pre 1994) 2 04-09-2008 06:07 AM
Oil Leak Or Boost Pressure Leak At Hot Side Charge Air Cooler (cac) Duct PSDPlayer 2003-2007 6.0L Power Stroke 2 01-12-2007 05:17 AM
