fuel oil filter housing leak at regulator - TheDieselGarage.com
Home Forum Who's Online Today's Posts Vendors Advertise Insurance Auto Loans
Thread Details Posted by ranger518, this thread has received 2 replies and been viewed 1084 times.
Old 09-11-2012, 02:12 PM   #1
ranger518
ranger518's Avatar
got a 2003 f550 that has a leak coming out of the fuel pressure rugulator so i got and installed the blue spring kit and put it on with the new front cover and o rings and it still leaks around the new front cover and the fuel filter housing has anybody had this issue could it have a small crack causing it to leak? thanks
I think it is great that Cummings service trucks are f-550 with 6.0 and 6.4. They must know somthing?
2006 F-250 lariat FX4
4" turbo back MBRP stainless steel exhaust cat delete
Airaide intake
Homemade coolant filter
Custom oil bypass filter
Quad pillar gauges EOT, ECT, Fuel pressure, and EGT
RCD EGR kit with new up pipe
Blue Ford fuel spring went form 45psi to 68psi part number 3C3Z-9T517-AG
Rancho Rs9000 shocks with my ride controll
Homemade 3" lift
315x70x17 BFG AT's
SCT With custom Innovative tunes
Mobil ELC Cat-1 Coolant
2004 Turbo
Zoodad mod
ranger518 is offline   Reply With Quote
Old 09-12-2012, 03:37 AM   #2
harry6.0
harry6.0's Avatar
What are the fuel pressures readings? If no obvious reason on the surfaces are detectable, like a crack or porous casting on the housing, then possibly excessive pressure could be building in the system, like from aeration due to combustion gasses entering the fuel supply system through a bad injector seal. Heres some info that may or may not be helpful.
http://alliantpower.com/sites/allian...b_06-08_en.pdf
Harry
Jan 03' built 6.0/F250cc4wd trqsft/SCT-tuned by KEM-Performance/Garrett Powermax vg-turbo/blue spring mod/gauges=egt+boost+fuel+SG2/exhaust/airaid intake/DR 4.5 lift/dual bilsteins/315's/greasable ball joints/powerstop/smittybuilt/kc lights/high idle mod/roll-n-lock/T5-Rotella 10w30 with (Archoil AR9100 in the oil) and (AR6200 in the fuel)http://www.archoilspokane.com/
harry6.0 is offline   Reply With Quote
Old 09-17-2012, 08:00 PM   #3
ranger518
ranger518's Avatar
ok got the new oil fuel filter housing put on today and started up truck and it is still leaking out of the same place. On the old one i could see where it was leaking when i took it apart look like a little dent dont know how that happened other than the fuel leaking through it caused it. guess i need to check out my fuel pressure truck has just had 8 new injectors put in it hop it is not that. any ideas what would cause this
Airaide intake
Homemade 3" lift
315x70x17 BFG AT's
2004 Turbo
Zoodad mod
Newer OBS fuel pump w/regulator & filter bowl for sale $75 preith Ford Parts 0 02-23-2011 07:00 PM
fuel filter housing dragogt 6.5L Diesel Engine 7 02-07-2010 09:56 PM
Fuel Filter Housing MOPSD250 2003-2007 6.0L Power Stroke 8 11-09-2009 01:44 AM
99 24v fuel filter housing? kwswan 5.9L Cummins (1998.5-2002) 13 09-07-2009 01:58 AM
sneak peak on new oil filter housing & fuel filter housing hhrecovery 2003-2007 6.0L Power Stroke 42 02-17-2007 04:39 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
