3406b info - TheDieselGarage.com
Thread Details Posted by CAT_Powered, this thread has received 4 replies and been viewed 1040 times.
Old 01-15-2013, 02:58 AM   #1
CAT_Powered
3406b info
Hi! Im new to the site and have a couple of questions. I have a 86 International 9370 tri-axle dump with a 7FB47122 3406b. The pump is opened up and I have an or6051 turbo on it, runs pretty strong and pulls 36 lbs. of boost. Around 5 yrs ago i made it air to air, did not know i should not of done that until I got on here and started reading threads. My question is do I need to have it meter timed or any changes in governer? One other thing, have a round port head on it and would I gain much by putting square port on? Any info would be greatly appreciated. Thanks.
CAT_Powered is offline   Reply With Quote
Old 01-15-2013, 01:01 PM   #2
cowpuncher
If it ain't broke don't fix it. Sounds like you have it pretty well on the top shelf, Tony says the 7fb does pretty well with just pin timing, although meter timing is good if you can find someone to do it. The square port manifold is supposed to flow a little more, but unless your just wanting to spend money I wouldn't worry about it, although with the round port the 36lb. reading your getting you might, I said might be partially a bit of back pressure. If it don't heat, cranks with the bump of the switch, and doesn't drink fuel I'd leave it alone as it sounds like you've done acheived what most everyone is shooting for.
cowpuncher is offline   Reply With Quote
The Following 2 Users Say Thank You to cowpuncher For this addition to TDG:
CAT_Powered (01-16-2013), Oxbow12 (01-18-2013)
Old 01-15-2013, 02:33 PM   #3
SledMan
SledMan's Avatar
Why not go to air to air? That's an easy 30-40hp. Why do you think Cat went to ATAAC in 1987 with the King of the Hill 425? The 425 ATAAC actually had a lower rack setting than the 400 JWAC....proving the efficiency.
Maybe Tony will be along, he'll get you straight.
2005 250 Super Duty Crew. White and Grey. ARP studs, EGR Delete, and SCT from Vivian. CCV re-route, and 4" Magnaflow turbo back.
Other trucks: 1979 Kenworth W900A reg hood, 1980 Ext hood, 1982 Kenworth Cabover Aerodyne (BJ and the Bear) 2000 and 2003 Kenworth W900's. All Caterpillar Power. My 2003 has an MBN I converted to 6NZ. Early 550 file, 211-3026 squirts. 800 cam. Acert twins via custom mount. ARP head bolts. 856 to the tires via Antrim Dyno.. with the tuned file.
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
SledMan is offline   Reply With Quote
The Following 2 Users Say Thank You to SledMan For this addition to TDG:
Old 01-16-2013, 01:34 AM   #4
CAT_Powered
Thanks cowpuncher and SledMan . Have one more ?. I have another 7fb I want to build someday, what do i need to do to get 700hp out of it?
Old 01-16-2013, 02:31 PM   #5
cowpuncher
Do a search for the 7fb or look in the mod section for Tonys post about setting it up, I believe he states about 600+ hp, I think he recommends the OR 6051 turbo in that post which some say will cross to the B/W 199119 which has been changed to B/W178063, but I like the B/W 199114.
3406b info please UncleP Medium and Heavy Duty 26 01-12-2013 01:53 AM
3406b? c-ray32 Medium and Heavy Duty 9 03-07-2011 03:39 AM
A Lil' Info Please 3406b B_QUICK_1 Medium and Heavy Duty 6 12-22-2010 08:40 AM
More 3406B! ar4cuda Medium and Heavy Duty 3 11-24-2010 03:56 AM
3406b allieslow Medium and Heavy Duty 6 07-30-2010 07:33 PM
