DT466E hpop/fuel line torque specs? - TheDieselGarage.com
Thread Details Posted by Xplorer99, this thread has received 3 replies and been viewed 4300 times.
Old 05-03-2013, 08:52 PM   #1
Xplorer99
hey guys... just ordered the ISIS cd, but i just stoped at the IH dealer and picked up new fuel line (1/2" OD plastic air brake line) and new fittings as well as the rubber seal for the front of the HPOP. just wondering if anyone knew the torque specs on those? really nice day out and would like to get those done, but ive never had any luck with those dang compression fittings lol...
thanks alot!
-Jake-
1999 International 4700. DT466E / Spicer 6+1
Xplorer99 is offline   Reply With Quote
Old 05-13-2013, 05:46 AM   #2
nitronick
High Pressure Oil Pump Gear Bolt
129 Nm (95 lb-ft.)
High Pressure Oil Hose Nut
26 Nm (19 lb-ft.)
High Pressure Oil Pump Mounting Bolts
27 Nm (20 lb-ft.)
Injection Control Pressure Sensor (ICP) ( See Note )
26 Nm (19 lb-ft.)
Injection Control Pressure Valve
47 Nm (35 lb-ft.)
Injection Control Pressure Valve Tinnermann Nut
6 Nm (5.5 lb-in.)
Supply Manifold Elbow Fitting ( On Engines Equipped With Engine Mounted ECM Unit )
26 Nm (19 lb-ft.)
Supply Manifold End Plug
81 Nm (60 lb-ft.)
Supply Manifold Mounting Bolts
27 Nm (20 lb-ft.)
Supply Manifold Regulator Valve Assembly
35 Nm (26 lb-ft.)
Fuel Return Valve Banjo Fitting
35 Nm (26 lb-ft.)
Banjo Fuel Line Connections
35 Nm (26 lb-ft.)
nitronick is offline   Reply With Quote
Old 05-13-2013, 05:47 AM   #3
nitronick
35 Nm (26 lb-ft.)
Fuel Filter Header Mounting Bolt
18 Nm (13 lb-ft.)
Injector Hold Down Bolt
13 Nm (120 lb-in.)
35 Nm (26 lb-ft.)
Shoulder Injector Bolt
13 Nm (120 lb-in.)
Old 05-17-2013, 07:55 PM   #4
Xplorer99
thanks alot, i got the isis manual... but apprearently i also need service literature for wiring diagrams and stuff... dumb question tho, do i have a bap/baro sensor? or is it just the map sensor on the intake? its a 99 truck built on june 1st 98. the motor is also a 98.. so ive been in both the 99+ and the 98 and before manual but i cant find the connector behind the dash... thanks!!!
-Jake-
Torque Specs Nolafishr 5.9L Cummins (2003-2007.5) 4 01-30-2010 11:53 AM
torque specs roadrunner 7.3L and 6.9 IDI (Pre 1994) 1 05-26-2009 03:11 PM
Torque Specs rsjohnsn 2003-2007 6.0L Power Stroke 1 03-19-2009 10:57 PM
7.3 hpop specs camojeeper Ford - Modification instructions, Product installs and Tech Articles 1 12-26-2008 03:43 PM
torque specs 4cstr General Ford Truck and Excursion 1 05-18-2006 09:54 PM
