What is the HUTCH Mod - Page 2 - TheDieselGarage.com
Thread Details Posted by Tornsteel, this thread has received 17 replies and been viewed 4718 times.
Old 04-18-2006, 09:33 PM   #11
RSP
Rockin-S
I have never heard of it called the Hutch mod. It has always been called the harpoon mod as far as I know.
97 F350 PSD Crew Cab 4X4 Almost Stock :umno:
79 F250 CTD Super Cab 4X4 Almost Stock
79 F150 Reg Cab 4X4 Whimpy 512 CI BigBlock Some day it will be a CTD too
RSP is offline   Reply With Quote
Old 04-18-2006, 09:36 PM   #12
TheHammer69
some kinda diesel oracle
The "Harpoon" mod is when you cut the vent and/or fill tubes only. The "hutch" is when you perform the mods to the pickup and pre-pump lines.
Hammer
2001 F250 Lariat CC/SB 4x4 7.3 auto TERMINATOR HPOS...Ceramic coated Garrett GTP-38R with BBHA & GDS outlet...DP-tuner F5...ITPdiesel Fueling and overboost regulator...6.0 CAC...AFE Stage-II PG7... Magnaflow 3.5dp/4exh...5R110 TC, BTS VB, John Wood pump mods, & V10 cooler...Schaeffer's 9000 5w-40...Oilguard bypass...and other stuff
2002 Corvette Z06 Parts soon to be installed: American Racing 1.75" "grey Ice" Ceramic coated headers without Cats...CNC ported and hand finished AFR 205 heads milled to 61CC chambers w/ 8019 springs...ported FAST 90/90...Custom Comp LSK lobe Cam 223/227 .637/.639 114+2...And to be tuned by yours truly with HP tuners
1997 Yamaha YZF-1000R
1994 Camaro Z28
Carolina PSD club
TheHammer69 is offline   Reply With Quote
Old 04-18-2006, 10:28 PM   #13
RSP
Rockin-S
OK ya I guess I knew it was the fill and vent tubes But I didnt realize there was a name for the rest of it
Old 04-19-2006, 01:07 AM   #14
imported_diesel71
Make sure you get rid of the qwik fitting on the fuel pump, the sucthion side. this is where i always find them sucking air. alot of nosiey trucks that i have looked at are caused from aerated fuel. fallow the fitting back to the steel line, this is where i cut the factory black plastic off. push on your rubber hose and clamp. I use a clear fuel filter in between the pump and factory steel line.:Thumbup:
imported_diesel71 is offline   Reply With Quote
Old 04-19-2006, 04:03 AM   #15
Tornsteel
Tornsteel's Avatar
Thanks guys this sight is so awesome (especially when you have money to spend). I would really like to do the regulated return as well but need to save up for it.
2006 XLT 6.0, 72,000 miles. First owner. Build date 10/05, CC,LB,3.73LS,SRW,ISSPRO Pyro-Boost-Trans on the APillar,ARP Studs,Stock HG's,ELITE SCT Tadd's Tunes,Sinister SCT,Innovative tunes,EGR delete,4" turbo back dual exhst, zoodad, ccv mod, Coolant bypass filter, Cage leveling kit,upfitter high idle, running Amsoil 3000 with Archoil, 6.4 banjo's, Blue spring, 03 Turbo w/ 03 pedestal.
Issues: Rear main seal at 1'700 mls. EGR valve, EGR cooler and Oil cooler @ about 43k, Stock Head Gaskets @55k, Black Onyx HG's @72k.
http://www.thedieselgarage.com/galle...028_393362.jpg
Sean H
Tornsteel is offline   Reply With Quote
Old 04-19-2006, 01:50 PM   #16
dfuser
Supporting Vendor
I have instruction for the DIY folks on the site under the documentation section. I'll need to add the Pre-pump instructions aswell.
05/2009 F350 2WD CC DUALLY EBONY (Inside/Out) dropped 3/5 on 305/45-22 - dubbed "Cat Woman"
dfuser is offline   Reply With Quote
Old 04-19-2006, 03:00 PM   #17
RacerX
AMERICAN INGENUITY
Originally Posted by QtrHorse
As already stated, there are a few vendors who sell the intank mod kit. ITP is one and Diesel Innovations is another. If you have a couple of friends, you can take the bed off and have it done in 2-3 hours, w/ a few breaks in between (this is w/ you taking your time and not rushing). I highly recommend for you to use some type of cut off wheel (dremel works great) when cutting the factory steel lines and make sure to debur anything you cut. I used ITP's kit and was very pleased w/ the instructions and items that it included. You could also buy his regulated return it w/ it and save a few $$.
I suggest a mini tubing cutter for a straight burr free cut if you have an inch of space all around the line.
The Racer X Built- E4OD THAT CAN -Video. 1997 Ford F-350 7.3 twin turboed PSD. Powered by 473 + cc's of Fuel and Nitrous. TDG members & team: Booner, Fuzzys69, Pipewhiner...Family owned & sponsored by :
DIY-injectors tdg's DZLJIM
American Ingenuity, Half Of American is I CAN.
LC-39A SA-506 SM-107 LM-5 CM-107
Visit us at :Racer X Automotive
RacerX is offline   Reply With Quote
Old 04-19-2006, 04:05 PM   #18
QtrHorse
Internet know it all
That's what I used but it leaves that little pushed in edge all the way around. You will need to reem the tubing after using a roll type cutter. That little ridge that it leaves will cause turbulences and bubbles in the fuel.
99.5 F250 XLT S/C 6SPD
ITP Intank Mods*LUK clutch w/ Kevlar pilot*AFE Stage 1*Red Top Optimas*Fumoto*Reflexxion Cowl Hood
Truck Pic's
For the idiot at large. Unless I actually make a post or put a link in my signature that I have something for sale, I do not.
QtrHorse is offline   Reply With Quote
