What's normal alternator output?? - TheDieselGarage.com
Thread Details Posted by jschall, this thread has received 30 replies and been viewed 1482 times.
Old 06-21-2006, 12:40 AM   #1
jschall
I just completed a decent road trip and did some data loging too pass the time ..and running down the highway at 75mph and approximately 2000rpms my alternator is making between 12.9 and 13.2 volts...is that about right?? Only AC and radio on no lights...
j.schall
2005 F250 4x4 CrewCab
modified Zoodad,fumoto valve, Kermit's coolant filtration system,CCV reroute,upfitter AIC, AFE Stage 2, 4in. MagnaFlow turbo back,Gauges, Schaeffers 9000 oil,SCT Hybrid (Elite & ID),Tadd & Jeff's Stage 3 fuel system w/fuel cooler and DAHL150, Elite(Tadd's) stage 2 injectors, Banks Technicooler,fluidampr,Oil Guard EPS-20 filtration....DOA....
New Truck: 2008 6.4 PSD F250 4x4 CC
MBRP DPF back exhaust, SCT Livewire, AirRaid air intake....more to come hopefully meanwhile the Ninja zx10R provides the excitement.
jschall is offline   Reply With Quote
Old 06-21-2006, 12:43 AM   #2
heinzboy
Banned
Mine is usually right around 13.2 to 14.1 volts depending on what I have on.
heinzboy is offline   Reply With Quote
Old 06-21-2006, 12:53 AM   #3
centennial60
Diesel Enthusiast
centennial60's Avatar
Send a message via Yahoo to centennial60
Seems a little low, normal voltage should be 13.5-14.5. Mines usually runs high 13s at cruising speed with the normal accessories on.
08 F250, CC, SB, FX4, Black, Alpine navi Stock for now
centennial60 is offline   Reply With Quote
Old 06-21-2006, 01:12 AM   #4
John DiMartino
I doubt its your alternator,the field is controlled by the PCM,that is where the problem lies usually.A few plowing guys i know have the twin alts on there new Superdutys,and the trucks die out after an hr of heavy plowing.The alts arent working very hard,by the time the pcm senses the low voltage,and tries to field the alts, its too late,and the truck dies without warning.Ill try to find the thread about it,maybe theres something there that can help you.
2000 Dodge CTD 2500 4x4,Qcab SWB, 4.10 LSD,PDR cam,PDR twins,DonM 6,Edge Drag Comp,RASP fuel system,DTT trans,Blizzard 810,Sidewing plow,Trynex Vp8000,Sunnybrook 3310
John DiMartino is offline   Reply With Quote
Old 06-21-2006, 01:23 AM   #5
jschall
The reason I ask is I can start my truck (dead cold) let it idle maybe 1 minute long enough to get oil pressure up after a change (this is how I know)..and I touched it and it was smoking hot....ie..hotter then the down pipe.....
j.schall
Old 06-21-2006, 01:28 AM   #6
barnbridge
I have my Scanguage programed to display voltage. While the glowplugs are lit it reads about 12 volts then jumps to 13.8 and remains there even with lights and AC on.
~2004 6.0 PSD, XLT, Torqshift, 3.73 LS
~Oilguard bypass filter, coolant filter
~Bodiak front hitch reciever
~ARE cap, Bedrug liner
~Jordan 2020 trailer brake controller
~Zoodad,foglight mod, high idle mod
~EGR cooler delete
~Sirius Satellite Radio
~Edge Insight digital guages
barnbridge is offline   Reply With Quote
Old 06-21-2006, 01:30 AM   #7
imported_diesel71
seems a littel low,you should see 13.5 at that rpm even with everything on. are both your batterys good?
imported_diesel71 is offline   Reply With Quote
Old 06-21-2006, 01:34 AM   #8
jschall
I think so ....(green eyes are green) well D71 I just finished 800 mile trip and dam it all if 30 miles from the house my noise starts again and I thought I had found it cause the one time I herd it at an idle with the aic on it sounded like it was comming from the alternator but the idler lives right under it...so.Know Im thinking....I wish you lived in Texas...O..yea my aic is on charge protect and the last few times I put it on...it jumps right upto 16-1700 rpms with nothing on...I thought it was wierd...
j.schalll
Old 06-21-2006, 01:52 AM   #9
imported_diesel71
your alternator may be on its wat out. most of the trucks with aic will jump to 1150-1200 rpm even when we are jumping a dead truck and putting a good load on it. this may be your noise too. do you have a way to do a load test on the batterys,this will conferm you dont have a bad cell or shorted plate in one of them? i wish i was thier,i like hard to find problems. that is wierd your aic whent that high. if the pcm is trying to keep the amps & volts right but the alternator cant do it,this would make sense why your rpms are so high with charge protect on.
Old 06-21-2006, 02:06 AM   #10
jschall
To change an alternator do you just lock the idler pulley lever thing Im vary familar with now..lol..unbolt it , disconect it..and thats it...???and I have read there is one a bit stronger (high output) ...is that true...??
Thanks D71
j.schall
