LLY Overheating Fix???? - TheDieselGarage.com
Go Back   TheDieselGarage.com > GM Diesel & Truck Discussion > Duramax 2004.5-2005(LLY) > LLY Overheating Discussions and Solutions
Thread Details Posted by gibson2403, this thread has received 20 replies and been viewed 8414 times.
Closed Thread
Old 08-10-2006, 12:53 PM   #1
gibson2403
Smile LLY Overheating Fix????
Guys, Below is a DP post by me. I hope my posting it here is not a violation of protocol, but I thought there might be LLY wizards over here that don't hit DP. Sooo, appreciate your input.
DPers love my LLY, and so far truck has not OH. As I've stated previously, I'm a turn the key and drive guy. But .... Below is an extract from three DP threads which let's assume the 1st two are accurate. My question is whether statement in #3 below is true or NOT. If true, what's it gonna cost me to get this fix?
2005 K2500HD D/A CC SWB, Putnam XDR Class V Hitch, Prodigy BC, EGR Blocker Plate/Finger Stick, Fumoto Valve, GM 2006 CAI
gibson2403 is offline
Old 08-10-2006, 11:22 PM   #2
TheBac
Hmmm.
3) You can either go with the V2, which is an aux radiator, or you can go with the TD-EOC, which is a larger oil cooler. It is made by a Garage Supporting Vendor, killerbee. He also has other items that go along with the cooler to help. Send him a PM, he can explain it all to you.
From all I've read, they both help fix the O/H problem.
TheBac is offline
Old 08-13-2006, 01:34 AM   #3
TheBac
The Garage has no problems whatsoever with links to posts over at the "DP", as long as they are pertanent to the topic being discussed.
But, that being said, you cannot re-post the actual wording of the DP postas that is a violation of their copyright rules. You have to link to it with a URL.
Due to that fact, I was required to delete the posts. Sorry.
TheBac is offline
Old 08-15-2006, 07:02 PM   #4
Ranch55
I don't know what the overheating fix should be, but I have had ideas for several years based on my very long experience factor working on Mega Bucks $$$$ rotating machinery in the petro-chemical industry for the last 35 years. We always looked to maintain the proper temperature of the operating fluids, ie...lubricating oils, hydraulic fluids and coolants.
I decided in my case for my '05 LLY to go after the engine oil and transmission oil.
I have installed a TD-EOC system. It was a very clean and easy installation. No modifications to any of the OEM equipment is what drew me this way.
I have also installed an '06 upgraded transmission cooler. Again, no modifications to OEM equipment, except to exchange OEM '05 trans oil lines with OEM '06 trans line.
I believe that by reducing or eliminating the extra BTU's via the coolers, will enable the stock engine coolant system to do a very effective job. Past experience tells me the coolers will probably help remove heat from the coolant system also.
Previously Owned - 2002 GMC 2500HD D/A, Long Bed, CC, 4x4
2005 GMC 2500HD D/A, Long Bed, CC, 4x4, Mike L '06 Trans Cooler, TD-EOC
1991 GMC 2500HD 7.4L, 4L80E Trans, Long Bed, Ext. Cab, 4x4
Honda Gold Wing - 1984 Aspencade - Original Owner
Ranch55 is offline
Old 08-15-2006, 11:29 PM   #5
RoaDkilL
Ranch55,
What before and after results have you experienced with this combination? :squish
RoaDkilL is offline
Old 08-16-2006, 12:54 AM   #6
idahofox
Originally Posted by RoaDkilL
Ranch55,
:squish , I like that.
Fox
2003 Silverado 2500HD, D/A, LB, EC, 4X4, SE, born 01/03.
idahofox is offline
Old 08-16-2006, 09:12 PM   #7
Ranch55
I haven't done any trailering yet, that's to come Labor Day weekend when I make a trip to the ranch.
Without a trailer, before any coolers, a run to the ranch in Texas heat (378 miles I-10) normal transmission temps were around 200*~210*. This was just with a good load (of feed corn) in the truck of about 2500lbs. Engine coolant temps would stay normal according to the OEM gauge at 210*. But when I opened the hood, it was really hot under there when I got to Uvalde.
Last weekend, after both coolers were installed, Texas heat at 94*, a 60 mile drive @ 65~70 mph, transmission temp did not rise above 162*, engine coolant temp gauge was actually moving a little from about 180* to maybe 190~195*, best I could tell. I actually pulled over under the Trinity River bridge and locked up the brakes, raised engine rpm's to 1500, and let the trans and engine heat up. It didn't take long (5 min maybe) for trans temp to come up to 205* or so, and the engine quickly came up to over 210*, maybe to 220*. I got back up on the highway to 65 mph. After about 15 miles, trans temp was back down to 162* and engine coolant temp was back down to maybe 185* to 195*, best I could tell from the OEM gauge.
I feel confident that even with a trailer, I will see similar results. I've done this kind of thing before with my 1991 GMC with a 7.4L. I had just been looking for a good setup to fit my '05 without doing a bunch of fitups myself.
So far, I'm a happy camper.
Ranch55 is offline
Old 08-16-2006, 10:13 PM   #8
stevebos
Originally Posted by Ranch55
I have installed a TD-EOC system. It was a very clean and easy installation. No modifications to any of the OEM equipment is what drew me this way. I have also installed an '06 upgraded transmission cooler. Again, no modifications to OEM equipment, except to exchange OEM '05 trans oil lines with OEM '06 trans line.
Ranch55:
Is your upgraded transmission cooler the Mike L. '06 cooler?
Were there any modifications required to install both the TD-EOC and Mike L. '06 cooler?
- Steve
2004.5 2500HD CCSB, 4x4, D/A, tow tune, TD-EOC
Goodies occupying space in garage: Corsa full exhaust, Isspro gauges, KB CAI
2006 Tahoe Transport 33WTB; 14,000 lbs.
stevebos is offline
Old 08-17-2006, 08:34 PM   #9
Ranch55
Originally Posted by stevebos
Ranch55:
Yes, I installed the '06 Mike L. trans cooler. Replaced the '05 OEM cooler lines with '06 OEM cooler lines. Raised the mounting holes about 1 1/2" (drilled new holes) in the "A" frame member on the front of cooler stack as per TD-EOC instructions for an '06 installation. No other modifications.
The TD-EOC fit right up. There was no modifications required because of the '06 trans cooler.
The very clean installation of these two coolers is what drew me this way. No modifications to the truck OEM parts required, except what I mentioned above. Very clean installation on both.
Ranch55 is offline
Old 08-17-2006, 09:29 PM   #10
killerbee
BUG JUICER and
Michael
Vehicle Systems Engineer/Professional Tuner
04.5 GMC 2500HD SRW LLY
Learn about INDUCTION OVERHEATING
ECM's FOR SALE
killerbee is offline
Closed Thread
