code p0603 internal kar error - TheDieselGarage.com
Thread Details Posted by bunsorrou, this thread has received 15 replies and been viewed 6353 times.
Old 08-27-2006, 10:42 PM   #1
bunsorrou
Please help. my 97 powerstroke ran fine yesterday and today it would not start. Plugged my supership diagnostic tool and got p0602 and p0603. just spend $150 and replaced camshaft position sensor, clear the the code and it still not start. code p0603 keeps coming back. i'm desperate. Please help. I can try to check connection on Pcm but don't know the location.
bunsorrou is offline   Reply With Quote
Old 08-27-2006, 11:09 PM   #2
RSP
Rockin-S
Are you sure its a KAR and not KAM? If its a KAM then its a normal code that comes up on most every one. Its just the Keep Alive Memory
97 F350 PSD Crew Cab 4X4 Almost Stock :umno:
79 F250 CTD Super Cab 4X4 Almost Stock
79 F150 Reg Cab 4X4 Whimpy 512 CI BigBlock Some day it will be a CTD too
RSP is offline   Reply With Quote
Old 08-27-2006, 11:24 PM   #3
moose99psd
moose99psd's Avatar
Send a message via AIM to moose99psd
well if u have never pulled the computer then the connection at the pcm is highly inprobable to be loose
moose99psd is offline   Reply With Quote
Old 08-27-2006, 11:28 PM   #4
moose99psd
moose99psd's Avatar
according to the superchips website its a KAM code and not a KAR code.. when u try to start does the tach move?
Old 08-28-2006, 02:17 AM   #5
imported_BigGreen
P0603 KAM just means that the batteries have been disconected. No big deal, especially if you unhooked them to replace the CPS.
His: '95 F350 CrewCab, SRW, 5spd std w/ Royal Purple, LUK SMFW, VDO triple gauge pod, HX Mod, Homemade open air intake, 3" down pipe, 4" straight exhaust, tuning by DP Tuner, 190xxx miles & averages 23 MPG's on the highway.
Her's: 2004 Chevy Malibu Classic, 2.2L Ecotec. Stock. Very dissapointed in fuel economy, but it's a great car other than that.
Daily Drive (Company Car): 2007 Impala - Jet Black
imported_BigGreen is offline   Reply With Quote
Old 08-28-2006, 03:13 AM   #6
CSIPSD
CSIPSD's Avatar
Give us some info, Does it crank? Does the tach move when it cranks? Any smoke out the tail pipe? White (unburnt fuel) ? How many miles on the truck? Fuel filter new?
01 F-250 SC PSD,210k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, GTS Hybrid injectors, Studs, 910 Valve springs, Forged rods Water injection,Swamps tuned, MBRP 4" dual's, Aero, 6" tip's, 100 axl tank, 4" Revtek lift, 37-14.50-17 TOYO MT's 469hp and 1068tq...
ISSPRO PERFORMAX GAUGES
CSIPSD is offline   Reply With Quote
Old 08-28-2006, 04:59 PM   #7
superchip tuner
Is the truck prorgrammed?
If so return it back to stock.
Did you buy the truck orignally? I ask because if you have replaced the CPS and the truck still does not start, there might be a plug in chip in the PCM and it has failed. This is just my experience with PSD trucks. The computer on these trucks are basically behind the parking brake backed up to the engine bay. The best way to get to it is though the inner fenderwell. Remove the inner fenderwell from firewall on the drivers side of the truck. It will be a 4" long harness plug looking like it plugs directly in the firewall. Unbolt the 10mm bolt and remove the harness and slide the PCM out toward you. At the opposite end of the harness there is a port where a chip can be mounted, if it looks aftermarket pull it off. Plug the PCM in and try to start it.
It is KAM (Keep Alive Memory) this is the code when you erase the computers memory of the DTC's, this can also come up when returning the vehicles computer to stock or removing the battery voltage. We consider this a nothing code.
I hope this helps...
Ron
Feel free to email me or call 8-5est.
rrapp@superchips.com
1-888-227-2447 ex 7019
Please do not call after this time. I will be on the trails covered in mud, blood and beer.
STAY TUNED!!!!!!!!!!
superchip tuner is offline   Reply With Quote
Old 08-28-2006, 05:26 PM   #8
RSP
Rockin-S
No, thats not the best way to get to the chip, There are 3 nuts holding the E-Brake on and they take a 13mm Socket to remove. Take those loose and lay the E-Brake over to the side and If there is a chip its right there. Lots easier then pulling the PCM
Old 08-28-2006, 09:05 PM   #9
Tornsteel
Tornsteel's Avatar
We would really like a play by play on the problem to help you out a little better. And welcome to the sight.
2006 XLT 6.0, 72,000 miles. First owner. Build date 10/05, CC,LB,3.73LS,SRW,ISSPRO Pyro-Boost-Trans on the APillar,ARP Studs,Stock HG's,ELITE SCT Tadd's Tunes,Sinister SCT,Innovative tunes,EGR delete,4" turbo back dual exhst, zoodad, ccv mod, Coolant bypass filter, Cage leveling kit,upfitter high idle, running Amsoil 3000 with Archoil, 6.4 banjo's, Blue spring, 03 Turbo w/ 03 pedestal.
Issues: Rear main seal at 1'700 mls. EGR valve, EGR cooler and Oil cooler @ about 43k, Stock Head Gaskets @55k, Black Onyx HG's @72k.
http://www.thedieselgarage.com/galle...028_393362.jpg
Sean H
Tornsteel is offline   Reply With Quote
Old 08-28-2006, 09:35 PM   #10
bunsorrou
Sorry, it's the KAM.. the problem is my truck would not start, the only code stored is P0603..
I did find a blown 25Amp fuse in the engine compartment. I replaced it and it is still would not start, and the fuse did not blow. Help
