Duramax DTC code list - TheDieselGarage.com
Go Back   TheDieselGarage.com > GM Diesel & Truck Discussion > Duramax 2001-2004 (LB7)
Thread Details Posted by TheBac, this thread has received 6 replies and been viewed 60516 times.
Old 11-05-2006, 02:10 AM   #1
TheBac
Code....................................Descriptio n
P0100 ** Mass or Volume Air Flow Circuit Malfunction
P0101** Mass or Volume Air Flow Circuit Range/Performance Problem
P0102** Mass or Volume Air Flow Circuit Low Input
P0103** Mass or Volume Air Flow Circuit High Input
P0104** Mass or Volume Air Flow Circuit Intermittent
P0105** Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106** Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107** Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108** Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109** Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0109** Intake Air Temperature Circuit Malfunction
P0111** Intake Air Temperature Circuit Range/Performance Problem
P0112** Intake Air Temperature Circuit Low Input
P0113** Intake Air Temperature Circuit High Input
P0114** Intake Air Temperature Circuit Intermittent
P0115** Engine Coolant Temperature Circuit Malfunction
P0116** Engine Coolant Temperature Circuit Range/Performance Problem
P0117** Engine Coolant Temperature Circuit Low Input
P0118** Engine Coolant Temperature Circuit High Input
P0119** Engine Coolant Temperature Circuit Intermittent
P0120** Throttle/Petal Position Sensor/Switch A Circuit Malfunction
P0121** Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem
P0122** Throttle/Petal Position Sensor/Switch A Circuit Low Input
P0123** Throttle/Petal Position Sensor/Switch A Circuit High Input
P0124** Throttle/Petal Position Sensor/Switch A Circuit Intermittent
P0125** Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126** Insufficient Coolant Temperature for Stable Operation
P0130** O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131** O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132** O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133** O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134** O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135** O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136** O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137** O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138** O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139** O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140** O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141** O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142** O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143** O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144** O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145** O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146** O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147** O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150** O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151** O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152** O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153** O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154** O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155** O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156** O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157** O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158** O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159** O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160** O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161** O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162** O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163** O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164** O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165** O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166** O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167** O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170** Fuel Trim Malfunction (Bank 1)
P0171** System too Lean (Bank 1)
P0172** System too Rich (Bank 1)
P0173** Fuel Trim Malfunction (Bank 2)
P0174** System too Lean (Bank 2)
P0175** System too Rich (Bank 2)
P0176** Fuel Composition Sensor Circuit Malfunction
P0177** Fuel Composition Sensor Circuit Range/Performance
P0178** Fuel Composition Sensor Circuit Low Input
P0179** Fuel Composition Sensor Circuit High Input
P0180** Fuel Temperature Sensor A Circuit Malfunction
P0181** Fuel Temperature Sensor A Circuit Range/Performance
P0182** Fuel Temperature Sensor A Circuit Low Input
P0183** Fuel Temperature Sensor A Circuit High Input
P0184** Fuel Temperature Sensor A Circuit Intermittent
P0185** Fuel Temperature Sensor B Circuit Malfunction
P0186** Fuel Temperature Sensor B Circuit Range/Performance
P0187** Fuel Temperature Sensor B Circuit Low Input
P0188** Fuel Temperature Sensor B Circuit High Input
P0189** Fuel Temperature Sensor B Circuit Intermittent
P0190** Fuel Rail Pressure Sensor Circuit Malfunction
P0191** Fuel Rail Pressure Sensor Circuit Range/Performance
P0192** Fuel Rail Pressure Sensor Circuit Low Input
P0193** Fuel Rail Pressure Sensor Circuit High Input
P0194** Fuel Rail Pressure Sensor Circuit Intermittent
P0195** Engine Oil Temperature Sensor Malfunction
P0196** Engine Oil Temperature Sensor Range/Performance
P0197** Engine Oil Temperature Sensor Low
P0198** Engine Oil Temperature Sensor High
P0199** Engine Oil Temperature Sensor Intermittent
P0200** Injector Circuit Malfunction
P0201** Injector Circuit Malfunction - Cylinder 1
P0202** Injector Circuit Malfunction - Cylinder 2
P0203** Injector Circuit Malfunction - Cylinder 3
P0204** Injector Circuit Malfunction - Cylinder 4
P0205** Injector Circuit Malfunction - Cylinder 5
P0206** Injector Circuit Malfunction - Cylinder 6
P0207** Injector Circuit Malfunction - Cylinder 7
P0208** Injector Circuit Malfunction - Cylinder 8
P0209** Injector Circuit Malfunction - Cylinder 9
P0210** Injector Circuit Malfunction - Cylinder 10
P0211** Injector Circuit Malfunction - Cylinder 11
P0212** Injector Circuit Malfunction - Cylinder 12
P0213** Cold Start Injector 1 Malfunction
P0214** Cold Start Injector 2 Malfunction
P0215** Engine Shutoff Solenoid Malfunction
P0216** Injection Timing Control Circuit Malfunction
P0217** Engine Overtemp Condition
P0218** Transmission Over Temperature Condition
P0219** Engine Overspeed Condition
P0220** Throttle/Petal Position Sensor/Switch B Circuit Malfunction
P0221** Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
P0222** Throttle/Petal Position Sensor/Switch B Circuit Low Input
P0223** Throttle/Petal Position Sensor/Switch B Circuit High Input
P0224** Throttle/Petal Position Sensor/Switch B Circuit Intermittent
P0225** Throttle/Petal Position Sensor/Switch C Circuit Malfunction
P0226** Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
P0227** Throttle/Petal Position Sensor/Switch C Circuit Low Input
P0228** Throttle/Petal Position Sensor/Switch C Circuit High Input
P0229** Throttle/Petal Position Sensor/Switch C Circuit Intermittent
P0230** Fuel Pump Primary Circuit Malfunction
P0231** Fuel Pump Secondary Circuit Low
P0232** Fuel Pump Secondary Circuit High
P0233** Fuel Pump Secondary Circuit Intermittent
P0234** Engine Overboost Condition
P0235** Turbocharger Boost Sensor A Circuit Malfunction
P0236** Turbocharger Boost Sensor A Circuit Range/Performance
P0237** Turbocharger Boost Sensor A Circuit Low
P0238** Turbocharger Boost Sensor A Circuit High
P0239** Turbocharger Boost Sensor B Malfunction
P0240** Turbocharger Boost Sensor B Circuit Range/Performance
P0241** Turbocharger Boost Sensor B Circuit Low
P0242** Turbocharger Boost Sensor B Circuit High
P0243** Turbocharger Wastegate Solenoid A Malfunction
P0244** Turbocharger Wastegate Solenoid A Range/Performance
P0245** Turbocharger Wastegate Solenoid A Low
P0246** Turbocharger Wastegate Solenoid A High
P0247** Turbocharger Wastegate Solenoid B Malfunction
P0248** Turbocharger Wastegate Solenoid B Range/Performance
P0249** Turbocharger Wastegate Solenoid B Low
P0250** Turbocharger Wastegate Solenoid B High
P0251** Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252** Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253** Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254** Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255** Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256** Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257** Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258** Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259** Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260** Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261** Cylinder 1 Injector Circuit Low
P0262** Cylinder 1 Injector Circuit High
P0263** Cylinder 1 Contribution/Balance Fault
P0264** Cylinder 2 Injector Circuit Low
P0265** Cylinder 2 Injector Circuit High
P0266** Cylinder 2 Contribution/Balance Fault
P0267** Cylinder 3 Injector Circuit Low
P0268** Cylinder 3 Injector Circuit High
P0269** Cylinder 3 Contribution/Balance Fault
P0270** Cylinder 4 Injector Circuit Low
P0271** Cylinder 4 Injector Circuit High
P0272** Cylinder 4 Contribution/Balance Fault
P0273** Cylinder 5 Injector Circuit Low
P0274** Cylinder 5 Injector Circuit High
P0275** Cylinder 5 Contribution/Balance Fault
P0276** Cylinder 6 Injector Circuit Low
P0277** Cylinder 6 Injector Circuit High
P0278** Cylinder 6 Contribution/Balance Fault
P0279** Cylinder 7 Injector Circuit Low
P0280** Cylinder 7 Injector Circuit High
P0281** Cylinder 7 Contribution/Balance Fault
P0282** Cylinder 8 Injector Circuit Low
P0283** Cylinder 8 Injector Circuit High
P0284** Cylinder 8 Contribution/Balance Fault
P0285** Cylinder 9 Injector Circuit Low
P0286** Cylinder 9 Injector Circuit High
P0287** Cylinder 9 Contribution/Balance Fault
P0288** Cylinder 10 Injector Circuit Low
P0289** Cylinder 10 Injector Circuit High
P0290** Cylinder 10 Contribution/Balance Fault
P0291** Cylinder 11 Injector Circuit Low
P0292** Cylinder 11 Injector Circuit High
P0293** Cylinder 11 Contribution/Balance Fault
P0294** Cylinder 12 Injector Circuit Low
P0295** Cylinder 12 Injector Circuit High
P0296** Cylinder 12 Contribution/Range Fault
P0300** Random/Multiple Cylinder Misfire Detected
P0301** Cylinder 1 Misfire Detected
P0302** Cylinder 2 Misfire Detected
P0303** Cylinder 3 Misfire Detected
P0304** Cylinder 4 Misfire Detected
P0305** Cylinder 5 Misfire Detected
P0306** Cylinder 6 Misfire Detected
P0307** Cylinder 7 Misfire Detected
P0308** Cylinder 8 Misfire Detected
P0309** Cylinder 9 Misfire Detected
P0311** Cylinder 11 Misfire Detected
P0312** Cylinder 12 Misfire Detected
P0320** Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321** Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322** Ignition/Distributor Engine Speed Input Circuit No Signal
P0323** Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325** Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
P0326** Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327** Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328** Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329** Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330** Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331** Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332** Knock Sensor 2 Circuit Low Input (Bank 2)
P0333** Knock Sensor 2 Circuit High Input (Bank 2)
P0334** Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335** Crankshaft Position Sensor A Circuit Malfunction
P0336** Crankshaft Position Sensor A Circuit Range/Performance
P0337** Crankshaft Position Sensor A Circuit Low Input
P0338** Crankshaft Position Sensor A Circuit High Input
P0339** Crankshaft Position Sensor A Circuit Intermittent
P0340** Camshaft Position Sensor Circuit Malfunction
P0341** Camshaft Position Sensor Circuit Range/Performance
P0342** Camshaft Position Sensor Circuit Low Input
P0343** Camshaft Position Sensor Circuit High Input
P0344* Camshaft Position Sensor Circuit Intermittent
P0350** Ignition Coil Primary/Secondary Circuit Malfunction
P0351** Ignition Coil A Primary/Secondary Circuit Malfunction
P0352** Ignition Coil B Primary/Secondary Circuit Malfunction
P0353** Ignition Coil C Primary/Secondary Circuit Malfunction
P0354** Ignition Coil D Primary/Secondary Circuit Malfunction
P0355** Ignition Coil E Primary/Secondary Circuit Malfunction
P0356** Ignition Coil F Primary/Secondary Circuit Malfunction
P0357** Ignition Coil G Primary/Secondary Circuit Malfunction
P0358** Ignition Coil H Primary/Secondary Circuit Malfunction
P0359** Ignition Coil I Primary/Secondary Circuit Malfunction
P0360** Ignition Coil J Primary/Secondary Circuit Malfunction
P0361** Ignition Coil K Primary/Secondary Circuit Malfunction
P0362** Ignition Coil L Primary/Secondary Circuit Malfunction
P0370** Timing Reference High Resolution Signal A Malfunction
P0371** Timing Reference High Resolution Signal A Too Many Pulses
P0372** Timing Reference High Resolution Signal A Too Few Pulses
P0373** Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374** Timing Reference High Resolution Signal A No Pulses
P0375** Timing Reference High Resolution Signal B Malfunction
P0376** Timing Reference High Resolution Signal B Too Many Pulses
P0377** Timing Reference High Resolution Signal B Too Few Pulses
P0378** Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379** Timing Reference High Resolution Signal B No Pulses
P0380** Glow Plug/Heater Circuit "A" Malfunction
P0381** Glow Plug/Heater Indicator Circuit Malfunction
P0382** Exhaust Gas Recirculation Flow Malfunction
P0385** Crankshaft Position Sensor B Circuit Malfunction
P0386** Crankshaft Position Sensor B Circuit Range/Performance
P0387** Crankshaft Position Sensor B Circuit Low Input
P0388** Crankshaft Position Sensor B Circuit High Input
P0389** Crankshaft Position Sensor B Circuit Intermittent
P0400** Exhaust Gas Recirculation Flow Malfunction
P0401** Exhaust Gas Recirculation Flow Insufficient Detected
P0402** Exhaust Gas Recirculation Flow Excessive Detected
P0403** Exhaust Gas Recirculation Circuit Malfunction
P0404** Exhaust Gas Recirculation Circuit Range/Performance
P0405** Exhaust Gas Recirculation Sensor A Circuit Low
P0406** Exhaust Gas Recirculation Sensor A Circuit High
P0407** Exhaust Gas Recirculation Sensor B Circuit Low
P0408** Exhaust Gas Recirculation Sensor B Circuit High
P0410** Secondary Air Injection System Malfunction
P0411** Secondary Air Injection System Incorrect Flow Detected
P0412** Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413** Secondary Air Injection System Switching Valve A Circuit Open
P0414** Secondary Air Injection System Switching Valve A Circuit Shorted
P0415** Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416** Secondary Air Injection System Switching Valve B Circuit Open
P0417** Secondary Air Injection System Switching Valve B Circuit Shorted
P0418** Secondary Air Injection System Relay "A" Circuit Malfunction
P0419** Secondary Air Injection System Relay "B" Circuit Malfunction
P0420** Catalyst System Efficiency Below Threshold (Bank 1)
P0421** Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422** Main Catalyst Efficiency Below Threshold (Bank 1)
P0423** Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424** Heated Catalyst Temperature Below Threshold (Bank 1)
P0430** Catalyst System Efficiency Below Threshold (Bank 2)
P0431** Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432** Main Catalyst Efficiency Below Threshold (Bank 2)
P0433** Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434** Heated Catalyst Temperature Below Threshold (Bank 2)
P0440** Evaporative Emission Control System Malfunction
P0441** Evaporative Emission Control System Incorrect Purge Flow
P0442** Evaporative Emission Control System Leak Detected (small leak)
P0443** Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444** Evaporative Emission Control System Purge Control Valve Circuit Open
P0445** Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446** Evaporative Emission Control System Vent Control Circuit Malfunction
P0447** Evaporative Emission Control System Vent Control Circuit Open
P0448** Evaporative Emission Control System Vent Control Circuit Shorted
P0449** Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450** Evaporative Emission Control System Pressure Sensor Malfunction
P0451** Evaporative Emission Control System Pressure Sensor Range/Performance
P0452** Evaporative Emission Control System Pressure Sensor Low Input
P0453** Evaporative Emission Control System Pressure Sensor High Input
P0454** Evaporative Emission Control System Pressure Sensor Intermittent
P0455** Evaporative Emission Control System Leak Detected (gross leak)
P0460** Fuel Level Sensor Circuit Malfunction
P0461** Fuel Level Sensor Circuit Range/Performance
P0462** Fuel Level Sensor Circuit Low Input
P0463** Fuel Level Sensor Circuit High Input
P0464** Fuel Level Sensor Circuit Intermittent
P0465** Purge Flow Sensor Circuit Malfunction
P0466** Purge Flow Sensor Circuit Range/Performance
P0467** Purge Flow Sensor Circuit Low Input
P0468** Purge Flow Sensor Circuit High Input
P0469** Purge Flow Sensor Circuit Intermittent
P0470** Exhaust Pressure Sensor Malfunction
P0471** Exhaust Pressure Sensor Range/Performance
P0472** Exhaust Pressure Sensor Low
P0473** Exhaust Pressure Sensor High
P0474** Exhaust Pressure Sensor Intermittent
P0475** Exhaust Pressure Control Valve Malfunction
P0476** Exhaust Pressure Control Valve Range/Performance
P0477** Exhaust Pressure Control Valve Low
P0478** Exhaust Pressure Control Valve High
P0479** Exhaust Pressure Control Valve Intermittent
P0480** Cooling Fan 1 Control Circuit Malfunction
P0481** Cooling Fan 2 Control Circuit Malfunction
P0482** Cooling Fan 3 Control Circuit Malfunction
P0483** Cooling Fan Rationality Check Malfunction
P0484** Cooling Fan Circuit Over Current
P0485** Cooling Fan Power/Ground Circuit Malfunction
P0500** Vehicle Speed Sensor Malfunction
P0501** Vehicle Speed Sensor Range/Performance
P0502** Vehicle Speed Sensor Low Input
P0503** Vehicle Speed Sensor Intermittent/Erratic/High
P0505** Idle Control System Malfunction
P0506** Idle Control System RPM Lower Than Expected
P0507** Idle Control System RPM Higher Than Expected
P0510** Closed Throttle Position Switch Malfunction
P0520** Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521** Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522** Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523** Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530** A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531** A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532** A/C Refrigerant Pressure Sensor Circuit Low Input
P0533** A/C Refrigerant Pressure Sensor Circuit High Input
P0534* Air Conditioner Refrigerant Charge Loss
P0550** Power Steering Pressure Sensor Circuit Malfunction
P0551** Power Steering Pressure Sensor Circuit Range/Performance
P0552** Power Steering Pressure Sensor Circuit Low Input
P0553** Power Steering Pressure Sensor Circuit High Input
P0554** Power Steering Pressure Sensor Circuit Intermittent
P0560** System Voltage Malfunction
P0561** System Voltage Unstable
P0562** System Voltage Low
P0563** System Voltage High
P0565** Cruise Control On Signal Malfunction
P0566** Cruise Control Off Signal Malfunction
P0567** Cruise Control Resume Signal Malfunction
P0568** Cruise Control Set Signal Malfunction
P0569** Cruise Control Coast Signal Malfunction
P0570** Cruise Control Accel Signal Malfunction
P0571** Cruise Control/Brake Switch A Circuit Malfunction
P0572** Cruise Control/Brake Switch A Circuit Low
P0573** Cruise Control/Brake Switch A Circuit High
P0574** Cruise Control Related Malfunction
P0575** Cruise Control Related Malfunction
P0576** Cruise Control Related Malfunction
P0578** Cruise Control Related Malfunction
P0579** Cruise Control Related Malfunction
P0580** Cruise Control Related Malfunction
P0600** Serial Communication Link Malfunction
P0601** Internal Control Module Memory Check Sum Error
P0602** Control Module Programming Error
P0603** Internal Control Module Keep Alive Memory (KAM) Error
P0604** Internal Control Module Random Access Memory (RAM) Error
P0605** Internal Control Module Read Only Memory (ROM) Error
P0606** PCM Processor Fault
P0608** Control Module VSS Output "A" Malfunction
P0609** Control Module VSS Output "B" Malfunction
P0620** Generator Control Circuit Malfunction
P0621** Generator Lamp "L" Control Circuit Malfunction
P0622** Generator Field "F" Control Circuit Malfunction
P0650** Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654** Engine RPM Output Circuit Malfunction
P0655** Engine Hot Lamp Output Control Circuit Malfucntion
P0656** Fuel Level Output Circuit Malfunction
P0700** Transmission Control System Malfunction
P0701** Transmission Control System Range/Performance
P0702** Transmission Control System Electrical
P0703** Torque Converter/Brake Switch B Circuit Malfunction
P0704** Clutch Switch Input Circuit Malfunction
P0705** Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706** Transmission Range Sensor Circuit Range/Performance
P0707** Transmission Range Sensor Circuit Low Input
P0708* Transmission Range Sensor Circuit High Input
P0709* Transmission Range Sensor Circuit Intermittent
P0710** Transmission Fluid Temperature Sensor Circuit Malfunction
P0711** Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712** Transmission Fluid Temperature Sensor Circuit Low Input
P0713** Transmission Fluid Temperature Sensor Circuit High Input
P0714** Transmission Fluid Temperature Sensor Circuit Intermittent
P0715** Input/Turbine Speed Sensor Circuit Malfunction
P0716** Input/Turbine Speed Sensor Circuit Range/Performance
P0717** Input/Turbine Speed Sensor Circuit No Signal
P0718** Input/Turbine Speed Sensor Circuit Intermittent
P0719** Torque Converter/Brake Switch B Circuit Low
P0720** Output Speed Sensor Circuit Malfunction
P0721** Output Speed Sensor Range/Performance
P0722** Output Speed Sensor No Signal
P0723** Output Speed Sensor Intermittent
P0724** Torque Converter/Brake Switch B Circuit High
P0725** Engine Speed input Circuit Malfunction
P0726** Engine Speed Input Circuit Range/Performance
P0727** Engine Speed Input Circuit No Signal
P0728** Engine Speed Input Circuit Intermittent
P0730** Incorrect Gear Ratio
P0731** Gear 1 Incorrect ratio
P0732** Gear 2 Incorrect ratio
P0733** Gear 3 Incorrect ratio
P0734** Gear 4 Incorrect ratio
P0735** Gear 5 Incorrect ratio
P0736** Reverse incorrect gear ratio
P0740** Torque Converter Clutch Circuit Malfuction
P0741** Torque Converter Clutch Circuit Performance or Stuck Off
P0742** Torque Converter Clutch Circuit Stuck On
P0743** Torque Converter Clutch Circuit Electrical
P0744** Torque Converter Clutch Circuit Intermittent
P0745** Pressure Control Solenoid Malfunction
P0746** Pressure Control Solenoid Performance or Stuck Off
P0747** Pressure Control Solenoid Stuck On
P0748** Pressure Control Solenoid Electrical
P0749** Pressure Control Solenoid Intermittent
P0750** Shift Solenoid A Malfunction
P0751** Shift Solenoid A Performance or Stuck Off
P0752** Shift Solenoid A Stuck On
P0753** Shift Solenoid A Electrical
P0754** Shift Solenoid A Intermittent
P0755** Shift Solenoid B Malfunction
P0756** Shift Solenoid B Performance or Stuck Off
P0757** Shift Solenoid B Stuck On
P0758** Shift Solenoid B Electrical
P0759** Shift Solenoid B Intermittent
P0760** Shift Solenoid C Malfunction
P0761** Shift Solenoid C Performance or Stuck Off
P0762** Shift Solenoid C Stuck On
P0763** Shift Solenoid C Electrical
P0764** Shift Solenoid C Intermittent
P0765** Shift Solenoid D Malfunction
P0766** Shift Solenoid D Performance or Stuck Off
P0767** Shift Solenoid D Stuck On
P0768** Shift Solenoid D Electrical
P0769** Shift Solenoid D Intermittent
P0770** Shift Solenoid E Malfunction
P0771** Shift Solenoid E Performance or Stuck Off
P0772** Shift Solenoid E Stuck On
P0773** Shift Solenoid E Electrical
P0774** Shift Solenoid E Intermittent
P0780** Shift Malfunction
P0781** 1-2 Shift Malfunction
P0782** 2-3 Shift Malfunction
P0783** 3-4 Shift Malfunction
P0784** 4-5 Shift Malfunction
P0785** Shift/Timing Solenoid Malfunction
P0786** Shift/Timing Solenoid Range/Performance
P0787** Shift/Timing Solenoid Low
P0788** Shift/Timing Solenoid High
P0789** Shift/Timing Solenoid Intermittent
P0790** Normal/Performance Switch Circuit Malfunction
P0801** Reverse Inhibit Control Circuit Malfunction
P0803** 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804** 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
TheBac is offline   Reply With Quote
Old 11-05-2006, 02:12 AM   #2
TheBac
If a code is missing, let us know and we can add it in. That list is constantly evolving.
Old 11-05-2006, 04:28 AM   #3
stevebos
Great information, thanks!
- Steve
2004.5 2500HD CCSB, 4x4, D/A, tow tune, TD-EOC
Goodies occupying space in garage: Corsa full exhaust, Isspro gauges, KB CAI
2006 Tahoe Transport 33WTB; 14,000 lbs.
stevebos is offline   Reply With Quote
Old 12-02-2006, 12:07 PM   #4
TheBac
Here is a website that has EVERY OBD2 code listed up through 2004.
http://myweb.accessus.net/~090/dtcobd2p.html#typ
Old 12-04-2006, 12:50 AM   #5
Dieselson
TDG Junior Mafia #61
Dieselson's Avatar
Same thing except all codes
http://www.pacificp.com/index.php?ma...0c18b153931f9d
2001 Chevy SB/CC Duramax LB7
Garrett GT4088R from PPE, PPE Duel fuelers, PPE Tuning, PPE stage 4 transmission w/suncoast 1056 converter, PPE Lift pump, Fabtech tie rods, Black Eagle alloys.
Engine is apart and in the garage
Goal is to have it done by the end of this summer.
TDG Mafia
The Diesel Garage
"Can you keep up??
Dieselson is offline   Reply With Quote
Old 01-14-2007, 03:55 PM   #6
Turtledude
Turtledude
Thanks guy's. I already know what TC means [downloaded list from PPE a year ago]. I need to know how to correct problem.
Turtledude is offline   Reply With Quote
Old 05-03-2010, 05:34 PM   #7
slofotwob
slofotwob
Send a message via Yahoo to slofotwob
codes
Hey I got a code from my GM 2004 duramax diesel 6.6 turbo P1093 and P1094. not on your list . You never received one? I have starting issues, black smoke, runs rough. When i get it started , with starting fluid. can you help with this problem?
slofotwob is offline   Reply With Quote
