Life Expectancy Of 7.3? - TheDieselGarage.com
Home Forum Who's Online Today's Posts Vendors Advertise Insurance Auto Loans
Thread Details Posted by BASIC, this thread has received 13 replies and been viewed 3327 times.
Old 06-17-2005, 12:19 AM   #1
BASIC
Posts: n/a
Points: 0 [Check]
HI guys,my first post.Thankyou Duke for the invitation.I have a 99 F-350 w/156,000 mi.,,I've read that its a 250,000 mi.engine is this true?I have more problems than I think I should have with the truck,I'd like something new.I plow with the truck and do take care of it.Nice to be here,BASIC.
Old 06-17-2005, 12:28 AM   #2
jharvey3
Resident Maniac
Howdy Basic, welcome.........
The tried and true 7.3 is a 500,000 mile motor if you take care of it.
What kind of problems are you having?
John
jharvey3 is offline   Reply With Quote
Old 06-17-2005, 12:29 AM   #3
Deezle1
Down With The Slickness
Send a message via AIM to Deezle1
Welcome to the DG Basic the life expectancy of the engine is based on how you abuse it if youve beaten it, its gunna be a little lower...if you baby it it will be alittle higher. 400k to 500 sounds right to me.
If im wrong (forces above) please correct me
Dominick
a figment of you're imagination...
1997 dodge ram 1500 4x4 318 auto: summit ignition, fastman throttle body, holley fuel pump 23lb injectors, 180* high flow t stat, open element intake, 3 inch cat back exhaust out the side, high flow water pump, high pressure oil pump...needs trans.
87 Chevy K30 6.2 4x4 4 speed...restoration/build
Deezle1 is offline   Reply With Quote
Old 06-17-2005, 12:30 AM   #4
Duke
'Ol Builder guy
Duke's Avatar
I think that's a realistic number. You could go 300-400 if you had a lot of long distance driving on the highway and anal care of the engine.
Hot rodding decreases life expectancy, too.
Great to have you here. Welcome to the site. :Thumbup:
Duke is offline   Reply With Quote
Old 06-17-2005, 12:44 AM   #5
BASIC
Posts: n/a
Points: 0 [Check]
Thanks for the welcome.I've had more truck problems than engine.The water pump and fan clutch just went,CPS and the fuel system froze up three times (twice one year,once the next)even with a winter additive and I am careful where I get my fuel.Its also the engine might go 300,000-500,000 mi. but at what price to keep it running?I've also had a hyd line and a slve cyl.go in the manual trans.Other than changing the oil and filters on a regular basis,what can I do to help maintain it?How long do the injectors last,is there any preventative maintenance that can be done?
Old 06-17-2005, 01:50 AM   #6
Duke
'Ol Builder guy
Duke's Avatar
Not really. The 7.3L loves clean oil since it's a HEUI diesel. Try to purchase fuel where a lot is sold. Change fuel filters often, too. Cheap insurance.
It's also good to buy the Fleetgaurd strips and check your coolant. Add FW-16 coolant additive if your charge is low to prevent cavitation.
I've done nothing except replace the batteries on one of mine.
Old 06-17-2005, 09:49 PM   #7
BASIC
Posts: n/a
Points: 0 [Check]
Thanks Duke,thats what I have been doing,BASIC.
Old 06-18-2005, 01:22 PM   #8
Sea97Stroker
Put a good airbox on it and be anal about checking your airfilter. There have been a ton of PSD die a early death because of Fords Joke of a aircleaner issed: system.
Stevo
1997 F350 CC 4x4 5 Speed , intercooled, BDP Stage 2's, TWildman Chip Via Beans Diesel Performance, 5inch Stacks , 777 Lube Bypass, other Doodads on: www.BeansDieselPerformance.com
Sea97Stroker is offline   Reply With Quote
Old 06-20-2005, 12:58 PM   #9
BJS
International says at 200k 10% will need an overhaul and at 350k 50% will need one
source
95 F350 Centurion Conversion Bronco (Crew Cab SRW) 4X4 4.10, Isspro Performax Boost, Pyro, & trans temp on the A-pillar, BDP Stage 1 injectors, Open air intake, Dpp Downpipe, Self built E4OD with parts from Racer-X, Tony Wildman Chip, Early '99 Intercooler.
Destin FL Vacation Houses 1 block from the beach
BJS is offline   Reply With Quote
Old 06-22-2005, 06:52 AM   #10
Powerstroke2000
Interestingly enough, a fellow works for a company who owns TWELVE of the early Powerstrokes in their fleet, and they have a mechanic also that maintains all their trucks. The one with the most miles I believe was a '95, and it had 1.7 Million miles on it! Of course it has gone through many parts in those miles, but apparently it hasn't had a full rebuild yet!
I wonder how many others might be around the country with similar mileage?
Dale
Precision Ind triple disk Torque Convertor & Pro build E4OD ~ Transgo Tugger shift kit
Mini-Me/SWAMP 250cc Hybrid 530 injectors
5" custom exhaust
IDM mod
TYMAR open intake
Ford AIC & full gauges
SD 17° HPOP
Superduty Intercooler & GTS pipe kit
CCV mod
Powerstroke2000 is offline   Reply With Quote
960 Spinner install hispeed428 Heavy Duty 18 01-20-2010 11:50 PM
03 lb7 ecm madmatt Whats Been Sold 0 12-31-2008 11:33 PM
S/V page plainredtruck Supporting Vendors Forum 1 12-25-2008 02:55 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
