| Thread Details Posted by haz-mat19, this thread has received 10 replies and been viewed 634 times. |
#1 |
what setting
Well I getting a Comp. My friend said they did not have any EZ's in stock and it would take three weeks to get one. What setting would be the best for mileage, daily driving and, alittle smoke. I only have a V/B so I know I can not use setting 5.
: .. Oh and how hard is to hook up. :thanks: :Thumbup:
'01 xcab 4x4,Suncoast by Mike L. Goerend triple, edge III, AFE stage II, HTT 62/12, FASS, and other stuff
| Sponsored Links | |||
Advertisement | |||
#2 |
Lead Newbie
I'd run 3x5 you get all the timing, a littile fuel and lots of smoke...... It will be sweet.....Glad you decided to step up and get the comp. you have a pyro, f/p, abd boost guage? if not, dont tap the wire yet. it wil work just like an EZ. you will need to monitior the f/p and pyro if you get into the fuel....
Tim 01 Dawdge 2500 QC 4X4 SunCoast By Garmon,Ranch Hand Bumpers Front and Rear, 315 Buckshot Mudders, Spray in Liner, Bluechip FMS, Dakota Digital FP, Vulcan Full Flow Pusher Pump Kit , Grand Rock 5 inch Powerflow Exhaust , Kennedy Diesel Twin Lift Pumps Buckcherry for President "Reality is not a choice, the way you deal with it is." -Tucker Max |
#3 |
I don't want to tap the wire right now. I am waiting for the injector pump to die and they will not warrenty it if the pump is pierced. I have a f/p, and trans, pyro is a little down the road. The comp was alittle more then I was going to spend right now. So if I don't tap the wire it is only going to be the same as an EZ, thanks See ya
#4 |
Lead Newbie
Run it 2x5...you will like it ......
#5 |
DPM Mobile Dyno
I believe without the pump wire tap only level 1 will work... And that is the same as the EZ.
Have fun Haz...
David Dunbar www.runNADM.com www.DieselPerformanceMotorsports.com 2004.5 Dodge 3500 Laramie 4x4 48re 1998 Dodge 2500 QC 4x4 12v 47re Power by Garmon - to the ground by Sun Coast = 12's :Thumbup: |
#6 |
Thanks David. I will have to wait until the warrenty is up or the pump dies to tap it. See ya.
#7 |
SETDR Vice President
For best milage on the highway I run 4X1 as I said over on SETDR.
I get about 23 - 24 mpgs Joe G.
01 Dodge 2500 4X4 Auto RED Quad Cab DD4's, Hx35, 5" exhaust, Edge Comp, BHAF, Holley Blue Pusher pump. Full Blown Sun Coast Comp Tranny, Laminated Flywheel, 91% ProLoc TQconvertor last Dyno 437hp, 996tq :Thumbup: |
#8 |
I put it in last night at work. I did not tap it yet like I said. But driving it I can already see some great improvement. No I need the damn pump to die so I can turn it up alittle :evil: . Joe that sounds like a good setting, power and awsome mileage :Thumbup: :thanks:
#9 |
I have question, when I turn up the fuel settings I get more smoke then when they are set on the first level. I did not tap the pump like I said. I was woundering if it worked on the other settings just not a drastic as if I where to tap the pump. See ya :Thumbup:
#10 |
Lead Newbie
The way I understand it is that by turning up the settings, even without the tap, that the comp asks the ECM to pour the fuel on quicker according to throttle position.....that is why you are seeing more smoke
| Sponsored Links | |
Advertisement | |
