| Thread Details Posted by 2003EDGE, this thread has received 0 replies and been viewed 4074 times. |
#1 |
International Tech.
DT466 2004 and up EGR Engine DTC List
Here ya go guys.
111 ECM No errors detected - flash code only 112† 168 0 3 ECM PWR Electrical system voltage B+ out-of-range high 113† 168 0 4 ECM PWR Electrical system voltage B+ out-of-range low 114* 110 0 4 ECT Engine Coolant Temperature signal out-of-range low 115* 110 0 3 ECT Engine Coolant Temperature signal out-of-range high 121* 102 0 3 MAP Intake Manifold Absolute Pressure signal out-of-range high 122* 102 0 4 MAP Intake Manifold Absolute Pressure signal out-of-range low 123* 102 0 2 MAP Intake Manifold Absolute Pressure signal in-range fault 124* 164 0 4 ICP Injection Control Pressure signal out-of-range low 125* 164 0 3 ICP Injection Control Pressure signal out-of-range high 126* 118 4 N/A BCP Engine Brake Control Pressure signal out-of-range low 127* 118 3 N/A BCP Engine Brake Control Pressure signal out-of-range high 131*† 91 0 4 APS/IVS APS signal out-of-range low 132*† 91 0 3 APS/IVS APS signal out-of-range high 133*† 91 0 2 APS/IVS APS signal in-range DTC 134*† 91 0 7 APS/IVS APS signal and IVS disagree 135*† 0 230 11 APS/IVS Idle Validation Switch circuit fault 136 94 0 4 EFP Engine Fuel Pressure signal out-of-range low 137 94 0 3 EFP Engine Fuel Pressure signal out-of-range high 141† 84 0 4 VSS Vehicle Speed Sensor signal out-of-range low 142† 84 0 3 VSS Vehicle Speed Sensor signal out-of-range high 143 0 21 2 CMP Incorrect CMP signal signature 145 0 21 12 CMP CMP signal inactive 146 0 64 12 CKP CKP signal inactive 147 0 64 2 CKP Incorrect CKP signal signature 151*† 108 0 3 BAP Barometric Absolute Pressure signal out-of-range high 152*† 108 0 4 BAP Barometric Absolute Pressure signal out-of-range low 153† 97 0 4 WIF Water In Fuel signal out-of-range low 154 171 0 4 IAT Inlet Air temperature signal out-of-range low 155 171 0 3 IAT Inlet Air temperature signal out-of-range high 161* 105 0 4 MAT Manifold Air Temperature Signal out-of-range low 162* 105 0 3 MAT Manifold Air Temperature Signal out-of-range high 163* 27 0 4 EGR Exhaust Gas Recirculation Valve Position Signal out-of-range low 211* 100 0 4 EOP Engine Oil Pressure signal out-of-range low 212* 100 0 3 EOP Engine Oil Pressure signal out-of-range high 215† 84 0 8 VSS Vehicle Speed Sensor signal frequency out-of-range high 225 100 0 0 EOP EOP sensor signal in-range fault 231† 0 250 2 ATA ATA data communication link error 236† 111 0 2 ECL ECL switch circuit fault 241† 0 42 11 IPR Injection Control Pressure regulator OCC self test failed 246† 0 56 11 EFAN Engine Fan - OCC self test fault 247† 121 0 11 BSV Engine Brake enable OCC self test failed 251† 0 38 11 IAH Inlet Air Heater OCC self test failed 256† 0 55 11 RSE Radiator Shutter Enable OCC fault 261† 0 27 11 VGT Variable Geometry Turbo control OCC self test failed 267† 0 39 11 ECI Engine Crank Inhibit OCC self test failed 311* 175 0 4 EOT Engine Oil Temperature signal out-of-range low 312* 175 0 3 EOT Engine Oil Temperature signal out-of-range high 313** 100 0 1 EWPS Engine Oil Pressure below warning level 314** 100 0 7 EWPS Engine Oil Pressure below critical level 315* 190 0 0 EWPS Engine speed above warning level 316 110 0 1 EWPS Engine Coolant Temperature unable to reach commanded set point 321** 110 0 0 EWPS Engine Coolant Temperature above warning level 322** 110 0 7 EWPS Engine Coolant Temperature above critical level 323** 111 0 1 EWPS Engine Coolant Level below warning/critical level 324** 71 0 14 IST Idle Shutdown Timer enabled engine shutdown 325 110 0 14 EWPS Power reduced, matched to cooling system performance 331* 164 0 0 ICP SYS Injection Control Pressure above system working range 332* 164 0 13 ICP Injection Control Pressure above spec. with engine not running 333* 164 0 10 ICP SYS Injection Control Pressure above/below desired level 334 164 0 7 ICP SYS ICP unable to achieve setpoint in time (poor performance) 335 164 0 1 ICP SYS ICP unable to build pressure during cranking 341* 0 34 4 EBP Exhaust Back Pressure signal out-of-range low 342* 0 34 3 EBP Exhaust Back Pressure signal out-of-range high 343* 0 34 0 AMS Excessive exhaust back pressure (gauge) 344* 0 34 13 EBP Exhaust back pressure above spec. when engine off 345 0 27 2 AMS Faults detected during VGT portion of the AMS Test 346 27 0 2 AMS Faults detected during EGR portion of the AMS Test 351 0 34 7 AMS Change in exhaust back pressure did not occur when expected 353 0 27 5 AMS Variable Geometry Turbo control over duty cycle 354 0 27 6 AMS Variable Geometry Turbo control under duty cycle 355 103 0 0 AMS Variable Geometry Turbo overspeed 361 0 27 10 AMS VGT control input (MAP/EBP) above/below desired level 365* 27 0 10 AMS EGR Valve Position above/below desired level 368* 0 146 7 AMS EGR driver module/ECM2 communication fault 371 94 0 0 EFP Engine Fuel Pressure is above normal operating range 372 94 0 1 EFP Engine Fuel Pressure is below normal operating range 421-426 0 1-6 5 INJ High side to low side open (cylinder number indicated) 431-436 0 1-6 4 INJ High side shorted to low side (cylinder number indicated) 451-456 0 1-6 6 INJ High side short to ground or V BAT (cylinder number indicated) 523† 0 233 4 IDM IDM V IGN voltage low 525* 0 254 6 IDM IDM fault 533† 0 221 3 IDM IDM relay voltage high 534† 0 221 4 IDM IDM relay voltage low 546* 121 0 1 BCP Engine Brake Contol Pressure is below expected range 547* 121 0 0 BCP Engine Brake Contol Pressure is above expected range 543* 0 155 7 ECM/IDM ECM/IDM communications fault 551 0 22 12 ECM/IDM IDM/CMPO signal inactive 552 0 22 2 ECM/IDM IDM incorrect CMPO signal signature 553 0 22 11 ECM/IDM IDM CKPO signal inactive 554 0 22 8 ECM/IDM IDM incorrect CKPO signal signature 613* 0 252 1 ECM ECM/IDM software not compatible 614* 0 252 13 ECM EFRC/ECM configuration mismatch 621* 0 253 1 ECM Engine using mfg. default rating 622* 0 253 0 ECM Engine using field default rating 623* 0 253 13 ECM Invalid Engine Family Rating Code (EFRC) 624 0 240 14 ECM Field default active 626† 0 254 8 ECM PWR Unexpected reset fault 631 0 240 2 ECM Read Only Memory (ROM) self test fault 632 0 254 12 ECM Random Access Memory (RAM) - CPU self test fault 655 0 240 13 ECM Programmable parameter list level incompatible 661 0 240 11 ECM RAM programmable parameter list corrupt 664 0 253 14 ECM Calibration level incompatible 665 0 252 14 ECM Programmable parameter memory content corrupt
| Sponsored Links | |
Advertisement | |
