proper clutch adjustment - TheDieselGarage.com
Thread Details Posted by dondiesel444, this thread has received 7 replies and been viewed 6663 times.
Old 01-14-2007, 01:10 AM   #1
dondiesel444
dondiesel444's Avatar
I'd like to know the proper way to adjust my clutch. the shop said after a week or so the pedal would come up and the clutch would need adjustment as it finally broke-in, but it hasn't happened yet. I guess eventually it will need adjustment, can some one tell me the proper way to do it by myself? thanks in advance
Don
1997 Western Star 4964FX double frame tri-axle dump truck, 3406C Cat Power, 8LL, 46K rears on Chalmers, lots of lights, Sirius radio
2001 F-250 PSD CC 4X4 Lariet, 97k miles, DP Tuner PCM, 3" lift, 305/70R16's on 16x10 wheels, 6637 air filter, straight piped, more to come.
dondiesel444 is offline   Reply With Quote
Old 01-14-2007, 02:21 AM   #2
2003EDGE
International Tech.
What kind of clutch is it? Solo, easy pedal?
2003EDGE is offline   Reply With Quote
Old 01-14-2007, 02:26 AM   #3
Lowboy
Ol Dirt Contractor
Lowboy's Avatar
I was Anti-Obama before it was cool!
Leno: ‘Remember the Old Days When Obama’s Biggest Embarrassment Was Joe Biden'
Ernie Hasse+ Bill Gaither America Medley
XCR 800cc Polaris Triple with Turbo, Nitrous & RMI
96 F250 7.3 Hypermax Stage III’s, H2 for now, Wide Open Performance long block. Spearco Intercooler 4” downpipe Suncoast Tranny, Terminator Oil
Newest--09 Black VW Jetta SportWagen TDI DSG Nav Roof 17" Avignon's Valentine One
Early 99 F250 SD 7.3 almost stock for now
87 Turbo Intercooled T-Bird stock
98 379 Pete 15.8L 3406E Pittsburgh Power to 900 HP Michigan Stage III OR6051 Turbo & P5 Nathan Horns
More Milwaukee V28 Tools than Tim Allen has!
Remember, nozzle size matters at the pump
Lowboy is offline   Reply With Quote
Old 01-14-2007, 04:21 AM   #4
fjh
Short answer!(If indeed you are talking an esay pedal or spicer clutch.)If you can get it in to gear with out grinding ,if you have 3/4 to two inches of free pedal at the top leave it alone! when the free pedal is gone or down to 3/4 of and inch Its time to adjust! You do it thru the cover on the bottom You need to bar or crank the engine till the Adjustment wheel bolt is visable push the clutch in and jam the clutch to the floor with a stick or rod and push in the that adjustment bolt and give it 1 or 2 turns .
John might bite my head off if I say anymore !
fjh is offline   Reply With Quote
Old 01-14-2007, 11:05 AM   #5
dondiesel444
thanks. I know I have to turn the bolt in, but I didn't know how many turns and I didn't know it had to be done with the clutch pushed to the floor.
Old 01-14-2007, 04:02 PM   #6
DSR
See if i can explain this right, have to have pedal down, turn adjuster on ppa so you have 1/2-3/4 inch between bearing and clutch brake ,with pedal up then adj linkage if needed to get free pedal right alot of times you will not have to adj linkage. on clutch with lock held in with bolt and need adj. tool or pry bars on adj. seems like 2 tabs on adj. will be right or good start on a normal clutch adj-- hope this helps
DSR is offline   Reply With Quote
Old 01-14-2007, 05:15 PM   #7
thejdman04
Load bars (if your around box van) are a nice convient adjustable way (i f you got more then one truck) of keeping the clutch to the floor if you are by yourself.
1996 Gmc k2500 4x4 6.5 turbo diesel, with mods Blew the head gasket, put all new heads, valves, injecotrs gaskets etc on the truck only to get it together and find out it had no oil pressure, and sounded horrible (pry a spun bearing). SOLD
2007 chevrolet 2500hd Duramax loaded. GM LEMON BUYBACK
2007 Chevrolet LBZ 1 ton crew cab 8ft box
on star, xm, tow mirrors, 145 amp alt,
#23 Singles Club
thejdman04 is offline   Reply With Quote
Old 01-15-2007, 04:03 AM   #8
bmoeller
bmoeller's Avatar
Yes, the pedal needs to be pressed down. Won't be able to turn the adjusting ring otherwise. If working alone, I use a few wood blocks to hold the pedal down.
2-3 tabs usually does it. With a clutch brake, you usually want ~9/16" gap between the brake and throwout bearing, or between the brake and the front cover that is around the input shaft of trans.
Also want ~1/8" of gap between the throwout bearing and clutch release forks.
Depending on the person who drives the truck, I tweak the 9/16" and 1/8" gaps. If the person has a bad tendency to push the pedal all of the way down when coasting to a stop, then I increase the gaps a bit, so the clutch brake squeeze starts later.
For the 9/16, I use a 3-4" long 3/8" bolt. If I'm driving the truck, I use the 9/16". If not, I set the gap such, that I can just spin the bolt head between the brake and bearing. I also shoot for 2" free travel, since most of the time, the guys driving aren't paying any attention to it. I don't usually hear that it needs to be adjusted, til I hear them grinding gears to start out.
If the clutch uses an adjusting bolt, in place of the tabs, I use a long handled 3/8" drive ratchet. One full swing of the handle travel is about the same as one tab. So, 2-3 swings is usually enough.
"Obama = Hoax and Chains"
