| Thread Details Posted by cherrybomb, this thread has received 11 replies and been viewed 6612 times. |
#1 |
International VT275
I only recently discovered that these exist, and had a few questions about them.
So far, it only looks like they were installed in 2005 and newer International CF trucks. Any other places I might find one in a donor vehicle? If not in a donor vehicle, any hints on where I might find a complete motor/ECU/Trans? Anyone done any performance mods to one of these? Seems like it would be a good candidate being that it's already a twin turbo mill. Anyone know how much power you can make with one? 300hp? 400hp? I'm still trying to find the best choice to fit in my 1999 Ford Explorer. Before I discovered the VT275, I was pretty confident I was going to put an Isuzu 4H series I4 in it, though every time I've heard one on the road, I'm not impressed with the sound. Don't mind that it's loud, but it just sounds anemic, not like your average diesel with that nice low sound. I guess it would be silly for me to pick a motor based on it's sound, but that is a bit of a consideration. Thanks in advance!
Yes, I drive a gasser, but I'm compiling information, and hopefully soon, parts, to swap in an Isuzu I4. Black smoke, here I come! :weld: |
| Sponsored Links | |||
Advertisement | |||
#2 |
I have never worked on one but the way I understand it is basicaly a v-6 version of the vt365 or 6.0 powerstroke. I would guess that some of the performance parts would swap over between the engines. It sounds like a neat project. good luck
Ross Show-ME Smokers 2.6 modified street pulling truck "The Lone Stroke" My Videos 1996 f350, powerstroke, 4x4, 5-speed, 4.56 gears, Swamps 450/600 injectors, Swamps BFH turbo, Swamps Idm, Swamps tunes, BTS oil, SBC clutch, studs, springs, tubes, air to water intercooler, fuel system, factory rods! ![]() Tow Rig 1997 f350, srw, reg cab, 4x4, 5 speed, 4.10 gears, 3in down pipe, straight pipe, mystery chip. Becker Brothers Enterprises |
#3 |
Super Moderator
![]() Join Date: May 2005
What about the 4Bd1t or 2t from an older NPR Isuzu? They had decent power, but not really supported by the aftermarket for wild hp numbers. Finding a VT this early in production may be near impossible, until wrecked ones get to wrecking yards.
Dale my daily driver:67 F100, 300 4V, 4 spd. work rigs: 94 IH 4900, DT466(originally 230hp), #0 fuel plate, tighter gov springs, 22* timing or, 06 IH 7400, DT466E, 300hp My Low Buck fuel rate site: www.freewebs.com/nevrenufhp |
#4 | |
I agree it might be difficult, if not impossible to find a VT currently, but it's interesting none the less. My goals are somewhere around 300-350 HP, and something that'll actually fit in my engine compartment. So far, engines that I know will fit physically are the 4H series Isuzu's, the VT275, a Cummins 4BT (also too loud/rough for my liking), and a late model GM 6.2 or 6.5L. The 4BT, and the 6.2/6.5's seem to have pretty good aftermarket support, or at least a good community of people who know the motors well, and can tweak them. I really like the 4H series Isuzu's, and could look past the sound if I knew I could get decent power out of them, but I can already find more tuning information about any other motor on that list that I can about the Isuzu's.
#5 |
the vt 275 is also in fords version of the cf international truck its basicly fords truck from nose to tail with navistars engine fords auto trans is behind it both the ford and navistar versions are identical other than the name on the grille... so far they seem like a sweet little engine our dealer runs a few as parts delivery trucks and we never see them in the shop except for oil changes.
as far as mods and hp potential no idea
84 f 250 ex cab 4x4 w/92 7.3 ATS turbo 3 in exhaust no muffler K&N filter pumped tweaked 25% Navistar Diesel electronics specialist( mechanic..lol) 19 years at local dealer Photos of The Beast DOC |
#6 |
Euro Sparky/ Wrencher
right now as i am speaking the VT275 is rated at 200 hp and 440 ft tq and this is basied on IH rating
yes the VT275 use the Ford Toqureshift 5 speed auto and seems working pretty well for that useage you will have some how more tq than hp then what you got in your Expolder truck weight wise i am not sure but it probablly be little more hevery than large gas engine you have in your truck you will need the wiring harness with this engine and the ecu because it will read diffrent than what the gasser will do if you go this route keep in your mind you will have to change few things along the way Merci , Marc |
#7 |
also keep in mind the vt275 is the engine navistar designed FOR ford to put in the f 150 then ford backed out of the deal as such it should fit in a light duty truck fairly well
#8 |
Super Moderator
![]() Join Date: Dec 2008
Let's just say you would not have the FIRST VT275 powered Explorer :evil:
'93 F-250 HD, 7.3L IDI, 5spd - FARM TRUCK I Support: Trailer brakes an every axle over the towing vehicle's GVW; CDLs for RVers; Safety inspections for ALL vehicles and 6 axle trucks (97K GVW proposal). Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote - Benjamin Franklin I vote for LIBERTY! |
#9 | |
I don't suppose you could supply details?
#10 |
Supporting Vendor
I have seen a couple of Expeditions with the 4.5 in them but no Explorers
06 F-350 Crewcab 5.9 CR 03 Excursion 6.0 99 F-250 7.3 97 Dodge 3500 5.9 95 F-250 7.3 |
| Sponsored Links | |
Advertisement | |
