air compressor governor question - TheDieselGarage.com
Thread Details Posted by dondiesel444, this thread has received 11 replies and been viewed 10858 times.
Old 02-15-2007, 09:24 PM   #1
dondiesel444
dondiesel444's Avatar
how can I adjust the pressure the governor allows the compressor to build? I installed a new compressor yesterday, and at first the pressure would build to 130 psi a few times (which is high I know) but now it will only build to about 110-115 (the 2 needles aren't even with each other, never were).
I removed the plastic cap on the end of the governor, and there is a lock nut and the bolt has a slot to turn it. I'm guessing thats all I need to do, BUT if I push on the end where the bolt/jam nut are the whole inside of the governor moves, like there is some free-play in there. do I have to set it at a certain free-play, or just adjust the bolt/jam nut to I get the desired pressure.
I know this is probably easy but I don't want to screw anything up.
1997 Western Star 4964FX double frame tri-axle dump truck, 3406C Cat Power, 8LL, 46K rears on Chalmers, lots of lights, Sirius radio
2001 F-250 PSD CC 4X4 Lariet, 97k miles, DP Tuner PCM, 3" lift, 305/70R16's on 16x10 wheels, 6637 air filter, straight piped, more to come.
dondiesel444 is offline   Reply With Quote
Old 02-16-2007, 12:04 AM   #2
Lmackattack
Highway to Hell
Lmackattack's Avatar
130 is normal for todays trucks 120 was the cut out on older trucks but it seams that they upped the psi cut out a little.
I think the tighter you turn in the bolt screw etc.. the higher the cut out will be. Its been a few years but I think thats how it works.
last week I started the truck after 4 weeks of sitting It started fine but the compressor never cut out . I was at 155 psi!! I pushed inthe trailer emergency and drained the air tanks to get it back down. I was worried about it that high and still very cold.
1978 MACK RS700L
285 HP @2100 RPM 1080 TORQUE. @1200 RPM
2 STICK 6 SPEED, 4.17 REARS ON 34K CAMELBACK SPRINGS,206"WB, 4" STRAIGHT STACKS BLOWING BLACK,
OH...AND A FEW TWISTS OF THE FUEL SCREWS ....THANKS AGAIN... FJH!
Lmackattack is offline   Reply With Quote
Old 02-16-2007, 12:16 AM   #3
Hybrid_4x4_Superduty
TDG Mafia Member #64!
Hybrid_4x4_Superduty's Avatar
Send a message via Yahoo to Hybrid_4x4_Superduty
Not saying its good on things but we had a freightliner century that had over 175 in the tanks, the truck was hooked up to the shop air that cut out at 200 so we got lucky with no damage.
-ADAM-
2008 Ford F-350 King Ranch, 4x4, 6.4L, Powerstroke Diesel, Torqueshift, Spartan Tuned, 4in FloPro Straight Duals, Afe Stg 2 Intake, Chromed & Tinted out!!! 115k Miles!
Hybrid_4x4_Superduty is offline   Reply With Quote
Old 02-16-2007, 01:49 AM   #4
chris142
Your supposed to have a pop off valve in the system. If I remember corectly it should pop @ 150 psi.
chris142 is offline   Reply With Quote
Old 02-16-2007, 10:09 PM   #5
John_G
Super Moderator
John_G's Avatar
To answer your question, and it is a good one, turn the screw with the slot in it (under the plastic cover) OUTWARD to increase the govornor cut-out pressure setting, and INWARD to decrease it. When you are satisfied with the setting, tighten the jam-nut while holding the slotted screw firmly, then replace the plastic cover.
Cut-out must be measured with an accurate gauge, and after the compressor has stopped pumping. So, don't measure cut-in. The differential pressure (cut-out minus cut-in) is not adjustable.
130 PSI is the current standard, but anything from 120 to 130 is acceptable.
Every vehicle with air brakes leaves the factory with a safety valve that as others have mentioned, "pops" at 150 PSI to prevent a tank from exploding. Most modern systems have TWO. One on the "wet" tank (as ALL systems MUST have), and another at the compressor discharge to save the compressor in the event of a discharge line freeze-up.
I vote for LIBERTY!
Old 02-17-2007, 12:13 AM   #6
dondiesel444
thanks John_G, I'll give that a try. I appreciate all the help!!
Old 02-17-2007, 02:01 AM   #7
bmoeller
bmoeller's Avatar
There isn't much inside of the governor. Basically a plastic or nylon plunger with a couple of o-rings on it, a spring.
"Obama = Hoax and Chains"
Old 03-20-2007, 04:37 AM   #8
This thing never popped, mabye its something to do with the air dryer? if so you have to have the key on. who knows:squish
-ADAM-
Old 03-20-2007, 07:18 AM   #9
bmoeller
bmoeller's Avatar
Shouldn't need to have the key on for the pressure relief. It is a spring loaded valve.
Old 03-20-2007, 09:53 PM   #10
dondiesel444
when I installed a new governor on my old Mack, the first time I started it the pressure went to at least 150 and then there was a wierd noise as the pressure blew off somewhere in the system. I'd think all trucks would have this as a safety...
