common 7.3L problems after 100K ?? ..... - TheDieselGarage.com
Thread Details Posted by triton, this thread has received 19 replies and been viewed 25030 times.
Old 02-28-2007, 03:15 PM   #1
triton
I'm hoping you guys can give me some pointers as to what typical problems are with a 7.3L DI.
It's in my work van which has a Quigley 4x4 conversion and recently turned 100K. I don't mind doing preventative maintenance even if the part isn't bad yet.
I've purchased glow plugs w/controller, CPS & belt to be replaced so far.
Besides the obvious like fluid changing, while I'm in motor.... are there another other parts that could use to be replaced or things done? EGR valve, wastegate, valve adjustment, injectors for example. I've looked and looked for a break down of this motor online but, have yet to find it. There also isn't a lot of talk about van here.
I bought it with 60K on the motor so, I'm not sure that anything other than oil changes have been done.
triton is offline   Reply With Quote
Old 02-28-2007, 03:42 PM   #2
imported_DieselKid
Send a message via AIM to imported_DieselKid
I would deffinetly look at the water pump, those seem to go out right after a 100k, grab the fan and see if there is any play in it.
MINE
2003 F-250 SCSB
SCT Xcal2(ID), Regulated Return (Built by me, Pics) 4" Exhaust, Coolant Filter
SOLD
2000 Ford F-250 SCLB Truck Pics
DADS
2004 Ford F-350 CCLB Dually Truck Pic Truck and Trailer Pic
SCT by Innovative Diesel, ARP Headstuds (Installed By Me Install Pics), Complete EGR Block Off, Crossover Fuel Line, AFE Stage 1 Filter, 5" Exhaust, Isspro Triple Guage Pillar
imported_DieselKid is offline   Reply With Quote
Old 02-28-2007, 03:54 PM   #3
CSIPSD
CSIPSD's Avatar
Thats a strech... If you have been adding the additive into the coolant then the water pump will be fine. Might add a Coolant filter for good measure. Really other then fluid changes there is no adjustments to the rig.
01 F-250 SC PSD,210k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, GTS Hybrid injectors, Studs, 910 Valve springs, Forged rods Water injection,Swamps tuned, MBRP 4" dual's, Aero, 6" tip's, 100 axl tank, 4" Revtek lift, 37-14.50-17 TOYO MT's 469hp and 1068tq...
ISSPRO PERFORMAX GAUGES
CSIPSD is offline   Reply With Quote
Old 02-28-2007, 04:38 PM   #4
kainers
kainers
220k water pump.I did have the tranny give up at 74k and lost multipule alternators all the way up till my current mileage.Hubs gave up along with the wheel bearings around 240k.Front end steering parts have been rebuilt once tie rod ends steering box blah blah.Steering box is in need again at 270k.Those OEM's seem to last about 100k miles then start to wear out.I have swapped inj's 3 times non due to performace.1 actual turbo at around 190k it wasn't a stocker it was the BB
Thats about it.Going off memory drive about 50k+- a year.
Mike
02 F-350 CC Lariat Auto 313k miles
436HP 886TQ 5/26/07 Mustang
13.64ET 97.97 mph in the QTR at 7800lbs
PICS
kainers is offline   Reply With Quote
Old 02-28-2007, 06:30 PM   #5
gregrob
99,000 miles right now.
So far: Alternator, CPS, Torque Converter, and 1 U-joint.
After 100K :shrug:
-02 CC SB Terminator HPOS, 180cc singles, GTP-38R, 4" ex, ITP fuel, AFE stage 2, bunch of other crap that probably doesn't make it any faster
gregrob is offline   Reply With Quote
Old 02-28-2007, 08:17 PM   #6
triton
Thanks for the replies guys.
Like kainers my tranny went out at 76K so it's ok now with a nice new 3yr. warranty :deal:
I don't think a van pulls as much current as a truck with all it's instruments does so, I guess I'm ok with the alternator... for now.
The fan feels as tight as it can be so, hopefully I'm ok with the W/P
It's nice to know not a whole lot needs to be done to keep it goin'. On a quick inspection I did see I'm going to need a new rear seal on the transfer. That's probably something to watch out for to along with the U-joints at it's age.
Thanks again !!
Old 03-01-2007, 12:55 AM   #7
kainers
kainers
I haven't touched my u-joints they are still factory.The rear end was replaced at 150k due to accident damage.Haven't touched the transfer case front end front axles or U-joints there either.
Old 03-01-2007, 11:58 AM   #8
DZLJIM
I don't think Ford should have sold any trucks till they were 'Broken In' at 100k miles.
DZLJIM is offline   Reply With Quote
Old 03-01-2007, 12:37 PM   #9
StrokinSnyd
TDG MAFIA #94
StrokinSnyd's Avatar
Send a message via MSN to StrokinSnyd
keep an eye on the water pump definitly. there are 4 guys arround me that have 98-00 strokers that all had the water pump go out just after the 100 k mark. mine went out about 98k. keep an ehe on the fan for an idea on the w/p situation. if/when it dose go the fan nut is a pain in the a** to git off. use a air chissel to loosen it. (thats the best way ive *** up with after helping replace 4 of them.)
96 Dodge Cummins EC LB 5 spd big valve springs, full cut DV's, Big sticks, phat shaft turbo....yada yada yada.... plain and simple, it goes fast and pulls whatever
StrokinSnyd is offline   Reply With Quote
Old 03-01-2007, 04:03 PM   #10
StrokerDude
StrokerDude's Avatar
a better way to remove fan.
Use the vise grips with the chain on them... put it around the pulley and use a BFW (big wrench), put the housing in a vise, and there you have it. If you get the vise grips good and tight, it will not slide and scratch up the pulley. When I finally did that to take it off, it only took seconds. I supposed you could do that with thepump still on the motor. I already had mine pulled when I got around to that method.
Alex C.
R.I.P. 2006 F-250 CC SB Fx4. w/ 500 RWHP *stolen 7/15/2010*
1990 F350 CCLB 4x4 -- 24V Cummins, 200hp DDP's, SuperB over S475-sx3, Cam and valvesprings, Spe-rite Convertor, Billet input.
www.JeffersonStateDiesel.com --- http://en.wikipedia.org/wiki/State_of_Jefferson
Singles Club # 182 - B.O.M.B Squad # 14 - American Club #23
StrokerDude is offline   Reply With Quote
