Turn up an older Cummins? - TheDieselGarage.com
Thread Details Posted by ash_flat_diesel, this thread has received 38 replies and been viewed 18672 times.
Old 03-25-2007, 01:19 AM   #1
ash_flat_diesel
Send a message via Yahoo to ash_flat_diesel
I think its a 400 Cummins but not sure exactly. Its in a Tri Axle International Dump truck about mid 80's. What can be done to it to help with power? It makes hardly any smoke at all now. Thanks!
ash_flat_diesel is offline   Reply With Quote
Old 03-25-2007, 01:26 AM   #2
John_G
Super Moderator
John_G's Avatar
More power is rather simple on those older engines.
If you want smoke, that's something else entirely.
Lack of smoke does NOT mean lack of power, in fact, it means you are getting power from ALL the fuel you are using, instead of blowing 1/2 of the fuel out the stack as soot
I vote for LIBERTY!
Old 03-25-2007, 01:28 AM   #3
bmoeller
bmoeller's Avatar
Don't exactly recommend doing this,but, if it has a PT pump, just put a pair of vice grips on the fuel return line. Just don't pinch it off completely. It raises the fuel pressure, and gives more power.
JohnG is right, though.
"Obama = Hoax and Chains"
Old 03-25-2007, 03:30 AM   #4
curtmu
What is your gov setting. Sometimes lack of power is just the engine not winding high enough.
Curtmu
Northwestern Indiana Union Millwright & Member of the Gravy Sucking Pigs
curtmu is offline   Reply With Quote
Old 03-28-2007, 12:37 AM   #5
ash_flat_diesel
Thanks guys. I will check a few things & get back to ya.
Old 03-28-2007, 01:38 AM   #6
chris142
There are "Buttons" in the pump you can change to get more fuel to it. I heard that setting the injectors loose will give it a little more fuel too.
Edit: Finding buttons can be a little hard. Probly due to emission reasons.
chris142 is offline   Reply With Quote
Old 03-29-2007, 12:07 AM   #7
curtmu
The pump uses a spring and washers to change the governor setting. There is a screw in the middle of the governor spring that I think raises the pump pressure. The more washers the faster the governor setting, there are also different springs rates to course adjust the setting.
Curtmu
Old 03-29-2007, 12:28 AM   #8
chris142
The screw in the govenor plunger adjusts the idle speed only.
Old 03-29-2007, 12:33 AM   #9
kevin
hot rod pete
kevin's Avatar
put a different button in your fuel pump,then your truck will haul ***** :smoke
kevin is offline   Reply With Quote
Old 03-29-2007, 12:37 AM   #10
chris142
Ya dats what I said:Thumbup: But you can't just buy a button anymore. At least not here in SoCal, Better off finding a pump to steal the button out of.
Tags
855 more power
