Best fuel additive for my 7.3? - TheDieselGarage.com
Thread Details Posted by jebsurf, this thread has received 46 replies and been viewed 8945 times.
Old 04-09-2007, 03:06 AM   #1
jebsurf
What are you guys running and how do you like it?
Nitrous is like wanting to sleep with a hot girl that you know she has a STD..... You know you want to hit it but you are scared of the out come.
In my stable now :
early 99 psd regcab with 120k miles.Mods_ sct tadds tunes and afe stage 2 and my magnaflow 4''turbo back and,built tranny (triple disk converter, alto clutches w/ powerpack, and a racer x transgo tugger hd kit) :Thumbup: Killed the stock one on 5/14/07***
2005 honda accord v6 power everything leather
The past rides:
95 honda accord(flipped that one 5 times),85 toyota 4x4 straight axle,95 acura integra ls,86 chevy surb 2500 4x4,95 ford exploder 4x4,96 nissan hardbody 4x4 reg cab,96 integra gsr,2003 cobra s/c 500rwhp
jebsurf is offline   Reply With Quote
Old 04-09-2007, 03:31 AM   #2
POWER STROKE 99
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
I run Power service........seems to do fine
1999 F-350 7.3L CREW CAB DUALLY, LIVE TUNING BY DP TUNER, 180cc SINGLES, REGULATED RETURN FUEL SYSTEM, PRE-PUMP AND IN TANK FUEL SYSTEM AND OVER BOOST ANNIHILATOR BY ITP DIESEL, DR MINI PACKS TO LEVEL THE RIDE, 6" AUSSIE STACKS BY GRANDROCK, AFE STAGE II INTAKE, TURBO MODS BY HTT, 05 HEAD LIGHT CONVERSION WITH UPGRADE WIRING HARNESS BY DFUSER, 05 GRILL, 05 6 SPEED UPGRADE, SHORT THROW SHIFTER AND LUK CLUTCH BY MIDWEST TRANSMISSION , CCV MOD, LINE-X , QUAD POD FILLED WITH AUTO METER C2 GUAGES, CUSTOM SLED PULLING HITCH, COOLANT FILTER SETUP
POWER STROKE 99 is offline   Reply With Quote
Old 04-09-2007, 03:40 AM   #3
4cstr
Posts: n/a
Points: 0 [Check]
Look at this thread in the Dodge section.
Old 04-09-2007, 03:58 AM   #4
TowRig
Send a message via AIM to TowRig
I run powerservice also, the information on powerservice had been removed from that site...so what does everyone think of powerservice?
AJ
2000 F-250 PSD Extended Cab Short Bed
-AutoMeter Gauges;Pyro, Tranny, Boost, Rear Diff, Fuel Pres, Air Pres.
-MBRP Turbo back, muffler delete
-AFE Stage II
-ITP Oil HPX Line
-CCV Mod
-AIH Delete
Trail rig: 1990 Jeep Cherokee, 4.0 I6, NP231 w/ SYE, Clayton Off road Long arm Suspension with coil conversion in rear, Full width Dana 44 up front(ARB, Warn Hubs and US Alloys Chromoly Axle shafts), full width Dana 60 in rear with Spool. 4.88 Gears all around, 36 inch Interco Bias Irok's, and lots of trail damage. :
TowRig is offline   Reply With Quote
Old 04-09-2007, 03:21 PM   #5
Andy
DYING BREED
I personally like to use Howels.
97' Ford F-350 powerstroke, automatic tranmision with shift kit, with 410 gears. BFG 285-75-16 custom 4 inch DUAL exhaust with 4 inch downpipe, Air intake with 4 inch inlet, 3 inch body lift to fit the toys, HTPS turbo, Super-duty pedistal and up pipes with SD spider, marine fuel pump with custom fuel system from tank to engine, 2003 high pressure oil pump, cometic head gaskets, Head STUDS, TS six position chip with E-LITES burns and 230cc injectors oh yeah all the gauges needed
Andy is offline   Reply With Quote
Old 04-09-2007, 03:43 PM   #6
plainredtruck
plainredtruck's Avatar
Images: 11
I used to use PowerService until commercial B-20 became available locally.
I don't put anything else in now.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline   Reply With Quote
Old 04-09-2007, 03:54 PM   #7
coreystroke02
coreystroke02
coreystroke02's Avatar
I like Stanadyne myself.
2002 F-250 Crew Cab 4x4, DP-Tuner 60 tow, 80 eco, 120 race, and 140 smoke, Banks wastegate, Banks Transcommand(bypassed), 4" SS exhaust, AFE stage 2 intake, Superlift 6" lift, 37" Nitto Terra Grapplers, 18" Motto wheels, EGT and Boost gauges.
coreystroke02 is offline   Reply With Quote
Old 04-09-2007, 04:28 PM   #8
tjl
tjl's Avatar
I use stanadyne.
Tim
'96 f350 cc dually, 5 speed w/ short throw shifter, stage 1 injectors, '03 sd intercooler, d66 turbo, DP Tuner F5 chip (stock, high idle, tow, econo, extreme) modified IDM, CCV mod, gutted EBPV
343 hp
670 tq
Dually Club #20
B.O.M.B. Squad #7
tjl is offline   Reply With Quote
Old 04-09-2007, 06:12 PM   #9
Shorty
Just another mud duck...
So after reading almost the whole thread... correct me if I am wrong, but it is basically saying to use 2 stroke no ash TCW-3 oil in every tank about 16 oz and only use the Stanadyne, Ps, and likes occasionally to clean out the injectors.... Right?
Later Daze,
Shorty
:93C_peelo
Shorty is offline   Reply With Quote
Old 04-09-2007, 06:26 PM   #10
Dieselwrencher
TDG Mafia Member #56
Dieselwrencher's Avatar
I use powerservice regularly and I use stanadyne to clean the injectors or I use their cetane boost depending on what I am doing.
2005 Dodge 3500 CC LB 5.9 48RE Smarty 5" Silverline Exhaust AFE Stage 2 305/70/17 Nitto Grapplers Tinted Windows
Putco light bar
1968 Corvette Coupe 5.9 cummins 47RH with Goerend parts assembled by Gilmore Performance 180 pump built by Smokem 12pt cage Ford 9" with spool 35 spline moser axles pro gears Quick Time DOT drag slicks tilt front end soon to get paint and more air.
1995 F-350 Crew Cab soon to be 6 door DRW Hauler project: 5.9 conversion in progress ZF5 speed destroked adaptor plate King pin D60 3.55 gears
Dieselwrencher is offline   Reply With Quote
