Chevy Cummins Conversion Package Check it out - TheDieselGarage.com
Go Back   TheDieselGarage.com > Diesel Conversion > Diesel Conversion
Thread Details Posted by Dieselwrencher, this thread has received 13 replies and been viewed 38272 times.
Old 04-11-2007, 01:52 AM   #1
Dieselwrencher
TDG Mafia Member #56
Dieselwrencher's Avatar
Here you go guys, the whole kitten cabootle. On ebay I found a brand new 5.9 Cummins remaned by cummins engine. It is the rotary pump style but that is ok. Here is what is stated in the auction. It has a starting bid of $5500 with no reserve so this is a great deal. That is the price for an engine let alone anything else. This would be a great deal for someone. Good luck.
http://cgi.ebay.com/ebaymotors/ws/eB...3428&rd=1&rd=1
Ebay auction# 320101463428
The engine is a 6BT, rotary pump (EASY TO INSTALL, NO CHARGE AIR COOLER TO FIT AND PLUMB!). Engine data plate lists the CPL as 804. The engine is a Cummins Factory Reman engine, built in Charleston, SC. It has ZERO miles. It has been periodically started to ensure it remains FRESH. Engine is complete (everything you see in the pictures) and includes the following accessories:
Chevy transmission adapter, Turbo 400 flexplate, fan hub, accessory pulley (to drive the air conditioning compressor), water inlet (lower radiator hose connection), Dodge style, rear sump oil pan, long oil dipstick and tube, new Nippondenso 3KW starter, belt tensioner.
The repower kit contains everything pictured, including:
ENGINE MOUNTS (bolts to stock GM isolators), Vacuum pump/Power Steering pump combo (New, Dodge setup), Low mount, rear out turbo exhaust manifold (you will have to fab your own air crossover if you use this exhaust manifold), exhaust pipe with flex section and clamp, air inlet elbows, used Delco 10 si alternator and bracket, accessory bracket (for mounting air conditioning compressor, belt.
The transmission is a FRESHLY built with ALL HEAVY DUTY, HIGH PERFORMANCE REBUILD PARTS, Chevy bolt pattern (not B.O.P) Turbo 400. It is built with an ALLISON, high capacity torque converter, ALLSION governor weights (for proper shift points), cast aluminum transmission pan, which incorporates a support to the transmission adapter. Also included is the torque converter to flexplate adapter, mechanical modulator and cable, dipstick tube (no dipstick), and THM 400 yoke.
This will get your gas guzzling (or weak, unreliable diesel) engine replaced with a REAL ENGINE. Enjoy power, dependability and econnomy in your classic GM truck. Give your Chevy "heartbeat" the rattle of a Dodge!
2005 Dodge 3500 CC LB 5.9 48RE Smarty 5" Silverline Exhaust AFE Stage 2 305/70/17 Nitto Grapplers Tinted Windows
Putco light bar
1968 Corvette Coupe 5.9 cummins 47RH with Goerend parts assembled by Gilmore Performance 180 pump built by Smokem 12pt cage Ford 9" with spool 35 spline moser axles pro gears Quick Time DOT drag slicks tilt front end soon to get paint and more air.
1995 F-350 Crew Cab soon to be 6 door DRW Hauler project: 5.9 conversion in progress ZF5 speed destroked adaptor plate King pin D60 3.55 gears
Dieselwrencher is offline   Reply With Quote
Old 04-11-2007, 02:25 AM   #2
Dazedandconfused
Cummins Man
Dazedandconfused's Avatar
Wish I had the cash.
04 Duramax
93 Dodge D-250
91 Dodge D-350
84 Dodge D-150
Dazedandconfused is offline   Reply With Quote
Old 04-13-2007, 10:59 PM   #3
ARAMP1
ARAMP1's Avatar
I'm thinking about doing something like that to my truck.
Click image for larger version
ARAMP1 is offline   Reply With Quote
Old 04-14-2007, 02:24 AM   #4
Dieselwrencher
Nice truck, that would be sweet. My brother's truck is the same except with rust and a cummins. It has the next older grille/ headlight combo but it is sweet.
Putco light bar
Old 04-14-2007, 02:39 AM   #5
Dazedandconfused
Cummins Man
I had one once upon a time and then I got rid of it, man that was stupid.
Name:	old truck 7.JPG
ID:	9597   Click image for larger version
Name:	old truck 3.JPG
ID:	9598   Click image for larger version
Name:	old truck 6.JPG
04 Duramax
93 Dodge D-250
91 Dodge D-350
84 Dodge D-150
Old 04-14-2007, 02:46 AM   #6
86 1 tonhauler
TDG MAFIA MEMBER #72
86 1 tonhauler's Avatar
Send a message via Yahoo to 86 1 tonhauler
wow what a deal
1986 f-350 6.9 dually str8 piped ,maxed out injection pump ,bucket seats, diamond plate flat bed,propane injection, on board aircompressor, train horns,goose neck plate, future mod , custom built turbo kit with intercooler and dual 4" miter cut stacks TDG DUALLY CLUB #5
RIDIN DIRTY #44
01 chevy 2500 HD 4x4 duramax
anybody got any used 4" miter cut stack laying around? pm me if ya do
quote: BARRY1ME: BTW I love your sig about engineers....but it should be changed to, if the engineers believe it isnt broke it doesnt have enough content removed from it. And thats the truth! (FYI I am engineer and work for Ford lol) At Ford the goal is to make the part barely good enough to passing DV (developmental validation) testing....If it passes way beyond the test then the part was overengineered, and content needs to be removed to reduce cost.
I CANT KEEP UP!!! HELP!!!
86 1 tonhauler is offline   Reply With Quote
Old 04-14-2007, 06:14 AM   #7
Dieselwrencher
Wow cool truck Dazed!
Putco light bar
Old 04-14-2007, 04:47 PM   #8
Dazedandconfused
Cummins Man
Yes it was but i was young and stupid and wanting a new truck so when that one broke I parted it out and bought a new truck. I will build another one of these days.
04 Duramax
93 Dodge D-250
91 Dodge D-350
84 Dodge D-150
Old 04-17-2007, 01:58 AM   #9
01duramax6spd
01duramax6spd's Avatar
I ran into a guy the other day that has 6 K30's with CTD's in them :Thumbup: . All have 5spd's and all have 7100 Bosch pumps :Thumbup: .
01 2500 Duramax/ZF6,returned to daily driver590/995
03 3500 Duramax/Ally S/C IV EFI Live {Brothers truck}
04 3500 Duramax/Ally EFI Live,feed truck with 3 bale Hydra-Bed,very sick trans
06 4500 Duramax/Ally 4x4 Monroe,EFI Live,Danville turbo, CM flatbed
11 2500 Duramax/Ally 4x4 H&S tuned and deleted {GF's truck}
13 3500 Duramax/Ally 4x4 stock for a very short time
Some Green Equipment and a heard of Black Angus cows
01duramax6spd is offline   Reply With Quote
Old 04-19-2007, 02:07 AM   #10
thejdman04
Seriously would hae want to part w/any?
1996 Gmc k2500 4x4 6.5 turbo diesel, with mods Blew the head gasket, put all new heads, valves, injecotrs gaskets etc on the truck only to get it together and find out it had no oil pressure, and sounded horrible (pry a spun bearing). SOLD
2007 chevrolet 2500hd Duramax loaded. GM LEMON BUYBACK
2007 Chevrolet LBZ 1 ton crew cab 8ft box
on star, xm, tow mirrors, 145 amp alt,
#23 Singles Club
thejdman04 is offline   Reply With Quote
