dt466e blue cam sensor swap - TheDieselGarage.com
Go Back   TheDieselGarage.com > Ford Diesel & Truck Discussions > General Ford Truck and Excursion
Thread Details Posted by sidssm, this thread has received 11 replies and been viewed 3658 times.
Old 04-17-2007, 06:03 AM   #1
sidssm
sidssm's Avatar
here is a sight selling this blue dt466e cam sensor it says it is better along with better performance
has anyone done this and if so did it help i would like everyones opinion on this thanks seth
sidssm is offline   Reply With Quote
Old 04-17-2007, 07:22 AM   #2
sidssm
sidssm's Avatar
here is a sight selling this blue dt466e cam sensor it says it is better along with better performance here is the site http://www.puredieselpower.com/catal...sel-p-126.html
Old 04-17-2007, 11:55 PM   #3
gtspowerstroke
Send a message via Yahoo to gtspowerstroke
As I recall it was originally thought that it advanced timing a couple degrees improving performance. However come to find out it actually retards timeing a couple degrees giving the opposite effect. Another case of someone finding something and preaching it like it's gospel before they find out the truth behind it and a lot of people jumping on the bandwaggon only to find out that they just blew their hard earned money on snake oil.
'96 F-250 Extended Cab, GT'S injectors, GT'S intercooler install kit, custom turbo kit with a little HX40, Swamp's BIGEST oil.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline   Reply With Quote
Old 04-18-2007, 01:58 AM   #4
pontiacross
pontiacross's Avatar
I don't think they last any longer eather I've replaced just as many in 466's as I have in 444E's
Ross
Show-ME Smokers 2.6 modified street pulling truck "The Lone Stroke" My Videos
1996 f350, powerstroke, 4x4, 5-speed, 4.56 gears, Swamps 450/600 injectors, Swamps BFH turbo, Swamps Idm, Swamps tunes, BTS oil, SBC clutch, studs, springs, tubes, air to water intercooler, fuel system, factory rods!
Tow Rig
1997 f350, srw, reg cab, 4x4, 5 speed, 4.10 gears, 3in down pipe, straight pipe, mystery chip.
Becker Brothers Enterprises
pontiacross is offline   Reply With Quote
Old 04-18-2007, 02:08 PM   #5
sidssm
sidssm's Avatar
thanks for replys i have this posted in other forums also and i have some people stating that on dyno runs this blue sensor will retard timing causing a drop 5-30 hp but it causes that plus a little in torque gain. that was said in my post on 7.3 discussion
Old 04-18-2007, 02:21 PM   #6
racehauler
For future reference it is best to post a question about something in one forum. If it a 7.3 specific question the 7.3 forum would be the best place to ask. A thread can always be moved if it is in the wrong forum.
Eric
96 F-350 CC Dually My TDG Gallery
B codes, head studs, Comp 910 valve springs, stock turbo w/ 1.00 turbine housing
6.0 IC, NAPA 6637 air filter, AeroTurbine 4040XL, ITP Overboost Annihilator,
Quadzilla Commander, electric fuel system w/ regulated return
coolant filter, 203* thermostat
Dually Club Member #53
346.7HP, 852.1TQ 12/15/07 Greeley, CO w/ stage 1 injectors and Wildman tunes
racehauler is offline   Reply With Quote
Old 04-19-2007, 01:13 PM   #7
FOMOGO
Diesel Addict
Well I will put this to bed on more time. Jody Tipton did Cylinder Pressure testing on My truck in February of last year with a Blue CPS and a Black CPS. The blue CPS retards timing without question. When you look at the CP graph it runs uphill, peaks at max cylinder pressure, drops as the piston is leaving TDC, then rises again at the point of injection/combustion, then falls as the piston goes down. It should have only one peak not a peak, then a divot, then a second peak. In effect it is firing the injector after TDC (and max compression) and the flame front is chasing the piston down the bore. Where it should fire just before TDC and then push the piston down the bore.
And yes my truck idled smoother and ran in a manner that felt normal with the Blue CPS. I drove it to BTS and probably a total of 5,000 miles with the Blue CPS. But for the proper performance run the Black CPS and forget about the Blue CPS.
Lots of people are running the Blue and wont change back to a Black but they just don't understand what they are giving up.
Bottom line,The Black fires the injectors at maximum compression. The Blue fires after maximum compression has occurred and is in effect firing at a lower compression ratio. Thus less roughness..... Or so it seems.
Does this clear it up now?
If you want to read more here is a link to the original thread where I posted the results.
http://forums.thedieselstop.com/ubbt...t=1&PHPSESSID=
FOMOGO
2001 F-250 Lariat, Black, CC, SB, 304 / 627 on Dunbars Dyno...
2001 F-250 XL, White, Beater, Hauling Trash, 304 / 617 on Dunbars Dyno... One bald tire........ Thanks to Jody..........
2001 F-250 XL, Green, Project Truck...
Tuned by DP-Tuner, Fueled by ITP Diesel, Shifted by BTS
Ford makes it - International shakes it
FOMOGO is offline   Reply With Quote
Old 04-19-2007, 01:20 PM   #8
Docluv2577
Send a message via AIM to Docluv2577 Send a message via Yahoo to Docluv2577
I also thought this was put to bed already as I posted on another thread stating that we run the black 444e/psd sensrors in dt 466 engines to advance the timing and improve performance if the black is prefered in the dt and the dt blue sensors are more sensitive to correct air gap and fail just as often as the black sensors what makes anyone think te blue is prefered in the 444e/psd its snake oil as was said and not advisable period end of story
84 f 250 ex cab 4x4 w/92 7.3 ATS turbo 3 in exhaust no muffler K&N filter pumped tweaked 25%
Navistar Diesel electronics specialist( mechanic..lol) 19 years at local dealer
Photos of The Beast
DOC
Docluv2577 is offline   Reply With Quote
Old 04-19-2007, 01:30 PM   #9
FOMOGO
Diesel Addict
Exactly......
FOMOGO
Old 04-19-2007, 06:45 PM   #10
gtspowerstroke
It honestly doesn't matter how many times you think you put it to bed. New people are going to discover it much like the original poster found it on ebay and they are going to ask as they've never heard about it before.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
