56 ford f600 / 5.9 cummins w/5sp - TheDieselGarage.com
Go Back   TheDieselGarage.com > Diesel Conversion > Diesel Conversion
Thread Details Posted by rustyrelic, this thread has received 8 replies and been viewed 2761 times.
Old 05-12-2007, 08:03 AM   #1
rustyrelic
Hi everyone, Im new to diesel garage. I have a 56 ford f600 with 272 y-block 4sp main and 4sp aux trans with a 2sp rear end. Im a UPS driver, my favorite brown truck to drive was a freightliner with the cummins 5.9 and 5sp. I would like that engine and trans combination in my 56 ford. I am looking for a donor 2ton truck with the 6 lug bud wheels (correct wheels for 56 f600) so i can use the rear axle. (the 6.3 ratio axle thats in it now will not work with the diesel) any words of wisdom,thoughts,or suggestions would be greatly apprecaited, thanks in advance Reno
rustyrelic is offline   Reply With Quote
Old 05-12-2007, 11:46 AM   #2
Diesel Dog
Diesel Dog's Avatar
Sounds like a cool swap!! You could always add an overdrive unit to that and make the final drive more diesel friendly.
'00 cc f 350 a few mods, and a bts tranny.
Wet concrete, Hot Asphalt And Life Wait for no one
Diesel Dog is offline   Reply With Quote
Old 05-12-2007, 12:35 PM   #3
fellro86
If you figure on finding a newer truck with just six lugs, not likely to happen, they are all 8 or 10 lugs.
The workhorse: 86 F250 6.9 4 speed 4wd 4.10 gears, electric fuel pump
The other workhorse: 92 F350 2wd crew cab, 92 6BT Cummins, NV4500 and GV overdrive unit, 4.10 rear axle
fellro86 is offline   Reply With Quote
Old 05-12-2007, 08:32 PM   #4
nevrenufhp
Super Moderator
nevrenufhp's Avatar
One thing to consider, with a newer rear end you get bigger brakes(even rear disc), better/ higher gears, and can be hid behind an old school rim.
Dale
my daily driver:67 F100, 300 4V, cammed, 4 spd.
or, 08 VW R32.
work rigs: 94 IH 4900, DT466(originally 230hp), #0 fuel plate, tighter gov springs, 22* timing
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline   Reply With Quote
Old 05-13-2007, 06:02 AM   #5
keydl
The aux trans probably has gears to change the ratios so the rear end will work.
You can probably use a hydroboost to make the brakes useable for a lightweight, depending on the brakes at the wheels they may work well, if it is a hill country truck. A flat land truck generaly used the smaller brakes. Check the parts book to see what to look for.
There is a world of repro parts for the cab.
The 9.00x20 tires are collectors now, I don't remember the tubeless replacement size in the 60's but 8x19.5 is close I think. Depends on what the truck will be doing. Low pro 22.5's may look ok but the wheels will have to be made to order.
Are you going to redeck it?
For power steering the box from a P chassie may work or a Freightliner 70 although when the front end is in good shape and greased they steer ok.
I put a stack of miles on a F700 with a Cat and a 5 speed.
Sounds most excellent.
keydl
keydl is offline   Reply With Quote
Old 05-13-2007, 06:46 AM   #6
rustyrelic
56 f600
The aux trans has a 15% overdrive (500rpm drop) 55mph is 2700 rpm in my highest gear (OD) the truck is a old firetruck, the stock wheel is 9r22.5 (56 was the first year ford had a tubeless rim ) one of the UPS trucks would be a perfect donor as they have the 5.9 cummins 5sp, 2ton axles with disc brakes and the 6 lug bud wheels. The only problem is UPS does not sell any, we still have some ford 2ton chassis trucks with the 300 6cyl from the late 70's on the road making deliveries daily. I have seen some PG@E ford f700 with the 6 lug wheels .... thanks for the interest @ info
Old 05-13-2007, 01:58 PM   #7
Diesel Dog
Diesel Dog's Avatar
There are some other chassis munufacturers that used the 5.9. I know some of the step vans Grummin and I'm sure others too. You are not stuck wishing for a UPS truck, just may need to hunt some.
Good luck and keep us posted!!
Old 05-15-2007, 09:49 PM   #8
Dieselwrencher
TDG Mafia Member #56
Dieselwrencher's Avatar
A lot of RPS trucks used the gruman body and freightliner style chassis with the cummins. I know a guy that has a fed ex ground truck with a 1000 alison and a 24v for sale if you are interested. The truck was rolled but runs fine. I think it has 8 lugs though.
2005 Dodge 3500 CC LB 5.9 48RE Smarty 5" Silverline Exhaust AFE Stage 2 305/70/17 Nitto Grapplers Tinted Windows
Putco light bar
1968 Corvette Coupe 5.9 cummins 47RH with Goerend parts assembled by Gilmore Performance 180 pump built by Smokem 12pt cage Ford 9" with spool 35 spline moser axles pro gears Quick Time DOT drag slicks tilt front end soon to get paint and more air.
1995 F-350 Crew Cab soon to be 6 door DRW Hauler project: 5.9 conversion in progress ZF5 speed destroked adaptor plate King pin D60 3.55 gears
Dieselwrencher is offline   Reply With Quote
Old 05-16-2007, 03:31 AM   #9
rustyrelic
thanks Dieselwrencher1, but I have to have a truck with two sticks , The UPS truck I drive has the 1000 allison, mercedes diesel , freightliner chassis. My old truck had the 5.9 cummins and 5sp it was more fun to drive.
