Coolant Leak - TheDieselGarage.com
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 5.9L Cummins (2003-2007.5)
Thread Details Posted by Snowaholic, this thread has received 9 replies and been viewed 1475 times.
Old 07-09-2007, 03:31 PM   #1
Snowaholic
TDG Mafia - Booze Runner
Snowaholic's Avatar
Coolant Leak
Coolant Leak
For the past few weeks I’ve noticed a small puddle under my bell housing, which looked like water condensation that had been dripping…. It has been raining here so much that I really never thought much about it, until Saturday when for once it was dry for a change and I saw the small puddle again. I crawled under the truck to feel the liquid, and it was just a touch sticky, and had a very slight sweet smell to it, but was a very opaque red. Well I traced the moisture to a boot that connects the coolant lines together at the back of the engine just below the Heater Core…
My question is: Is there a better fix for this than getting it warranted? Has anyone else had this issue?
2007 Dodge 3500 MegaCab Laramie CTD 4x4 Patroit Blue Just a bunch of Go fast parts and programing
Snowaholic is offline   Reply With Quote
Old 07-09-2007, 08:53 PM   #2
WHITEPOWERstrok
i had the same issue! i searched and searched where mine was comin from, but couldnt fine it. mine hasnt done it in a couple weeks, so i dunno....
2003 Ford F350 FX4 6.0L - 2007 Front Clip
16" Custom Lift/Dual Reservoir shocks/Traction Bars
42x15R20 Swamper SX2's/20x12 black XD Rockstars
Road Armor Stealth front-rear Bumpers/AMP Powersteps
Recon Smoked LED everything/Smoked LED 1 pc Headlights
SCT Xcal3 Tuned by DJ/Josh's 190cc injectors/DJ's Fuel Intensifier
ARP headstuds/Dfuser EGR delete/7" black stack
94 2500 12v - Reg cab 4x4
Wicked Diesel S300-S400 twins/Airdog Fuel pump
DDP fireringed head/DDP injectors/ARP headstuds
ATS manifold/MBRP exhaust/AFE filter
Garmon "whoop azz" trans, and lots more
WHITEPOWERstrok is offline   Reply With Quote
Old 07-17-2007, 12:32 AM   #3
pos dodge
All you have to do is pressure check the coolant system. It is much easier to find a leak when the system is under pressure. The coolant should spooge everywhere if there is a leak. And if you want to start a leak just keep putting more pressure on the system.
06 cummins volant intake, ats arcflow, autometer gauges, banks cat back exhaust. mag hytec transmission pan, transgo shift kit, boost fooler, triple dog, 33 12.50 trxus sts, leveling kit, optional turbo silencer ring, fass system, VA C5.
ATS exhaust manifold and fluid damper coming this week.
pos dodge is offline   Reply With Quote
Old 11-12-2007, 01:14 PM   #4
chad_schieck
cschieck2002
Send a message via Yahoo to chad_schieck
Question
Anymore to this Thread. My brother has an 07 Mega Cab with 15k on it that has just learned this trick. Had to add about 2 gallons of antifreeze in the last 2.5 months. The leak is intermitant. Just curious if I should be looking for other problems as well. He says there is no loss of power or blowing white smoke or anything like that.
Thanks for the help- this is my first post on this forum.
2000 F350 Crew Cab, Automatic, 6.5" Pro Comp lift, dual front shocks, dual front steering stailizers, 315x75x16 BFG AT KO, 16x10 black Helo Maxx 6 rims, 3" ATS fender flares, 3.73 stock gears, 5" turbo back exhaust w/ straight pipe, Zoodad, Cold Air Intake, Edge Juice w/ Attitude monuted on A Pillar stacked with Edge Evolution Programmer, Cyberdyne tranny temp guage on pillar.
chad_schieck is offline   Reply With Quote
Old 11-12-2007, 01:40 PM   #5
WHITEPOWERstrok
i figured out that mine was the water pump, so the dealership replaced it under warranty...
Old 11-12-2007, 05:00 PM   #6
Fiftygrit
There is a common leak on the small hose, left hand side under the hood, heater hose I think, there is a small fitting, rubber hose off of a hard pipe, the clamps get loose and they leak, mine did it, and from all the forums, lots of them do it, try there first, feel around the connection if its wet, just snug up the clamps, stopped mine from leaking.
Fiftygrit is offline   Reply With Quote
Old 11-12-2007, 09:14 PM   #7
Snowaholic
Snowaholic's Avatar
I had the dealer fix it when they replaced my tranny. They said the same thing. I'm keeping an eye on it to see if it does it again. So far so good...
Old 11-12-2007, 10:23 PM   #8
catdude
I have 16k on mine and have the same leak on the little hose that connects the heater tubes issed:
07 Dodge 5.9 3500 DRW 4x4 QC 6spd:93C_peelo With a few mods.
catdude is offline   Reply With Quote
Old 11-13-2007, 04:48 PM   #9
Snowaholic
Snowaholic's Avatar
Mine was the bottom band clamp....
Old 11-14-2007, 09:09 PM   #10
SarahB
Mine Too!
I found that mine only did it intermitten, but it was also the loose clamp.
Sarah
SarahB is offline   Reply With Quote
