| Thread Details Posted by hccumminssmoke, this thread has received 35 replies and been viewed 609 times. |
#1 |
Official TDG Doctor
![]() Join Date: Oct 2006
Golf Cart
Im not sure where to post this, so I've decided to listen to what you guys have to say. I play golf constintly!!! Im going to college for it!!! So since I love diesel power so much I want to find a small like 1 cylinder or maybe 2 and swap it in!!! Would it work do you think? I saw the 700 Artic Cat in Diesel Power...so I would think a golf cart could work...Any input would be great!
Nathaniel
2K1 Black Sheep 3500, AUTO, DRW, 4X4 Electronics Air Dinosaur Fuel Pump A Way To Get It To The Ground Reflexxion Steel Cowl Hood Eagle 058 Wheels Kool Vue Power/Heated Towing Mirrors Other Doo Dads Custom Blacked Out Cab Lights Custom Blacked Out 3rd Brake Light Custom Blacked Out Fender Lights AVS Black Light Covers 2001 Pewter Rock 2500, 4x4, Crew Cab, Short Bed 03/04 Front Girly Named Transmission Black Tonneau Bed Cover 285/75/16 Nitto Terra Grappler Rubbers Fox Racing Sticker Cherry Poped Protected By: TDG Mafia Want A Duramax? Need Some Info?
Get To Learning |
#2 |
Thats going to be a pricey swap. There are some small diesel motors with transmissions becoming available now that you may be able to make work. Or since you don't need to go that fast, a generator engine may do well for you. You could always gear the rear end high, and then do a divorce mount transfercase to work as a 2 speed, but shift on the fly would be tricky without a clutch. I guess you get to start engine shopping.
Suck, Squeeze, Bang, Blow, 6 in a row makes her go! Blue VP truck with twins and a built tranny 09 6.7L QC LB stick, 4x4. |
#3 |
Official TDG Doctor
I found one new on Ebay for $400, its 10hp, but the only problem i see is when a golf cart stops it doesnt idle...it just stops ya know??? I also saw a pic of a cart in diesel power with a stack...the guys give me looks and yell when i pull up blowing smoke in the parking lot...what would they think if i let some out driving hole to hole!!!
Get To Learning |
#4 |
use a centifugal clutch like on a gocart or a snowmobile
#5 |
Roast some tire between holes on the back 9.
#6 |
TDG MAFIA MEMBER #72
u could use a clutch set up like the jd gators have
1986 f-350 6.9 dually str8 piped ,maxed out injection pump ,bucket seats, diamond plate flat bed,propane injection, on board aircompressor, train horns,goose neck plate, future mod , custom built turbo kit with intercooler and dual 4" miter cut stacks TDG DUALLY CLUB #5RIDIN DIRTY #44 01 chevy 2500 HD 4x4 duramax anybody got any used 4" miter cut stack laying around? pm me if ya do quote: BARRY1ME: BTW I love your sig about engineers....but it should be changed to, if the engineers believe it isnt broke it doesnt have enough content removed from it. And thats the truth! (FYI I am engineer and work for Ford lol) At Ford the goal is to make the part barely good enough to passing DV (developmental validation) testing....If it passes way beyond the test then the part was overengineered, and content needs to be removed to reduce cost. I CANT KEEP UP!!! HELP!!! |
#7 |
Official TDG Doctor
Well I guess I could just find a JD gator thats a diesel and do a swap like that...and Sean I think it would w/o a doubt roast some tires, but i really want it to blow some smoke!!! fab some twin stacks and run them out the sides away from the plastic...oh man!!!!
Nathaniel
Get To Learning |
#8 |
I think it'd be pretty hard to get to work. But if it did, it'd be awesome, and you'd get like 200 MPG.
[quote=HCCUMMINSSMOKE]I found one new on Ebay for $400, its 10hp, but the only problem i see is when a golf cart stops it doesnt idle...it just stops ya know???QUOTE] That's the way most golf carts are. I wouldn't mind doing something like that in the future because the party of the country where I want to live I have freinds that live about a mile in each direction. So I'd probably have to put some bigger tires on it because I'd probably have some driving I'd do in open fields. |
#9 |
Official TDG Doctor
yea...it would be cool every once in a while on the course, but id like to see it with like a 2 or 3 inch lift, bigger wheels and tires...and did i mention stacks???
Nathaniel
Get To Learning |
#10 |
You'd probably have to put a stack or two on it to keep it quiet on the course. The stacks do a good job of channeling the sound up where it can't reflex off of anything.
Usually 20 hp set ups. |
