| Thread Details Posted by DieselMonk, this thread has received 15 replies and been viewed 3378 times. |
#1 |
How do YOU break in your diesel engine?
I'd like to know from everybody how they break-in their new diesels ?
Some break them in "hard" others baby them... so what's better to to? :evil:
07 Chevrolet Classic 2500HD, LBZ 6.6L Duramax Diesel, 4" Magnaflow duals and Superchips. 05 Passat TDI, 2.0L pumpe duse diesel, stock. |
| Sponsored Links | |||
Advertisement | |||
#2 |
06 6. oh
When we got our 2006 f-250 i took it out that night and dogged the crap out of it...Problems to date 2 bad injectors, LPOP and HPOP under warranty and now head gaskets...all this at 150k miles and driven hard since day 1.:-)
2000 F-250 PowerStroke Diesel, CrewCab, ShortBed, Harvest Gold 300,000Miles as of 5/16/06, 4" Donahoe Racing Lift w/ 5.5" Rear blocks,16x10 Bullet hole pacer rims with 315/75/16 Bfg mudterrains wrapped around them(boy do they pull!!), Dual Exhaust 4" turbo back with 5" tips,A Custom Tuned jody Tipton PCM W/140 Race, HTC aftermarket Turbo, 3 pod gauge, Ultra lite boost, pyro and tranny, HX MOD, Boost Relief Kit, Procomp ladder bars(black) 2006 F-250 CC,SB,6.0, Lariat, Beige and 2 Tone black, 125,000 Miles as of 2-10-06 ,Dual Exhaust, Husky Floor Mats, Rhino lined,20x10 MotoMetals and 35x12.50 toyo m/ts, TheDieselGarage.com Sticker(25hp mode), Eliminated EGR cooler, EGR block off plate, Welded Up Pipe, SCT tuned by DJ and Bill @ Dfuser:-) CAN YOU KEEP UP? http://www.socaps.com/photopost/data...fia2darksm.jpg |
#3 |
Did you want to make this into a poll?
I've believed that you should drive a vehicle hard right from the get-go, ever since my Dad told me a story about their Airport Authority Cars. They had two identical Olds Cutlasses. One was driven up north and back at high speeds soon after it was bought. The other toiled at the airport, not driven hard at all. This second car was a total dog. But the first one ran like a raped ape and had more get-up than you'd believe a 2bbl 350 should have. I should know, because I got that car from my dad when I turned 16 and drove it all through high school. Maybe I'm FOS, but thats what I believe. I'd do the first oil change on a shorter interval, though. Maybe around 1000 miles. |
#4 |
Well the owners manual on the d max says dont tow for first 500 miles. When installing all jasper engines they said dont beat it dont baby it. Dont get out ont he highway and set the cruise but dont do all city driving either. Personally I know many trucks that are put to work from day one (companie drivers beat, pulling loads from day one), but personally I drove my new truck like normal, once and awhile id step on it, but fairly normal accelerations, mix of highway and city.
1996 Gmc k2500 4x4 6.5 turbo diesel, with mods Blew the head gasket, put all new heads, valves, injecotrs gaskets etc on the truck only to get it together and find out it had no oil pressure, and sounded horrible (pry a spun bearing). SOLD 2007 chevrolet 2500hd Duramax loaded. GM LEMON BUYBACK 2007 Chevrolet LBZ 1 ton crew cab 8ft box on star, xm, tow mirrors, 145 amp alt, #23 Singles Club |
#5 |
For not towing the first 500 miles, is more for the rear end.
Run hard, keep idling to a minimum. Helps the rings seat in properly. Don't just set the cruise. Vary the engine speed some. Pulling a trailer helps to break in the engine better, and quicker.
"Some people are educated beyond their intelligence." '93 W350 CC, LE, 5spd, HTT modded H1C, 4" DE Sold- '99 3500 Q/C, SO CTD, 4x4, 5spd. Traded off- '97 3500 C/C, 4x4, CTD '92 W250, LE, CC, CTD w/ tweaked pump (SOLD) ![]() "Obama = Hoax and Chains" If Obama is the answer, it must have been a stupid question. |
#6 |
I also was confused on the proper break in method so I took it easy for the first 100 miles and varied my speed, after that I would accelerate fully then bring it back down. I also made sure that I did not use any additves for the first 1500 miles.
2007 F-250 -6.0l -King Ranch -CC -3.73 auto -Fx4 -Sunroof -20" stock wheels -Black -High Idle Mod -ZooDad Mod -SCTX3 stock tunes -RDS 60g auxiliary tank-box combo |
#7 |
TDG Mafia # 81
![]() Join Date: Jan 2009
When I get a truck, it is ran hard from the very first turn of the key by me. I dont go full throttle all the time, but I get on it some. As stated before, change the oil at a 1/3 of recomended interval, then run it like you stole it.
And the setting of the rings, I read that when rebuilding a diesel. Run it down the road for the first time, punch it to 30MPH then let off, then punch it 40MPH let off, then punch it to 50MPH and let off. Has anyone else heard of this, it was in a old Chilton, and I do mean really old! Early 80's I think? (old for a diesel manual, dont get offended you old timers!) Tony
2001 GMC 2500HD EC/LB, 4X4. A few go fast goodies. 540hp/1107tq Danville Dyno 11/09, Kennedy 40% injectors and Danville Performance modified LBZ CP3 going in 12/20/09 2005 International 4300 SC, Vulcan 21ft car carrier w/wheellift. Need a American Enterprises Sidepulling Device! Proud Veteran Served 6yrs Active Army From Germany, Kuwait and Bosnia to Ft. Hood and Ft. Knox Operator, Manager, and Son of the Family Business. I make my living off others misfortunes, its just a fact! |
#8 |
Supporting Vendor
![]() Join Date: Dec 2008
When i bought the truck I was at the dealership with a bullydog Power pup in my hand. I walked outside and downloaded it. I let it warm up for a few minutes and put the peddle to the floor
2004F-SVT Lariat 2005 Cummins 5.9 conversion August 2007 TDG Truck of the Month Septmeber 2009 TDG Truck of the Month 2008 TDG Truck of the Year 2005 CR Cummins conversion with destroked motor mounts and tach module.
ARP Studs;Hamilton springs and pushrods WickedDiesel DragonSlayer CP3 and 5x10.5 inj Tsperformance MP8; Smarty S06 TNT-R Speraco Inercooler; Opie Water by-pass;DTT intake elbow Twin turbos Grand rock 7" stacks ATS Stage V 48re Transmission with billet output shaft and Co-pilot Ford transfer case with ATS input shaft. Thanks to Sogrand for that 4.56 gears with Detroit truetrac. Custom Oasis Diff covers FarmboyFabrication Ladder bars (10) Autometer Gauges 6.5" Explorer Procomp lift with Fox Shox 37x13.5x22 Toyos with 22x10 Eagle wheels 2005 front end conversion with McColluch HID lights Randy Ellias light bar with 4 procomp 130watt lights Heat exchanger hood; limo tint, recon lights up top and on the mirrors Optima. Yellow Tops; BilletBadges; Big special thanks to Walley at FTE My Cummins conversion:http://www.thedieselgarage.com/forum...read.php?t=933 |
#9 |
Also for myself, I keep it a bit easy for the first 500mi then I'll get gradually to full throttle. There are so many people of breaking engines it differently, so I thought to see which way is the most prefferred one.
I put on the SuperChip and the dual exhaust on at 1000mi and have the tow/performance setting programmed (60hp). The enginge stopped giving better milage for about 2000mi until I hauled my 32ft camper around, then I ended up yesterday at 20mpg hand calculated and gained about 1.5 mpg at 6000mi. A friend of mine has a 06 LBZ ext cab with 25000mi on it, never towed trailer, same mods done like my truck and get's worse fuel milage. :shrug:
#10 |
I just had a new motor put in mine because of a mechanics incompitence. I ran it pretty hard for the first 200 miles then I put my programer on it and let the smoke roll.
I'm Zac 2003 F-250 6.0 Powerstroke, Torqueshift, 4x4 Crew Cab, Shortbed, Dark Red Exterior; Tan Interior; H-11 Headstuds; Tuned by Innovative Diesel; MBRP down pipe straight into a 6 inch Grand Rock miter stack; Airaid Intake; Isspro Trans temp, Fuel pressure, Boost, Pyro gauges; EGR Cooler Deleted; Pro Comp 3in leveling kit and F-350 blocks out back; Eagle Alloy 114 wraped in Nitto Terra Grapplers; Ranchhand brushguard; Custom Traction Bars; Recon Smoke Cab Light and Third Brake Light;Pioneer CD Player and XM radio; and a "THE DIESEL GARAGE" sticker in the back window. Black Betty: 1981 Jeep CJ7 258 I-6, 4 spd, Headman Header, Comp Cams MSD ignition, Motorcraft 2100 Carb, 2in of lift, 30in Swampers, Lincoln Locked rear. Scrappy: 1975 Jeep CJ5 258 I-6, 3 spd,Headman Header, Motorcraft 2100 Carb, Full MSD ignition, Stretched 14 inches, 4 inches of lift, 33 inch tires, Lincoln Locker rear BOMB Squad #15 Singles Club #136 American Club #17 Riding Dirty Club #25 A big thanks to Aaron at Smoking Guns Performance
| Sponsored Links | |
Advertisement | |
