| Thread Details Posted by 19stroker96, this thread has received 11 replies and been viewed 1182 times. |
#1 |
obs to superduty turbo upgrades?
ok my stock turbo is toast so i am deciding on which turbo to go with i am thinking hypermax h2e or phat stroker from industrial injection i have a 96 so if i do a phat stroker and upgrade all my up pipes pedistal and everything i need from a superduty will it all fit under the hood with the phat stroker what all do i need to get from superduty to get it to work
2004 f350 6-oh 4" magnaflow turbo back leveled 35" nittos on 18" mkw M19 1996 f250 powerstroke (sold) |
| Sponsored Links | |||
Advertisement | |||
#2 |
Well you would need everything from the up pipes to the turbo pedistal to the SD Y pipe and everything in between. If you buy new not cheap. Only way to even come close to being worth your while is if you can find all the parts cheap like in a wrecked truck or something. By the time you buy the turbo and all the parts you could have bought that H2E and have more turbo.
'96 F-250 Extended Cab, GT'S injectors, GT'S intercooler install kit, custom turbo kit with a little HX40, Swamp's BIGEST oil. 466 on #2 only 739 with NČO 13.544 in 1/4 mi! "If you think you can do a thing or think you can't do a thing, you're right." Henry Ford Yeah I can keep up!:Thumbup: |
#3 |
Get the H2E. The SD guys only wish they had a turbo like that for a drop in
Eric 96 F-350 CC Dually My TDG Gallery
B codes, head studs, Comp 910 valve springs, stock turbo w/ 1.00 turbine housing 6.0 IC, NAPA 6637 air filter, AeroTurbine 4040XL, ITP Overboost Annihilator, Quadzilla Commander, electric fuel system w/ regulated return coolant filter, 203* thermostat Dually Club Member #53 346.7HP, 852.1TQ 12/15/07 Greeley, CO w/ stage 1 injectors and Wildman tunes |
#4 |
2L Motorsports
Definatly the H2E!
-Michael
Michael Paul (Jr.) - 2L Motorsports My Truck: 1995 F250: Regular cab, 7.3L PSD, ZF 5-Speed, 4x4, 4.10 LSD, Chip, Swamps Bigger Injectors, Turbo, Clutch, Gauges, 4" Downpipe, 6" Tip, Fuel System, Medium Oil, Headstuds, Valve springs, Cab Lights, Dana 60, 305/70R16s on Eagle Alloys - Driven Daily Still needing to be done: More Clutch, Ladder Bars, Even More Oil My Webshots - Facebook - MySpace |
#5 |
Yup, H2e...
01 F-250 SC PSD,210k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, GTS Hybrid injectors, Studs, 910 Valve springs, Forged rods Water injection,Swamps tuned, MBRP 4" dual's, Aero, 6" tip's, 100 axl tank, 4" Revtek lift, 37-14.50-17 TOYO MT's 469hp and 1068tq... ISSPRO PERFORMAX GAUGES |
#6 |
ok cool just wondering i have a pedistal, up pipes, sd y pipe, so i wasnt sure if i should do the phat stroker turbo or just the h2e im leaning more towars the h2e
#7 |
Mafia Member #93
what about the D66?
early 99 with some stuff on it |
#8 |
There are a few people that are running the superduity pedistill and compatible turbos, but I think they all had to either get about a 4in body lift or cut on the firewall to make it fit.
Ross Show-ME Smokers 2.6 modified street pulling truck "The Lone Stroke" My Videos 1996 f350, powerstroke, 4x4, 5-speed, 4.56 gears, Swamps 450/600 injectors, Swamps BFH turbo, Swamps Idm, Swamps tunes, BTS oil, SBC clutch, studs, springs, tubes, air to water intercooler, fuel system, factory rods! ![]() Tow Rig 1997 f350, srw, reg cab, 4x4, 5 speed, 4.10 gears, 3in down pipe, straight pipe, mystery chip. Becker Brothers Enterprises |
#9 | |
Darrell at diesel performance pluse posted in the venders section acouple of days ago tht he is in the process of comeing out with a turbo similar to the d66, but it's still in the testing fase.
#10 | |
| Sponsored Links | |
Advertisement | |
