Rough idle 6.0? - TheDieselGarage.com
Thread Details Posted by QtrHorse, this thread has received 7 replies and been viewed 12821 times.
Old 09-15-2005, 06:47 PM   #1
QtrHorse
Internet know it all
Rough idle 6.0?
My friend has a 2003 6.0 that just recently started to stumble/ have a rough idle very intermittently. He says it does it while the truck is moving and while it's stopped. I asked if it seemed to be completely killing the engine but he said no, so I guess that rules out the CPS.
Any help or ideas would be greatly appreciated.
99.5 F250 XLT S/C 6SPD
ITP Intank Mods*LUK clutch w/ Kevlar pilot*AFE Stage 1*Red Top Optimas*Fumoto*Reflexxion Cowl Hood
Truck Pic's
For the idiot at large. Unless I actually make a post or put a link in my signature that I have something for sale, I do not.
QtrHorse is offline   Reply With Quote
Old 09-15-2005, 06:54 PM   #2
Rcannon
is here and there.
Rcannon's Avatar
Images: 11
check the oil..
Overfill will cause the rough idle sometimes.
Life changes, so roll with it, not against it.
Rcannon is offline   Reply With Quote
Old 09-15-2005, 08:01 PM   #3
imported_LovinPSDs
Mine has been doing a funny idle too. It'll kinda get real quiet then after 2 or 3 seconds kidda click back up and sounds like a diesel. I hear a fluxuation (sp?) in boost alil too. I'll stay behind it and the exhuast will flow, then it seems to spool just alil bit then back to normal flow. AND I have noticed this change in boost alil during cruising too. Anyone have any ideas? It seems to be at the low RPMs like top gear at like 50 or so MPH. Anyone?? Startin to scare me..
Lovin
2004 King Ranch CC DRW DPPI Turbo Back, over head gauges, Looney wild, coolant filter
DUALLY CLUB MEMBER #61
To Do: Lift and bigger tires, studs
2006 ZX-6R- ALL BLACK :evil:
2000 CBR 600 Totaled.
CAN YOU KEEP UP?
imported_LovinPSDs is offline   Reply With Quote
Old 09-15-2005, 08:22 PM   #4
PSDPlayer
Diesel Custom Tuner
At idle the change in sound is the cycling of the egr. It is part of the strategy and can only be changed by a flash that addresses that concern. The new calibration will keep the egr open to keep engine noise low at idle. If you are at an extended idle the strategy will time out and the egr will close and the engine will become louder. The missfire rough idle maybe caused by a bad high pressure oil pump.
PSDPlayer is offline   Reply With Quote
Old 09-15-2005, 08:53 PM   #5
QtrHorse
There is another symptom that I forgot to list. When it has this rough idle/ cut out/ go dead symptom, it will blow just a little black smoke and then go back to normal.
I have read that the 6.0 turbo's need to be dissasembled and cleaned at 50,000-75,000 miles (depends on your driving habits), could this be the problem?
Truck Pic's
Old 09-15-2005, 09:46 PM   #6
PSDPlayer
Diesel Custom Tuner
Turbo really doesn't do anything at idle to cause your symptoms. Has move to do with injectors, high pressure oil pump. ICP and IPR.
Old 09-16-2005, 12:51 AM   #7
ntnbtwk
Send a message via MSN to ntnbtwk Send a message via Yahoo to ntnbtwk
this really sounds familiar for me as well..
2004 F250 XLT SC SB 4X4 AUTO
MODS :
BANKS TECHNICOOLER
4" TURBO BACK
SCT BIAVA RACE TUNE :Thumbup:
AFE STAGE II
ZOODAD
2 1/2 LEVEL KIT, 2500 LB OVERLOADS REAR
DUAL STEERING STABILIZER
315X70X16 GOOODYEAR ATS ON 16X10'S
ARE FIBERGLASS SHELL W/LIFT SIDE WINDOWS
FULL OFFICE LAPTOP,PRINTER,GPS. :bow:
KEEP IT LOADED AND THEY WONT BEG YA TO GET GROCERIES, :roflmao: :umno: "ATTENTION" THIS BIG HOSS ONLY STOPS FOR HARDWARE!!
ntnbtwk is offline   Reply With Quote
Old 09-16-2005, 02:29 AM   #8
VIZARD
Oil overfill and EGR strategy / issues are reasons.
In addition and very specific to the '03:
ICP Sensor Problems:
This is now covered by Customer Satisfaction Program 03B05. It applies to trucks build through 2-3-03. The program will be in affect until 12-31-05. Ford is authorizing a free oil and filter change under this program until 12-31-03.
Some 6.0 PowerStroke engines may exhibit rough/rolling idle, poor idle return, lack of power, injector fault codes or excessive smoke. This may be caused by the ICP sensor reading incorrectly. The ICP sensor and connector terminals should be inspected for damage (the ICP is at the rear of the engine, under the turbo), and the sensor circuits checked for opens or shorts. With the engine at operating temperature (engine oil above 180 degrees), the ICP sensor signal should be 0.16-0.28 volts (less than 70 PSI) with the key on and engine off. The engine needs to be off for at least two minutes for this test. If the ICP signal is not within this range, replace the sensor with P/N 3C3Z-9F838-EA
And lets not forget about wire chaffing.
'04 F-250 PSD 6.0 SC Long Bed FX4 w/camper package - Engine build date 10/03/03
I won't be harmed - I won't be insulted
I won't be laid a hand upon - I don't do any of these things
And I expect the same of others
J.B. Books credo
VIZARD is offline   Reply With Quote
2002 Ford SD hub lock maintence Bcarriveau Ford - Modification instructions, Product installs and Tech Articles 1 01-06-2009 05:49 PM
Well, it happened..... Summit6.6 2003-2007 6.0L Power Stroke 28 09-22-2005 08:13 PM
05E15 Recall UpstateDieselGuy 2003-2007 6.0L Power Stroke 0 09-09-2005 12:14 AM
Hey Chevy guys. Check out this gasser with a turbo slowford GM Performance Forum 13 08-22-2005 05:45 PM
Thanks For The Forum Guys! bigdraft 4X4 Offroad Forum 8 05-18-2005 02:47 AM
