TorqShift transmission oil change - TheDieselGarage.com
Thread Details Posted by Spuppy, this thread has received 20 replies and been viewed 25973 times.
Old 09-13-2007, 03:09 PM   #1
Spuppy
I have been reading posts on here that you should just leave the tranny alone, or if you do change the oil in it, you dont need to change the external filter. I would agree that 30,000 miles is early for a transmission flush but i don't want warranty issues so I had it done. Looking at my filter I cant understand how they can do a flush with out changing the filter. So why would a dealer not include a filter? Ford put one there for a reason. I would think that this is the probable cause for transmission failure, a plugged filter. now my tranny shifts are smoother and my wallet is lighter.
Spuppy is offline   Reply With Quote
Old 09-13-2007, 03:20 PM   #2
444turbodiesel
It depends on the usage, if you're towing a lot I'd say it needs to be changed every 30-40K, if not you could probably go a lot longer (especially with synthetics)
Which leads me to the question, what fluid is recommended (and not recommended) for the 5R110? Does it require a HFM fluid?
I know there was a lot of controversy over running synthetics and/or Mercon V in the 4R100.
(too lazy to walk out to the truck and read the manual )
07-6.0 4X4 CC Lariat Tow Boss w/36,000 trouble free miles.
CCV-Zoodad-Harpooned, cat delete, otherwise
BONE STOCK
444turbodiesel is offline   Reply With Quote
Old 09-13-2007, 03:36 PM   #3
Extended Power
Too much into it now...
Extended Power's Avatar
After I switched to Amsoil, not only do I have to change the oil...but the tranny too! And only after 5-6000 miles!
Stay with the Ford oil, and change all the filters...they are cheap.
Extended Power is offline   Reply With Quote
Old 09-13-2007, 03:47 PM   #4
TriGuy
Fire Fighter
ok I'm just about to do the 3rd fluid change on my 03's torqshift
do it yourself
I only drain the pan, thats about half of the tranny fluid
I change the external filter up at the tranny cooler [by the radiator passenger side]
ONLY USE Mercon SP fluid in the tranny if you value your warranty and tranny seals.
the whole process takes 20 minutes.
if I recall correctly there was a nice write up on this on Dieslemans 6.0 site
Do you smell smoke?
TriGuy is offline   Reply With Quote
Old 09-13-2007, 07:14 PM   #5
jennamax
I had the dealer flush my tranny by hooking it to their flushing machine do-hicky thing. They did not change the filters or drop the pan. The service tech told me the flush machine do-hicky thing actually cleans the filters as well.
2004 F350 Crew Cab 4X4 6.0 PSD
Lariat, Leather, Sunroof
4 1/2 inch Pro Comp lift
35X12.5X18 Pro Comp Extreme All Terrains
1000 Watt Sound System:Thumbup:
MBRP 4-in turbo back w/cat delete
SCT XCal-2 tuned by Innovative Diesel
Intake Elbow
Autometer Z-Series-pyro, tranny, boost on A-pillar
Zoodad
jennamax is offline   Reply With Quote
Old 09-13-2007, 08:10 PM   #6
TriGuy
Fire Fighter
the external filter on the tranny cooler is a paper element that looks like a mini roll of TP no way a flush is going to clean it. the internal filter is a wire mesh and I can see that getting cleaned in a flush. go pull the filter on the cooler, I'll bet it looks like crap
Do you smell smoke?
Old 09-13-2007, 08:23 PM   #7
bootcamp
bootcamp's Avatar
I have never change the oil in my tranny (41000 miles) ,but I did take the time to change out the 12 dollar tp paper filter , my old man did his at the same time and both of us agree that it did shift better after doing this.But we both imagine stuff all the time anyways.We didnt lose more than 4 oz of oil.The other thing I did notice was a temp difference on my gauge ,it did run a little cooler even if it was just 10 degrees. But the old filter that came out look like crap.
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline   Reply With Quote
Old 09-13-2007, 10:03 PM   #8
jennamax
When you change the paper filter does the tranny oil spill out? Or is it a simple pull and replace procedure? Do you buy the filter from the dealer or is any auto part store's filter sufficient?
Intake Elbow
Zoodad
Old 09-13-2007, 10:43 PM   #9
Extended Power
There's a little bit of oil, but nothing serious. Just use a rag.
The dealer charged me $26.00 for mine, but I'm Canadian, so it prolly only $12-$13.00 for you US residents.
Old 09-14-2007, 12:56 AM   #10
Spuppy
444turbodiesel,
Ford uses mercon sp, (18) quarts, there isnt anything else on the market yet as far as I know. Its synthetic so what could be better?? :shrug:
I agree with Triguy that you need to change the filters and as bad as mine looked I will change the filter again in about 1000 miles because between the machine flush and new oil I am sure it will be dirty soon.
