Dual Alternator Setup - TheDieselGarage.com
Thread Details Posted by M.R.C. F-250, this thread has received 5 replies and been viewed 1580 times.
Old 09-21-2005, 04:15 PM   #1
M.R.C. F-250
Welcome to the Darkside
Does anyone know what parts are required for the dual alternator setup? I did not get it with my truck and was thinking about installing it.
Thanks,
M.R.C. F-250
M.R.C. F-250 is offline   Reply With Quote
Old 09-21-2005, 06:20 PM   #2
CrimsnTide
Seems to me that I have read a few posts saying this "upgrade" was NOT an easy one to do after the truck was built. I can't recall the problems encountered, but there were some issues. For some reason, I want to say the routing or bending of a particular tube was/is needed. I'm sure it can be done, but to what extent. I think people who have considered going to the dual altenator, were convinced to check out just purchasing a higher output altenator - not necessarily Fords' heavy duty one, but an aftermarket one. Not much help I know, but I'm sure this will get someone to respond with some greater knowledge... :
2006 F350 w/6.0 CC, LB
CrimsnTide is offline   Reply With Quote
Old 09-21-2005, 09:22 PM   #3
nummit
It's more than bolting on another alt,belt,etc.The PCM is also programmed to control the 2nd alt.
Unless you can find a way for the computer to talk to the added alt. I dont know how you could add an alternator.
Perhaps SCT tuners could help?
I debated removing my second alt.until I found out about the computer issue.
nummit is offline   Reply With Quote
Old 09-21-2005, 11:19 PM   #4
imported_poppasmurf
yeah...
I agree with the others. Adding one after the fact is very difficult and very spendy. The easiest route would be to put a higher capacity alternator on instead of your factory alternator.
Whenever people are ordering a new truck, I always tell them to order the dual alternators if they even have an itch that they may need it in the future. The $300 at time of order is small compared to after the fact.
Good luck with your quest,
Brian.
2004 F250 Lariat, Diesel 6.0L, 5spd auto,4x4 FX4, True Blue/Med Parchment, Camper Package, Cab lights, Dual Alternators, AIC, Power Sliding Rear window, 12.5k receiver hitch.
Add-ons: Headache Rack, Brush Guard, B&W Hidden Hitch & Daytime Running Lights, PIAA 520 series driving lights, boost/tranny gauges, Dahl 100 fuel filter/water separator, Prodigy brake controller, air horns, high visibility LED signals (below doors).
In-the-works: Onboard air, Aux. fuel/Toolbox combo, Thermocouple installation.
Ordered on: 03/29/04.
Arrived on: 04/28/04.
SIGNED: 05/01/04 Whoop!
Recall 04B24: Installed 02/15/05.
imported_poppasmurf is offline   Reply With Quote
Old 09-21-2005, 11:57 PM   #5
M.R.C. F-250
Thanks for the input guys. I will definitely look into the high output one. Any brand in particular I should look into?
M.R.C. F-250 a.k.a. DjLinks
"In Thrust We Trust"
Black 2005 F-250 Crew Cab XLT Sport FX4
Performance:
Airaid Intake w/Plexi Mod, Zoodad Mod, MBRP 4" Turbo Back, Auto Meter Sport Comp Pyrometer, SCT Tunes by DJ's Diesel Performance & The Frog
Audio:
OEM Radio 6 Disc MP3, 08 Super Duty Door Tweeter Pods, Infinity Kappa Mids & Highs, JL Audio 300/4, JL Audio 12W3, JL Audio 500/1
Exterior:
Smoked Tail Lights, Third Brake Light & Tail Gate Clearance Lights, FX4 Decals Removed, Steveracer Mod, OEM 20" Wheels, Reverse Flood Lights, Cowl Induction Hood
Old 09-22-2005, 05:01 AM   #6
PSDPlayer
Diesel Custom Tuner
Don't even try it. You are better off getting yours upgraded. You can go to about 200 amp in the stock 3g case. Going any larger will require external regulation where you will have to mount a separate voltage regulator. To go dual alt it like swapping an auto for a manual trans and vice versa. Just trade the truck.
PSDPlayer is offline   Reply With Quote
No flaming allowed...... woodsracer 5.9L Cummins (2003-2007.5) 11 06-11-2006 06:46 PM
HELP ! 94 12 V W/ Issues VIDEO FOOTAGE ! DieselMinded 5.9L Cummins (Pre 1994) 21 09-19-2005 12:05 AM
International 504? Deezle1 Utility & Farm Tractors 34 06-25-2005 03:09 AM
