Diesel Dakota conversion - TheDieselGarage.com
Go Back   TheDieselGarage.com > Diesel Conversion > Diesel Conversion
Thread Details Posted by Sanders, this thread has received 16 replies and been viewed 6760 times.
Old 09-29-2007, 03:44 AM   #1
Sanders
I currently have a Dodge Dakota with a 360 V8 AWD. I'll admit I like the motor but I don't like the MPG, I get 11 mpg on the highway and around 9 around town. Awful is the only way to describe it, my treehugging side feels guilty at times. Anyway, all joking aside I was thinking about putting a Duramax in the Dakota. Here's the plan:
1. Find Durmax with wiring harness and ECM
2. Find Allison transmission
3. Remove V8, tranny and transfer case. I would like to keep the AWD system but I think that might be more trouble than it's worth.
4. Install motor and tranny and custom driveshafts.
It sounds simple.
I was thinking the Duramax would be the best fit since I already have a big V8 in the Dakota. I need to get some measurement but I think it will fit. I was thinking about running two wiring harnesses in the truck. It may sound odd but it saves me having to splice a bunch of wires. Have a stand alone system for the motor and leave the original wiring harness for the rest of the truck.
As far as the tranny goes I think it will be fairly simple. I'm sure I'll have to make some crossmember modifications and take the driveshafts to get new yokes welded on.
It is going to be some work, but I think it will be possible. The big challenge will be making it look factory but I have a feeling it will look like something Frankenstien left in a toilet. I would like to hear inputs on this as far as engine choices etc....comments good or bad. Thanks
Sanders
EW1 USN
Sanders is offline   Reply With Quote
Old 09-29-2007, 04:12 AM   #2
MOOSE 04
that still seems like alot of motor to cram in there. maybe a cummins 4 cylinder would work best for that small of a truck
MOOSE 04 is offline   Reply With Quote
Old 09-29-2007, 08:02 PM   #3
nevrenufhp
Super Moderator
nevrenufhp's Avatar
There's a few guys in Canada that have Cummins 5.9's in Dakotas. The transfer case & drive shafts add to the expense, but really helps traction in all weather.
Dale
my daily driver:67 F100, 300 4V, cammed, 4 spd.
or, 08 VW R32.
work rigs: 94 IH 4900, DT466(originally 230hp), #0 fuel plate, tighter gov springs, 22* timing
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline   Reply With Quote
Old 09-29-2007, 08:30 PM   #4
USAFdieselman
My pride and joy!
I think there is a guy on base here that has a Cummins in a Dakota, but I never have the chance to stop him.
~Carl http://www.thesmilies.com/smilies/mi...rankf-ssgt.gif
03 Ford F250 7.3 PSD CC SB FX4
4" ProComp lift, TS Performance chip, AFE Stage 1, Wicked Wheel, ITP Boost Anihilator, MBRP 4" duals
SOON: Tony Wildman tunes and more ITP parts!
CAN YOU KEEP UP??
TDG Singles Club #130
Outlaw #7
USAFdieselman is offline   Reply With Quote
Old 09-30-2007, 02:53 AM   #5
keydl
Going for mileage? VW-TDI at much less cost and much more balance. Not enough HP? Blu-tec 3.0 from the new Jeep. A lot more trouble to find one for repower and a little more expensive but better matched to total vehicle weight.
Duramax leaves no cargo capacity on the front axle. 4BT is about the same as the 360. Perkins has some that are in the good choices for weight.
TDI will probably cruise over 80 mph and may get as high as 45 mpg. With a chip may be close to the 360 for torque.
keydl
93 Dodge /CTD, IC, 518, club cab LE, BHAF, KDP fixed, kelderman air ride
81 Isuzu /C223na, 5spd
keydl is offline   Reply With Quote
Old 10-01-2007, 03:36 AM   #6
stroker_baldy
OBS
Diesel World April of this year has an article of a 97 dakota w/ a cummins.
might wanna find that issue. volume 2, # 3, pages 36-39. hope that helps
97 F-250 7.3 psd 4x4: homemade Intake, fpr mod, IDM mod, 18k mod, HX mod, a pillar w/ 3 autometer gauges, 3" downpipe, minus muffler and cat.
stroker_baldy is offline   Reply With Quote
Old 10-02-2007, 01:15 AM   #7
Dieselwrencher
TDG Mafia Member #56
Dieselwrencher's Avatar
I agree the dmax might be too much for the front axle to hold. If you really want to go the dmax route you better plan on finding a D60 for the front and a heavy duty rear for the back. I doubt the factory front will hold it let alone the torque side of it.
2005 Dodge 3500 CC LB 5.9 48RE Smarty 5" Silverline Exhaust AFE Stage 2 305/70/17 Nitto Grapplers Tinted Windows
Putco light bar
1968 Corvette Coupe 5.9 cummins 47RH with Goerend parts assembled by Gilmore Performance 180 pump built by Smokem 12pt cage Ford 9" with spool 35 spline moser axles pro gears Quick Time DOT drag slicks tilt front end soon to get paint and more air.
1995 F-350 Crew Cab soon to be 6 door DRW Hauler project: 5.9 conversion in progress ZF5 speed destroked adaptor plate King pin D60 3.55 gears
Dieselwrencher is offline   Reply With Quote
Old 04-16-2008, 03:01 PM   #8
6BT-Dakota
Send a message via AIM to 6BT-Dakota
Im new to this site but that would be my truck.
6BT-Dakota is offline   Reply With Quote
Old 04-17-2008, 01:09 AM   #9
nevrenufhp
Super Moderator
nevrenufhp's Avatar
I think we need to see some pics sirrr! It's awe inspiring!
Dale
or, 08 VW R32.
Old 04-17-2008, 03:03 AM   #10
Dieselwrencher
Welcome to the garage, and nice Dakota!
Putco light bar
