6.9 upgrades? - TheDieselGarage.com
Go Back   TheDieselGarage.com > Ford Diesel & Truck Discussions > 7.3L and 6.9 IDI (Pre 1994)
Thread Details Posted by imported_7inchstack, this thread has received 17 replies and been viewed 5714 times.
Old 10-09-2007, 04:57 AM   #1
imported_7inchstack
6.9 upgrades?
My buddy has a 6.9L and was looking in to getting some power upgrades. he wants a turbo but he's affraid the motor will fall apart (242,000) hard miles. will the motor hold up with a turbo? and are there any injectors or anything that will give him some more fuel flow? ill find out the year,tranny,ect... tommorow.
Thanks Ryan
RYAN
At age 16 this is what i have to appreciate
1996 2500 4x4 reg cab, auto, NADP full billet tranny, 370's, custom full cut DV's, pump tweaking,AFC mods, #0, 5K GSK, 18* timing, ARP 12mm, custom K&N, industrial injection silver bullet, port matched ATS pulse manifold, CFM+ carbon intake manifold, 7 inch stack, autometer gauges (boost,EGT,trans,fuel), KDP fixed, DSS, 4 inch lift, 37 inch Xtreame A/T
13.9@95MPH=[ in the 1/4 mile on 37 inch radials not happy with that
431HP/828ft lbs at the norcal diesel dyno day
imported_7inchstack is offline   Reply With Quote
Old 10-11-2007, 03:48 AM   #2
imported_7inchstack
anyone?
Ryan
RYAN
Old 10-11-2007, 04:19 AM   #3
FordGuy100
Singles Outlaw member #9
Have him run this test. I believe its called a blow-by test. With the engine warm/idleing take off the oil filler cap and check to see if he can see any smoke coming out of it. If he can see smoke coming out with it idleing in a good amount, then I would say he isnt a good canidate, but if hardly any smoke or no smoke comes out he should be good.
As for injectors, theres only one place www.dps-performance.com, they also sell injection pumps to your specs. But some people have had bad customer service from them, and others have gotten bad items from them.
1985 Ford F-250 with a 6.9 IDI, Regular cab, 4x4, T-19 tranny, 3.54's non-limited slip.Things I've done:
New Dupont blazing fire red paint, new eagle alloys series 186 in 16x8" with BFG T/A KO 285/75/16 E tires, all new exterior chrome pieces like new bumpers new grille ect., ISSPRO tach on the A-pillar, ATS wastegated turbo, 4" exhaust, ISSPRO boost pyro water and oil temp gagues, pump maxed out, coming soon: stereo, spray in bedliner, other misc stuff. Wishlist: A Zf-5 speed or gear vendors overdrive, lockers, 2.5"-4" of lift with 315/75/16 tires, newer seat from a psd, all new gauges, Dana 60 front end, a 7.3 psd intercooler, propane, moose pump.
FordGuy100 is offline   Reply With Quote
Old 10-11-2007, 04:56 AM   #4
imported_7inchstack
alright i'll let him now. Thanks What kinda power do the 6.9's put out stock? (to the wheels?) like 130 HP?
Thanks Ryan
RYAN
Old 10-11-2007, 01:55 PM   #5
FordGuy100
Yeah I would say 130hp at the wheels is around the average for a stock IDI. Turbo IDI's with fresh IP's and injectors will put down around 200hp.
Another thing is ask him how much oil he burns, should be around a quart of oil every 500 miles, or less. And if you want to go over the top, get a compression tester and test all the cylinders for compression.
Old 10-11-2007, 04:42 PM   #6
Dieselwrencher
TDG Mafia Member #56
Dieselwrencher's Avatar
Just be careful, the wrist pins are the weak link there in those when turboing them. If he does do it do not over boost it especially with that many miles on it.
2005 Dodge 3500 CC LB 5.9 48RE Smarty 5" Silverline Exhaust AFE Stage 2 305/70/17 Nitto Grapplers Tinted Windows
Putco light bar
1968 Corvette Coupe 5.9 cummins 47RH with Goerend parts assembled by Gilmore Performance 180 pump built by Smokem 12pt cage Ford 9" with spool 35 spline moser axles pro gears Quick Time DOT drag slicks tilt front end soon to get paint and more air.
1995 F-350 Crew Cab soon to be 6 door DRW Hauler project: 5.9 conversion in progress ZF5 speed destroked adaptor plate King pin D60 3.55 gears
Dieselwrencher is offline   Reply With Quote
Old 10-11-2007, 09:17 PM   #7
rwaltonky
TDG MAFIA MEMBER #75
Send a message via AIM to rwaltonky Send a message via Yahoo to rwaltonky
I put my truck on a dyno and only got 170hp at the rear wheels. I have an after market turbo, a higher performance injector pump (not just a screw turn up), 20hp injectors, 3 1/2 in exhaust and k&n air filter with soup bowl mods. I also have a holley blue electric fuel pump. Thats a lot of stuff and work just to have 170hp. I can have a bigger ip pump and injectors built but I have to do some internal engine work and head work. Hope that gives you an idea.
Ray
1985 Ford F-250 4x4 200hp and 300ft. lb. torque. It has 3:55 gears, Dps high performance IP pump, Stage 1 injectors, Aftermarket hypermax turbo 3 1/2 in. straight pipe with 5in. tip, Holley electric fuel pump, and home made K&N ram air intake. Also keyless entry and power window kit installed, cowl induction hood and it all sits on a set of 33x12.50x16.5
1991 Ford ranger 2wd 5 speed. No mods, Cheap on gas
MY VIDEO LINKS
http://video.thedieselgarage.com/cat...ac0161c12e.htm
http://video.thedieselgarage.com/cat...93011b0897.htm
http://video.thedieselgarage.com/cat...39011bc6c4.htm
My Pics
http://www.thedieselgarage.com/galle...=9&userid=5065
rwaltonky is offline   Reply With Quote
Old 10-12-2007, 03:24 AM   #8
imported_7inchstack
alright thanks guys i'll pass this info to him. how much boost we talking? not much like 15-20 PSI?
Thanks Ryan
RYAN
Old 10-12-2007, 03:59 AM   #9
FordGuy100
Boost is kind of your own personal preference. Usually people say a stock 6.9 with head bolts can handle a max of 12-15psi. I would stay on the low side of that, unless you had head studs, then 15 psi wouldnt be a problem.
And looking at another thread on another site, I would say 200hp for a turbo IDI is a little to much. Heres a quote from the thread, he was talking about how propane makes a difference power-wise.
"Here are my numbers on the dyno run this summer:
First pull, no LPG
HP 183.15 Torque 325.45
2nd and 3rd pull with LPG
HP 205.35 Torque 362.64
HP 205.51 Torque 361.55
So 22.96 increase in HP and 37.19 increase in Torque with the propane.
One of the guys figured that is 298.5HP at the crank with the LPG. not bad for a stock pump, just turned up, stock injectors, old style Banks turbo, and homeade LPG. Oh yea, little exhaust work also."
I think that 298.5hp at the crank is a bit excessive though, more like 250-260hp at the crank.
Old 10-12-2007, 08:14 PM   #10
John_G
Super Moderator
John_G's Avatar
205.51 WHP is about 236.90 CHP if he has a M/T.
How? The driveline efficiency of the F2/350 with a M/T is about 86.75%, lower with an A/T.
DO NOT get greedy with power if you have a 6.9L. The pistons cannot take a lot of CP, and the headgaskets are already prone to external leaks.
I vote for LIBERTY!
