detroit 471 hp/tq? - TheDieselGarage.com
Go Back   TheDieselGarage.com > Diesel Conversion > Diesel Conversion
Thread Details Posted by 86 1 tonhauler, this thread has received 3 replies and been viewed 4177 times.
Old 10-15-2007, 02:30 PM   #1
86 1 tonhauler
TDG MAFIA MEMBER #72
86 1 tonhauler's Avatar
Send a message via Yahoo to 86 1 tonhauler
detroit 471 hp/tq?
i just bought a running very very good 471 detroit diesel , im thinkin about putting it in my 86 1 ton dually and i was curious as to what the hp and tq numbers were:Thumbup:
1986 f-350 6.9 dually str8 piped ,maxed out injection pump ,bucket seats, diamond plate flat bed,propane injection, on board aircompressor, train horns,goose neck plate, future mod , custom built turbo kit with intercooler and dual 4" miter cut stacks TDG DUALLY CLUB #5
RIDIN DIRTY #44
01 chevy 2500 HD 4x4 duramax
anybody got any used 4" miter cut stack laying around? pm me if ya do
quote: BARRY1ME: BTW I love your sig about engineers....but it should be changed to, if the engineers believe it isnt broke it doesnt have enough content removed from it. And thats the truth! (FYI I am engineer and work for Ford lol) At Ford the goal is to make the part barely good enough to passing DV (developmental validation) testing....If it passes way beyond the test then the part was overengineered, and content needs to be removed to reduce cost.
I CANT KEEP UP!!! HELP!!!
86 1 tonhauler is offline   Reply With Quote
Old 10-16-2007, 10:13 PM   #2
Dieselwrencher
TDG Mafia Member #56
Dieselwrencher's Avatar
I am not sure about the numbers on it, but if you look on the valve cover there should be a data plate that should tell you.
2005 Dodge 3500 CC LB 5.9 48RE Smarty 5" Silverline Exhaust AFE Stage 2 305/70/17 Nitto Grapplers Tinted Windows
Putco light bar
1968 Corvette Coupe 5.9 cummins 47RH with Goerend parts assembled by Gilmore Performance 180 pump built by Smokem 12pt cage Ford 9" with spool 35 spline moser axles pro gears Quick Time DOT drag slicks tilt front end soon to get paint and more air.
1995 F-350 Crew Cab soon to be 6 door DRW Hauler project: 5.9 conversion in progress ZF5 speed destroked adaptor plate King pin D60 3.55 gears
Dieselwrencher is offline   Reply With Quote
Old 10-17-2007, 04:25 AM   #3
DBogo
RCFFD #47
Send a message via AIM to DBogo
something like 160 horse and 485 foot pounds if i recall correctly, and i think thats for a 471t
1995 Ram 2500 12v NV4500 4x4, 5" ss straight piped , ICEBOX, #10 place, 215 injectors, 4.5gsk, afc full forward, cranked starwheel, autometer boost/pyro, jacobs exhaust brake, 60lb springs, boost elbow, KDP tabbed, HID's, DT Profab +1/2" control arms, silencer ring MIA, air horns
1988 Mack RD690, 300, 8spd, 17' Bibeau dump, electric tarp, leds all around, 2 stage jake, 6" straight stack, the 'ol dog barks
1983 VW Rabbit Pickup, 1.6 N/A, 5spd, stock for now
The Desire to Serve, The Ability to Perform, The Courage to Act 100% Volunteer
DBogo is offline   Reply With Quote
Old 10-17-2007, 04:52 AM   #4
444turbodiesel
167 hp at 2200rpm should be the rating, torque would be pretty low though. Two strokers had to be wound tight to build power.
07-6.0 4X4 CC Lariat Tow Boss w/36,000 trouble free miles.
CCV-Zoodad-Harpooned, cat delete, otherwise
BONE STOCK
444turbodiesel is offline   Reply With Quote
