how to delete ebpv - TheDieselGarage.com
Home Forum Who's Online Today's Posts Vendors Advertise Insurance Auto Loans
Thread Details Posted by StrokeThis, this thread has received 3 replies and been viewed 614 times.
Old 10-19-2007, 02:53 AM   #1
StrokeThis
Formerly CursedtoFirst45
StrokeThis's Avatar
how to delete ebpv
first of all im not really all that mechanically inclined as far as terms go, but i can do the work.
how do you remove the ebpv, what does it look like, and is there a thread related with step by step instructions?
thanks in advance,
eric
Eric
1994 Dodge Ram 2500
You can take our information, you can try to shut us down, but we're still here, and we're going to be better than ever!!
-John DeereGreen
StrokeThis is offline   Reply With Quote
Old 10-19-2007, 05:24 AM   #2
2tonePSD
2tonePSD's Avatar
The purpose of the EBPV is to keep the exhaust heat in the engine and aid in warming the engine up in cold temps. I don't drive my truck all that much in cold temps and didn't like it closing while I was driving down the road so I just removed it. I also didn't see myself using it as an exhaust brake so that was another reason for removing.
To gut it you can remove the EBPV housing (where the down pipe connects). It has 3 bolts holding it on (on the OBS trucks anyway). I had my turbo out when I gutted mine so it was much easier to get to those bolts. Then take a torch and cut the head of the rivets off of the valve. You can then remove the main plate. Getting the rod out that goes top to bottom may be a challange. I cut it apart with the torch and punched both sides in toward the center to remove it. You will then have to close off at least the bottom hole where the EBPV lever was hooked to it. I used a steel soft plug (freeze plug) to cap it off, 7/8" if I remember correctly.
Then you have to deal with the rod that comes out of the pedestal. I just took a piece of fuel line and hose clamped it on to the rod up against the pedestal so that it would stay tight against the internal spring and centered in the hole.
this was from a thread that was posted the other day. Racehauler is the one that wrote this.
RIP.......
96 F-350 Regular cab: 5" to 6" exhaust. autometer Z series a pillar pod for gauges. Window tint.
2tonePSD is offline   Reply With Quote
Old 10-19-2007, 08:17 AM   #3
bigdraft
The Big Meanie
bigdraft's Avatar
http://pages.prodigy.net/stevebaz/_i...az/index3.html
check this site out......the 7.3 BIBLE......it will help ya
kevin
1996 Dodge 3500 Ex. Cab LB Wide Hipper
Boys Stroke It...Men RAM It
Dually Club Member
Farm Club Member
If I Get Caught Drunk On My Horse, Is It A DUI Or A RUI???
I Got A Named Bubba
In Progress...
FOREVER FARMS
What Is A Farm With No Barns?
[Today 9:22 PM] GrnMachineLover: I just think diesels in cars are funny
bigdraft is offline   Reply With Quote
Old 10-20-2007, 01:30 AM   #4
STROKER#1
Arrow
Please read the above post with the title: Ebpv ?
STROKER#1 is offline   Reply With Quote
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
