Poor fuel mileage!!! - TheDieselGarage.com
Go Back   TheDieselGarage.com > Dodge Diesel & Truck Discussion > 5.9L Cummins 12 Valve (1994-1998.5)
Thread Details Posted by covey88, this thread has received 31 replies and been viewed 1556 times.
Old 10-21-2007, 09:56 PM   #1
covey88
covey88's Avatar
Ok guys I have tried changing the fuel filters, air filters, and I changed the transfer pump (the fuel pump, not the injector pump) and I still only get 15 mpg, this is how I calculate it fill truck up run truck to half tank fill up write do the gallons of fuel I get and divide buy the mile I put on since last fill up, is this right? I normally only get 220 to 225 miles to a half tank (35 gallon tank) what else could be wrong??????????
covey88 is offline   Reply With Quote
Old 10-21-2007, 11:37 PM   #2
cajuncummins
fill out your sig, cause if you have a dually with 410's that's about the mileage you'll be lookin at, also if you're having problems with your auto trans, that could suck some fuel efficiency too, what truck do you have? tell us and we can help more
anyways, just to throw some stuff out there, your timing might have slipped, it happens to older trucks
cajuncummins is offline   Reply With Quote
Old 10-21-2007, 11:43 PM   #3
DBogo
RCFFD #47
Send a message via AIM to DBogo
mines the same way, i got to get my timing checked, its more then i want to do, if anyone here wants to tackel the timing let me know
1995 Ram 2500 12v NV4500 4x4, 5" ss straight piped , ICEBOX, #10 place, 215 injectors, 4.5gsk, afc full forward, cranked starwheel, autometer boost/pyro, jacobs exhaust brake, 60lb springs, boost elbow, KDP tabbed, HID's, DT Profab +1/2" control arms, silencer ring MIA, air horns
1988 Mack RD690, 300, 8spd, 17' Bibeau dump, electric tarp, leds all around, 2 stage jake, 6" straight stack, the 'ol dog barks
1983 VW Rabbit Pickup, 1.6 N/A, 5spd, stock for now
The Desire to Serve, The Ability to Perform, The Courage to Act 100% Volunteer
DBogo is offline   Reply With Quote
Old 10-22-2007, 12:22 AM   #4
dangerous196
dangerous196's Avatar
Am I the only one or is that cajuncummins pic sick?!! Your milage is on the money for REAL world milage, of course you will get better just cruising down the freeway at about 60. That's when I get 700 miles per tank 35 gallon tank.
Around town 10 to 13 MPG is average! Remember your truck wieghs between 5000 and 8000 lbs thats 3 regular cars!! With that in mind 15 to 20 mpg is AWSOME!!
06 daully with intake exhuast and a few power mods
Looking for 700hp Any ideas on a turbo that can also pull 20k??
dangerous196 is offline   Reply With Quote
Old 10-22-2007, 03:02 AM   #5
coldcummins
I average 13mpg pulling 10k at 60mph and 21mpg at 65mph with 4:10s with the truck in my sig
97' 2500 ECLB, Tranny, Guages, 3gsk, DDP2's, MBRP duals, HT 60/14, KDP tabbed, BHAF, 100plate ff, *wheel cranked......
coldcummins is offline   Reply With Quote
Old 10-22-2007, 03:50 AM   #6
Dual K20s
Professional Amateur
To check if anything is wrong, fill-up then drive about ten miles on the highway at 60mph then fill back up and calculate.
Have you replaced the overflow valve? I'd also time it to 16 cause that will help.
My name's Derek and this is my ride:
Singles Club Member #58
98 Dodge 2500 Motor: 12 valve, BHAF, 4K GSK, O-ringed head, .020 over HG, studs, Modified AFC, DDP4 injectors, DDP DVs, 17.5* timing, 16cm^2 ex. housing, Drivetrain: 5-speed 4x4 w/ SB clutch (13" OFE 450Hp)
83 Chevy K20 with turbo 6.2 Sold
It's not what you buy, It's what you build
Dual K20s is offline   Reply With Quote
Old 10-22-2007, 04:43 AM   #7
DBogo
RCFFD #47
i have not replaced the overflow valve, i did replace the lift pump though, also my milage is quite a bit better with red fuel in it, and my truck does have 3.55's in it not 4.10s so im not sure how im getting worse milage then the fella with 4.10s
Old 10-22-2007, 04:58 AM   #8
Dual K20s
You might checkout that overflow valve since even if the lp can make the predsure the valve will dump it before it gets high enough. I'd help ya w/ that timing but Id be a hell of a long road trip
I think its cnvrted2cummins' tint that helps, keeps things cool and flowing well Those are pretty good #'s
Old 10-22-2007, 05:17 AM   #9
DBogo
RCFFD #47
yea that is quite a ride
Old 10-22-2007, 02:24 PM   #10
Mopar1973Man
2nd Gen Guru
Mopar1973Man's Avatar
Send a message via Yahoo to Mopar1973Man
Like my truck I'm getting 19-20 MPG normally which is about 300-320 miles to half tank.
There is several thing that effect MPG numbers... Timing, fuel quality, over dosing with additives, tire size, lift kits, gearing, driving style, weather, speed etc...
I would say you extremely low in MPG number though...
Michael Nelson - 2002 Dodge Cummins & 1996 Dodge Ram 5.9L Gasser
116K Miles On My VP44 - 4 Years of 2 Cycle Oil Diet! - Mixed at 128:1 Ratio - 25.3 MPG maxed out!
Mopar1973Man is offline   Reply With Quote
