Fuel shutdown solonoid? - TheDieselGarage.com
Home Forum Who's Online Today's Posts Vendors Advertise Insurance Auto Loans
Go Back   TheDieselGarage.com > Diesel Conversion > Diesel Conversion
Thread Details Posted by 9 Lives, this thread has received 5 replies and been viewed 405 times.
Old 10-29-2007, 01:02 PM   #1
9 Lives
How do you wire it into the system on a Superduty ford? I want it to turn off and on just as a 12V cummins should in a dodge.
9 Lives is offline   Reply With Quote
Old 10-29-2007, 04:54 PM   #2
DBogo
RCFFD #47
Send a message via AIM to DBogo
is this a 12v in a superduty, or do you want to rig up something on a 7.3 or 6.0 im not sure what you want to do here, it seems like you have a superduty in a 12v that you want to make the shutoff silinoid work with your ignition switch
1995 Ram 2500 12v NV4500 4x4, 5" ss straight piped , ICEBOX, #10 place, 215 injectors, 4.5gsk, afc full forward, cranked starwheel, autometer boost/pyro, jacobs exhaust brake, 60lb springs, boost elbow, KDP tabbed, HID's, DT Profab +1/2" control arms, silencer ring MIA, air horns
1988 Mack RD690, 300, 8spd, 17' Bibeau dump, electric tarp, leds all around, 2 stage jake, 6" straight stack, the 'ol dog barks
1983 VW Rabbit Pickup, 1.6 N/A, 5spd, stock for now
The Desire to Serve, The Ability to Perform, The Courage to Act 100% Volunteer
DBogo is offline   Reply With Quote
Old 10-29-2007, 07:32 PM   #3
9 Lives
Im wanting to put a 98 12V engine into my superduty. Where do I splice and run the wires to make this shutdown solonoid work properly with the key.
Old 10-29-2007, 08:41 PM   #4
DBogo
RCFFD #47
you could do it that way, im not sure where to splice the wires, or you could put the selinoid on its own toggle switch, which would be easier, or even easier you could just put a manual shutdown with a cable you pull
Old 10-30-2007, 01:59 AM   #5
nevrenufhp
Super Moderator
nevrenufhp's Avatar
Basically, you turn on the key, and follow the wires down with a test lite.
Dale
my daily driver:67 F100, 300 4V, 4 spd.
work rigs: 94 IH 4900, DT466(originally 230hp), #0 fuel plate, tighter gov springs, 22* timing
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline   Reply With Quote
Old 10-30-2007, 04:25 AM   #6
Dieselwrencher
TDG Mafia Member #56
Dieselwrencher's Avatar
On the 12v shut off solenoid, one wire is ground, one is hot with ignition and one is hot while cranking. I think you can tap into the s terminal wire for the hold in power, and use a hot with key on for your power to it. Make sure these are on a fuse or breaker for safety.
2005 Dodge 3500 CC LB 5.9 48RE Smarty 5" Silverline Exhaust AFE Stage 2 305/70/17 Nitto Grapplers Tinted Windows
Putco light bar
1968 Corvette Coupe 5.9 cummins 47RH with Goerend parts assembled by Gilmore Performance 180 pump built by Smokem 12pt cage Ford 9" with spool 35 spline moser axles pro gears Quick Time DOT drag slicks tilt front end soon to get paint and more air.
1995 F-350 Crew Cab soon to be 6 door DRW Hauler project: 5.9 conversion in progress ZF5 speed destroked adaptor plate King pin D60 3.55 gears
Dieselwrencher is offline   Reply With Quote
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
